Posted: Tue Nov 23, 2010 6:06 am Post subject: OV protection for Alt energized contactor |
At 02:37 PM 11/22/2010, you wrote:
The drawing you posted won't work. See
http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z11M.pdf
for an exemplar technique for adding ov protection to
an externally regulated alternator. No b-lead contactor
is necessary.
jonlaury
Posted: Tue Nov 23, 2010 1:00 pm Post subject: Re: OV protection for Alt energized contactor |
The B lead contactor was to avoid having an always hot 8 ga wire that goes across the top of my engine to the Stby 40a alternator. Maybe a large diode is a simpler solution.
What is it that won't work in the drawing? The wiring of the Ford regulator was clipped and pasted from Z-13. Is it the alternator energized contactor?
The attached uses your exemplar OV reference and shows the entire schematic.
 Download |
| Filename: |
Z8 w-SB ALT,GPJ-Rev C.pdf |
424.15 KB |
| Downloaded: |
467 Time(s) |
Posted: Tue Nov 23, 2010 2:53 pm Post subject: OV protection for Alt energized contactor |
At 03:00 PM 11/23/2010, you wrote:
Oh yeah, I think we had this discussion before. That
contactor would go right next to the battery contactor.
Energize it with power taken from the alternator control
switch that connects the Bus to the regulator.
Posted: Tue Nov 23, 2010 2:57 pm Post subject: OV protection for Alt energized contactor |
At 01:49 PM 11/23/2010, you wrote:
Looks to me if the S terminal of your Ford regulator senses too high a
voltage for any reason then it will cut all power to the F terminal of your
alternator. Problem with this set up is that it doesn't give you an
indication that you have gone into an OV situation.
OV is a transient event . . . perhaps 100 mS long followed
by a very long LV condition which flashes a light.
Float Flyr
Posted: Wed Nov 24, 2010 4:44 pm Post subject: OV protection for Alt energized contactor |
What causes the light to flash? I don't even see an enunciator light in the
schematic.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
jonlaury
Posted: Thu Nov 25, 2010 1:59 pm Post subject: Re: OV protection for Alt energized contactor |
| Quote: | What causes the light to flash? I don't even see an enunciator light in the
schematic. |
Noel,
Look at the schematic that I posted in this thread (that Bob started as a parallel to the original).
The 9005 LVM is on the far left of the schematic. I assume that the diode with the circle around it is a LED symbol. I usually see LED's indicated with a zig-zag arrow.
J
