OV protection for Alt energized contactor
PostPosted: Tue Nov 23, 2010 6:06 am    Post subject: OV protection for Alt energized contactor Reply with quote
At 02:37 PM 11/22/2010, you wrote:
My Stby alternator energizes its contactor, per the attached drawing.
How do I provide OV protection to the circuit with an OVM 14?
John
http://forums.matronics.com//files/stby_alt_ov_protection_study_417.pdf
The drawing you posted won't work. See
http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z11M.pdf
for an exemplar technique for adding ov protection to
an externally regulated alternator. No b-lead contactor
is necessary.
jonlaury
PostPosted: Tue Nov 23, 2010 1:00 pm    Post subject: Re: OV protection for Alt energized contactor Reply with quote
Bob,
The B lead contactor was to avoid having an always hot 8 ga wire that goes across the top of my engine to the Stby 40a alternator. Maybe a large diode is a simpler solution.
What is it that won't work in the drawing? The wiring of the Ford regulator was clipped and pasted from Z-13. Is it the alternator energized contactor?
The attached uses your exemplar OV reference and shows the entire schematic.
John
John
Z8 w-SB ALT,GPJ-Rev C.pdf
 Filename:  Z8 w-SB ALT,GPJ-Rev C.pdf
 Filesize:  424.15 KB
 Downloaded:  422 Time(s)
PostPosted: Tue Nov 23, 2010 2:53 pm    Post subject: OV protection for Alt energized contactor Reply with quote
At 03:00 PM 11/23/2010, you wrote:
Bob,
Oh yeah, I think we had this discussion before. That
contactor would go right next to the battery contactor.
Energize it with power taken from the alternator control
switch that connects the Bus to the regulator.
PostPosted: Tue Nov 23, 2010 2:57 pm    Post subject: OV protection for Alt energized contactor Reply with quote
At 01:49 PM 11/23/2010, you wrote:
Looks to me if the S terminal of your Ford regulator senses too high a
voltage for any reason then it will cut all power to the F terminal of your
alternator. Problem with this set up is that it doesn't give you an
indication that you have gone into an OV situation.
OV is a transient event . . . perhaps 100 mS long followed
by a very long LV condition which flashes a light.
Float Flyr
PostPosted: Wed Nov 24, 2010 4:44 pm    Post subject: OV protection for Alt energized contactor Reply with quote
What causes the light to flash? I don't even see an enunciator light in the
schematic.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
jonlaury
PostPosted: Thu Nov 25, 2010 1:59 pm    Post subject: Re: OV protection for Alt energized contactor Reply with quote
schematic.
Noel,
Look at the schematic that I posted in this thread (that Bob started as a parallel to the original).
The 9005 LVM is on the far left of the schematic. I assume that the diode with the circle around it is a LED symbol. I usually see LED's indicated with a zig-zag arrow.
J
