Nanchang CJ6
Posted: Thu Jul 29, 2010 6:37 pm Post subject: Hot offer for Nanchang CJ6 Aircraft Parts |
Part Number Description
1 LS2-13 Brake drum
2 500×150 Tyre
3 400×150 Tyre
4 LS2-70 Brake pad
5 DZ-5 Spark plug
6 CQ-409 Brake bladder
7 H2-5500-80 Check Valve Assembly
8 H2-5500-70 Check Valve Assembly
9 H2-4150-00 Main Landing Gear Actuator
10 HB1-101-10x20x2.8 Bolt
11 HB1-404G-M10 Bolt
12 HB1-104-10x20x2.8 Bolt
13 H2-3000-02
14 BM8GB54-45 Pin
15 HB1-125-5x29.5x2 Bolt
16 HB1-404G-M4 Bolt
17 HB1-125-5x41.5x2 Bolt
18 HB1-125-5x41.5x2 Bolt
19 HB1-502LB-4x3.5 Bolt
20 HB1-106-4×16 Bolt
21 HB1-106-4×18 Bolt
22 HB1-106-5×16 Bolt
23 HB1-106-5×18×3 Bolt
24 HB1-106-5×28×3 Bolt
25 HB1-106-6×20×3 Bolt
26 HB1-106-6×22×3 Bolt
27 HB1-106-6×24×3 Bolt
28 HB1-106-6×40×3 Bolt
29 HB1-106-6×52×3 Bolt
30 HB1-106-8×22×3.5 Bolt
31 Stainless Exhaust System
32 Common Steel Exhaust System
33 Canopy
34 Antenna
35 HS-6A Engine
36 J9-G1 Propeller
37 H2-4210-31 Front wheel axle
38 QS-2B Brake valve
39 QSF-6A Air tap
40 H2-4250-00
41 H2-4220-00
42 Prop Cap and nut
43 crush washers for oil sump
44 Air flap valve
45 Prop governor control bracket
46 QS-1 air valve
47 QS-2 air valve
48 Air filters for air pump (box)
49 Gill shutters
50 Copilot lunch box Zeus
51 Oil cooler wing faring
52 Wing fuel door cover
53 12-5522-00 Double action valve
54 H2-5522-00 Emergency valve
55 H2-5503-00 Check Valve
56 H2-5523-00 Hose
57 H2-5524-00 Hose
58 H2-5526-00 Hose
59 H2-5532-00/3 Hose
60 H2-5532-00/5 Hose
61 H2-1030-100 Anti-Dust Cover
62 H2-0109-110 Seat pad
63 H2-7510-90 Seat pad
64 HB2-30B Pin
65 BM5GB62 Nut
66 GB1018-20 Washer
67 H2-9850-900 Oil Table
68 H2-9850-100 Screw Jack
69 H2-9820-200 Screw Jack
70 H2-9810-200 Screw Jack
71 H2-9820-300 Control Lock
72 H2-9820-400 Control Lock
73 H2-9260-10 Cover
74 H2-9830-700 Exhaust cover left
75 H2-9839-800 Exhaust cover right
76 FJ-15 Light Bulb
77 HB6-31 Rubber Sleeve
78 24V-220W landing light
79 FJ22 Nav light
80 FJ30V-0.17 light
81 H2-5526-00 Hose main gear emergency
82 JH2-6902-0039 Cowling air filter
83 H2-7510-90 Seat back
84 FL3 Compass Amplifier
85 H2-5524-00 Hose main gear
86 H2-6341-00/A gill assembly
_________________ Sarah's E-mail:lcdzkj@live.cn |
elmar.h(at)shaw.ca Guest
Posted: Fri Jul 30, 2010 11:29 am Post subject: Hot offer for Nanchang CJ6 Aircraft Parts |
Did anybody from the list ever
buy parts from those guys?
Is that a reliable CJ parts supplier,
is it worth a try?
cheers
Elmar
kelmonroe(at)comcast.net Guest
Posted: Fri Jul 30, 2010 12:10 pm Post subject: Hot offer for Nanchang CJ6 Aircraft Parts |
Buy your parts from Doug Sapp its a sure thing!!!
Posted: Sat Jul 31, 2010 4:32 am Post subject: Hot offer for Nanchang CJ6 Aircraft Parts |
Buy and support Doug Sapp. He's invested thousands and thousands of dollars buying and stocking parts to support the CJ and Yak community. Doug's always there when you need him and he's one of THE best resources you'll ever find. Even if this person were less expensive, which I seriously doubt, you will never be able to duplicate the infinite number of ways Doug supports our community.
As the saying goes, "don't be penny wise and pound foolish".
Dennis
yakplt(at)yahoo.com Guest
Posted: Sun Aug 01, 2010 3:19 pm Post subject: Hot offer for Nanchang CJ6 Aircraft Parts |
First, I fully concur with Dennis, who knows more about YAK's and CJ's than I do. .
Second, even if a part happened to cost more than someone else, I would still purchase it from Doug. This is a very small community. Doug ignores this and prices his parts fairly. If Doug folds and goes out of business, there are some folks out there that will use their new monopoly to gouge the living daylights out of all of us. Make no mistake about that.
There is a common ethic amoung a lot of us that who-ever provides the cheapest price, ....that is the person "I" am going to purchase from. BIG MISTAKE.
Penny wise, dollar foolish. DITTO !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
And that is all I am going to say.
Mark Bitterlich
--- On Sat, 7/31/10, A. Dennis Savarese <dsavarese0812(at)bellsouth.net> wrote:
From: A. Dennis Savarese <dsavarese0812(at)bellsouth.net>
Subject: Re: Re: Hot offer for Nanchang CJ6 Aircraft Parts
To: yak-list(at)matronics.com
Date: Saturday, July 31, 2010, 8:28 AM
Dennis
Nanchang CJ6
Posted: Sun Aug 01, 2010 5:55 pm Post subject: Re: Hot offer for Nanchang CJ6 Aircraft Parts |
Hello everyone,frankly speaking,all the parts in the list we have sent to our USA,UK,Australia and other country's customers.And every customer is much satisfied with quality and price of our items.We also passed Quality Management System Certificate which is in the attached file.Please check it.Welcome to work together.Hope we can help you.
285.58 KB |
6933 Time(s) |
