Hot offer for Nanchang CJ6 Aircraft Parts
Nanchang CJ6
PostPosted: Thu Jul 29, 2010 6:37 pm    Post subject: Hot offer for Nanchang CJ6 Aircraft Parts Reply with quote
Part Number Description
  1 LS2-13 Brake drum
  2 500×150 Tyre
  3 400×150 Tyre
  4 LS2-70 Brake pad
  5 DZ-5 Spark plug
  6 CQ-409 Brake bladder
  7 H2-5500-80 Check Valve Assembly
  8 H2-5500-70 Check Valve Assembly
  9 H2-4150-00 Main Landing Gear Actuator
  10 HB1-101-10x20x2.8 Bolt
  11 HB1-404G-M10 Bolt
  12 HB1-104-10x20x2.8 Bolt
  13 H2-3000-02
  14 BM8GB54-45 Pin
  15 HB1-125-5x29.5x2 Bolt
  16 HB1-404G-M4 Bolt
  17 HB1-125-5x41.5x2 Bolt
  18 HB1-125-5x41.5x2 Bolt
  19 HB1-502LB-4x3.5 Bolt
  20 HB1-106-4×16 Bolt
  21 HB1-106-4×18 Bolt
  22 HB1-106-5×16 Bolt
  23 HB1-106-5×18×3 Bolt
  24 HB1-106-5×28×3 Bolt
  25 HB1-106-6×20×3 Bolt
  26 HB1-106-6×22×3 Bolt
  27 HB1-106-6×24×3 Bolt
  28 HB1-106-6×40×3 Bolt
  29 HB1-106-6×52×3 Bolt
  30 HB1-106-8×22×3.5 Bolt
  31 Stainless Exhaust System
  32 Common Steel Exhaust System
  33 Canopy
  34 Antenna
  35 HS-6A Engine
  36 J9-G1 Propeller
  37 H2-4210-31  Front wheel axle
  38 QS-2B Brake valve
  39 QSF-6A Air tap
  40 H2-4250-00
  41 H2-4220-00
  42 Prop Cap and nut
  43 crush washers for oil sump
  44 Air flap valve
  45 Prop governor control bracket
  46 QS-1 air valve
  47 QS-2 air valve
  48 Air filters for air pump (box)
  49 Gill shutters
  50 Copilot lunch box Zeus
  51 Oil cooler wing faring
  52 Wing fuel door cover
  53 12-5522-00 Double action valve
  54 H2-5522-00 Emergency valve
  55 H2-5503-00 Check Valve
  56 H2-5523-00 Hose
  57 H2-5524-00 Hose
  58 H2-5526-00 Hose
  59 H2-5532-00/3 Hose
  60 H2-5532-00/5 Hose
  61 H2-1030-100 Anti-Dust Cover
  62 H2-0109-110 Seat pad
  63 H2-7510-90 Seat pad
  64 HB2-30B Pin
  65 BM5GB62 Nut
  66 GB1018-20 Washer
  67 H2-9850-900 Oil Table
  68 H2-9850-100 Screw Jack
  69 H2-9820-200 Screw Jack
  70 H2-9810-200 Screw Jack
  71 H2-9820-300 Control Lock
  72 H2-9820-400 Control Lock
  73 H2-9260-10 Cover
  74 H2-9830-700 Exhaust cover left
  75 H2-9839-800 Exhaust cover right
  76 FJ-15 Light Bulb
  77 HB6-31 Rubber Sleeve
  78 24V-220W landing light
  79 FJ22 Nav light
  80 FJ30V-0.17 light
  81 H2-5526-00 Hose main gear emergency
  82 JH2-6902-0039   Cowling air filter
  83 H2-7510-90  Seat back
  84 FL3 Compass Amplifier
  85 H2-5524-00 Hose main gear
  86 H2-6341-00/A gill assembly
Sarah's E-mail:lcdzkj@live.cn
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
elmar.h(at)shaw.ca
PostPosted: Fri Jul 30, 2010 11:29 am    Post subject: Hot offer for Nanchang CJ6 Aircraft Parts Reply with quote
Did anybody from the list ever
buy parts from those guys?
Is that a reliable CJ parts supplier,
is it worth a try?
cheers
Elmar
kelmonroe(at)comcast.net
PostPosted: Fri Jul 30, 2010 12:10 pm    Post subject: Hot offer for Nanchang CJ6 Aircraft Parts Reply with quote
Buy your parts from Doug Sapp its a sure thing!!!
dsavarese0812(at)bellsout
PostPosted: Sat Jul 31, 2010 4:32 am    Post subject: Hot offer for Nanchang CJ6 Aircraft Parts Reply with quote
Buy and support Doug Sapp. He's invested thousands and thousands of dollars buying and stocking parts to support the CJ and Yak community. Doug's always there when you need him and he's one of THE best resources you'll ever find. Even if this person were less expensive, which I seriously doubt, you will never be able to duplicate the infinite number of ways Doug supports our community.
As the saying goes, "don't be penny wise and pound foolish".
Dennis
yakplt(at)yahoo.com
PostPosted: Sun Aug 01, 2010 3:19 pm    Post subject: Hot offer for Nanchang CJ6 Aircraft Parts Reply with quote
First, I fully concur with Dennis, who knows more about YAK's and CJ's than I do. .
Second, even if a part happened to cost more than someone else, I would still purchase it from Doug. This is a very small community. Doug ignores this and prices his parts fairly. If Doug folds and goes out of business, there are some folks out there that will use their new monopoly to gouge the living daylights out of all of us. Make no mistake about that.
There is a common ethic amoung a lot of us that who-ever provides the cheapest price, ....that is the person "I" am going to purchase from. BIG MISTAKE.
Penny wise, dollar foolish. DITTO !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
And that is all I am going to say.
Mark Bitterlich
--- On Sat, 7/31/10, A. Dennis Savarese <dsavarese0812(at)bellsouth.net> wrote:
From: A. Dennis Savarese <dsavarese0812(at)bellsouth.net>
Subject: Re: Re: Hot offer for Nanchang CJ6 Aircraft Parts
To: yak-list(at)matronics.com
Date: Saturday, July 31, 2010, 8:28 AM
Dennis
Nanchang CJ6
PostPosted: Sun Aug 01, 2010 5:55 pm    Post subject: Re: Hot offer for Nanchang CJ6 Aircraft Parts Reply with quote
Hello everyone,frankly speaking,all the parts in the list we have sent to our USA,UK,Australia and other country's customers.And every customer is much satisfied with quality and price of our items.We also passed Quality Management System Certificate which is in the attached file.Please check it.Welcome to work together.Hope we can help you.
 Filesize:  285.58 KB
 Viewed:  6895 Time(s)
