Anyone know where I can find a Housai exhaust valve guide?
Pete Fowler
PostPosted: Fri Jan 07, 2011 10:15 am    Post subject: Anyone know where I can find a Housai exhaust valve guide? Reply with quote
I've tried all the usual suspects with no luck.
jlpartington(at)att.net
PostPosted: Fri Jan 07, 2011 6:44 pm    Post subject: Anyone know where I can find a Housai exhaust valve guide? Reply with quote
doug sapp
To: yak-list(at)matronics.com
Sent: Fri, January 7, 2011 12:15:58 PM
Subject: Anyone know where I can find a Housai exhaust valve guide?
--> Yak-List message posted by: "Pete Fowler" <pfdesign1(at)cox.net (pfdesign1(at)cox.net)>
http://forums.matronics.com/viewtopic.php?p=325920#325920
Harv
PostPosted: Sat Jan 08, 2011 1:20 pm    Post subject: Re: Anyone know where I can find a Housai exhaust valve guid Reply with quote
Do you have a part number for the valve guide?
I've a contact in China that can pretty much find anything.,
Harv
tjyak50
PostPosted: Sun Jan 09, 2011 7:27 am    Post subject: Re: Anyone know where I can find a Housai exhaust valve guid Reply with quote
Pete:
If the guide is bad, why not just replace the cylinder. I think that will be a lot easier, faster and probably cheaper in the long run.
Getting the guide in and out (straight) is a trick.
Tj
dougsappllc(at)gmail.com
PostPosted: Sun Jan 09, 2011 9:03 am    Post subject: Anyone know where I can find a Housai exhaust valve guide? Reply with quote
Guys,I have put out some feelers in China.  Should have word back in about 2 weeks.
I do have intake seats and springs in stock as well as a 2 or 3 exhaust valves.  At this time used serviceable "as removed" cyls are in stock.  By spring we will have overhauled cyls in stock for the 285 hp HS6A engines.
Doug
On Sun, Jan 9, 2011 at 7:27 AM, tjyak50 <tomjohnson(at)cox.net (tomjohnson(at)cox.net)> wrote:
[quote] --> Yak-List message posted by: "tjyak50" <tomjohnson(at)cox.net (tomjohnson(at)cox.net)>
Pete:
Tj
http://forums.matronics.com/viewtopic.php?p=326103#326103
rget="_blank">http://www.matronics.com/Navigator?Yak-List
le, List Admin.
Nanchang CJ6
PostPosted: Mon Jan 17, 2011 12:09 am    Post subject: Re: Anyone know where I can find a Housai exhaust valve guid Reply with quote
Is this exhaust vavle you need in picture?
Maybe we can help you.
Sarah
 Filesize:  21.15 KB
 Viewed:  6107 Time(s)
Sarah's E-mail:lcdzkj@live.cn
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
