rleffler
Posted: Tue Jun 08, 2010 1:55 am Post subject: Finish Kit Surpise |
My finish kit arrived yesterday. I was surprised by the gray primer on the cowl. I guess that’s something new Van’s is doing these days.
bob
62.32 KB |
5640 Time(s) |
_________________ Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler |
speckter(at)comcast.net Guest
Posted: Tue Jun 08, 2010 4:43 am Post subject: Finish Kit Surpise |
Looks like a nice get coat. Shucks we can’t make comments about your pink plane.
Gary Specketer
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler
Sent: Tuesday, June 08, 2010 4:55 AM
Subject: Finish Kit Surpise
bob
62.32 KB |
5635 Time(s) |
pilotmelch(at)omnav.com Guest
Posted: Tue Jun 08, 2010 7:49 am Post subject: Finish Kit Surpise |
Not sure if this is the same, but the more modern composite plane manufacturers are spraying a coat of primer into the mold before the layup/cloth or pre-preg is laid in. This is not a gel-coat (gel coat is polyester based and won’t stick to a pure epoxy matrix), but is instead a primer layer. Having it be the first layer in the mold layup does many things: 1) pre-primes the part for the builder J, 2) pre-fills the pinholes in a way that won’t allow them to reappear later J J, 3) provides a sure bond between the primer and epoxy matrix since the epoxy cures to it.
If this is what Van’s is doing now – great!
John Melchert
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of gary
Sent: Tuesday, June 08, 2010 7:42 AM
Subject: RE: Finish Kit Surpise
Gary Specketer
bob
62.32 KB |
5625 Time(s) |
Bob Turner
Posted: Tue Jun 08, 2010 10:24 am Post subject: Re: Finish Kit Surpise |
I wonder if Vans has changed vendors for the cowl. I am generally pleased with the kit, but I thought the QC on the cowl was lacking.
_________________ Bob Turner
RV-10 QB |
robin(at)PaintTheWeb.com Guest
Posted: Tue Jun 08, 2010 10:57 am Post subject: Finish Kit Surpise |
| Quote: | I thought the QC on the cowl was lacking<
Spoken like a builder that hasn't worked with the canopy yet! Talk about
crappy fiberglass. I would definitely pay extra for much more finished
glass parts. I decided to paint my interior canopy vs. headliner and it
takes a lot of filler and sanding to get the canopy paint ready inside &
out.
Robin
Posted: Tue Jun 08, 2010 11:48 am Post subject: Finish Kit Surpise |
Item #2 is not necessarily true, you just might not be able to see the pinholes and larger void, but that doesn't mean they aren't there.
The Nomex, honey comb sandwich material in the cowl certainly can allow for huge voids where the edge of the honeycomb is keeping the first layer of glass against the mold, but the area in the middle of the cell structure allows the glass to come off the mold, thus the alligator scale like skin.
Subject: RE: RV10-List: Finish Kit Surpise
Date: Tue, 8 Jun 2010 10:48:50 -0500
.ExternalClass .ecxshape {;} .ExternalClass p.ecxMsoNormal, .ExternalClass li.ecxMsoNormal, .ExternalClass div.ecxMsoNormal {margin-bottom:.0001pt;font-size:11.0pt;font-family:'Calibri','sans-serif';} .ExternalClass a:link, .ExternalClass span.ecxMsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited, .ExternalClass span.ecxMsoHyperlinkFollowed {color:purple;text-decoration:underline;} .ExternalClass p.ecxMsoAcetate, .ExternalClass li.ecxMsoAcetate, .ExternalClass div.ecxMsoAcetate {margin-bottom:.0001pt;font-size:8.0pt;font-family:'Tahoma','sans-serif';} .ExternalClass span.ecxBalloonTextChar {font-family:'Tahoma','sans-serif';} .ExternalClass span.ecxballoontextchar0 {font-family:'Tahoma','sans-serif';} .ExternalClass span.ecxEmailStyle20 {font-family:'Calibri','sans-serif';color:windowtext;} .ExternalClass span.ecxEmailStyle21 {font-family:'Calibri','sans-serif';color:#1F497D;} .ExternalClass span.ecxEmailStyle22 {font-family:'Arial','sans-serif';color:navy;} .ExternalClass span.ecxEmailStyle23 {font-family:'Calibri','sans-serif';color:#1F497D;} .ExternalClass .ecxMsoChpDefault {font-size:10.0pt;} (at)page Section1 {size:8.5in 11.0in;} .ExternalClass div.ecxSection1 {page:Section1;}
John Melchert
Gary Specketer
bob
62.32 KB |
5610 Time(s) |
Bob Turner
Posted: Tue Jun 08, 2010 12:02 pm Post subject: Re: Finish Kit Surpise |
Robin: Actually my cabin is done; I thought the QC on the cowl was worse. The cabin area issues were cosmetic; the cowl issues structural. The foam/glass reinforcement was placed too far aft. I had to remove some, and then reinforce what was left.
RV-10 QB |
Posted: Tue Jun 08, 2010 12:41 pm Post subject: Finish Kit Surpise |
And what paint are you using inside the cabin
Robin Marks wrote: [quote] [quote]--> RV10-List message posted by: Robin Marks <robin(at)painttheweb.com> (robin(at)painttheweb.com)
| Spoken like a builder that hasn't worked with the canopy yet! Talk about crappy fiberglass. I would definitely pay extra for much more finished glass parts. I decided to paint my interior canopy vs. headliner and it takes a lot of filler and sanding to get the canopy paint ready inside & out. Robin Do Not Archive --
Posted: Tue Jun 08, 2010 12:53 pm Post subject: Finish Kit Surpise |
Lynn, it has been almost 2 years now. I am sorry I don’t recall what paint was used but it turned out terrific and I really like the simplicity of the painted cabin after 155 hours. If I didn’t have an OH console with its complex angles, switches, openings & eyeball vents I would have used a headliner.
Good luck,
Robin
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Linn Walters
Sent: Tuesday, June 08, 2010 1:39 PM
Subject: Re: Re: Finish Kit Surpise
Robin Marks wrote: | Quote: | --> RV10-List message posted by: Robin Marks <robin(at)painttheweb.com> (robin(at)painttheweb.com) | Quote: | | I thought the QC on the cowl was lacking< | Spoken like a builder that hasn't worked with the canopy yet! Talk aboutcrappy fiberglass. I would definitely pay extra for much more finishedglass parts. I decided to paint my interior canopy vs. headliner and ittakes a lot of filler and sanding to get the canopy paint ready inside &out. | 0123[quote]--
