Finish Kit Surpise
rleffler
PostPosted: Tue Jun 08, 2010 1:55 am    Post subject: Finish Kit Surpise Reply with quote
My finish kit arrived yesterday. I was surprised by the gray primer on the cowl. I guess that’s something new Van’s is doing these days.
bob
 Filesize:  62.32 KB
 Viewed:  5586 Time(s)
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
speckter(at)comcast.net
PostPosted: Tue Jun 08, 2010 4:43 am    Post subject: Finish Kit Surpise Reply with quote
Looks like a nice get coat. Shucks we can’t make comments about your pink plane.
Gary Specketer
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler
Sent: Tuesday, June 08, 2010 4:55 AM
Subject: Finish Kit Surpise
bob
 Filesize:  62.32 KB
 Viewed:  5581 Time(s)
pilotmelch(at)omnav.com
PostPosted: Tue Jun 08, 2010 7:49 am    Post subject: Finish Kit Surpise Reply with quote
Not sure if this is the same, but the more modern composite plane manufacturers are spraying a coat of primer into the mold before the layup/cloth or pre-preg is laid in. This is not a gel-coat (gel coat is polyester based and won’t stick to a pure epoxy matrix), but is instead a primer layer. Having it be the first layer in the mold layup does many things: 1) pre-primes the part for the builder J, 2) pre-fills the pinholes in a way that won’t allow them to reappear later J J, 3) provides a sure bond between the primer and epoxy matrix since the epoxy cures to it.
If this is what Van’s is doing now – great!
John Melchert
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of gary
Sent: Tuesday, June 08, 2010 7:42 AM
Subject: RE: Finish Kit Surpise
Gary Specketer
bob
 Filesize:  62.32 KB
 Viewed:  5571 Time(s)
Bob Turner
PostPosted: Tue Jun 08, 2010 10:24 am    Post subject: Re: Finish Kit Surpise Reply with quote
I wonder if Vans has changed vendors for the cowl. I am generally pleased with the kit, but I thought the QC on the cowl was lacking.
Bob Turner
RV-10 QB
robin(at)PaintTheWeb.com
PostPosted: Tue Jun 08, 2010 10:57 am    Post subject: Finish Kit Surpise Reply with quote
I thought the QC on the cowl was lacking<
Spoken like a builder that hasn't worked with the canopy yet! Talk about
crappy fiberglass. I would definitely pay extra for much more finished
glass parts. I decided to paint my interior canopy vs. headliner and it
takes a lot of filler and sanding to get the canopy paint ready inside &
out.
Robin
indigoonlatigo(at)msn.com
PostPosted: Tue Jun 08, 2010 11:48 am    Post subject: Finish Kit Surpise Reply with quote
Item #2 is not necessarily true, you just might not be able to see the pinholes and larger void, but that doesn't mean they aren't there.
The Nomex, honey comb sandwich material in the cowl certainly can allow for huge voids where the edge of the honeycomb is keeping the first layer of glass against the mold, but the area in the middle of the cell structure allows the glass to come off the mold, thus the alligator scale like skin.
Subject: RE: RV10-List: Finish Kit Surpise
Date: Tue, 8 Jun 2010 10:48:50 -0500
.ExternalClass .ecxshape {;} .ExternalClass p.ecxMsoNormal, .ExternalClass li.ecxMsoNormal, .ExternalClass div.ecxMsoNormal {margin-bottom:.0001pt;font-size:11.0pt;font-family:'Calibri','sans-serif';} .ExternalClass a:link, .ExternalClass span.ecxMsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited, .ExternalClass span.ecxMsoHyperlinkFollowed {color:purple;text-decoration:underline;} .ExternalClass p.ecxMsoAcetate, .ExternalClass li.ecxMsoAcetate, .ExternalClass div.ecxMsoAcetate {margin-bottom:.0001pt;font-size:8.0pt;font-family:'Tahoma','sans-serif';} .ExternalClass span.ecxBalloonTextChar {font-family:'Tahoma','sans-serif';} .ExternalClass span.ecxballoontextchar0 {font-family:'Tahoma','sans-serif';} .ExternalClass span.ecxEmailStyle20 {font-family:'Calibri','sans-serif';color:windowtext;} .ExternalClass span.ecxEmailStyle21 {font-family:'Calibri','sans-serif';color:#1F497D;} .ExternalClass span.ecxEmailStyle22 {font-family:'Arial','sans-serif';color:navy;} .ExternalClass span.ecxEmailStyle23 {font-family:'Calibri','sans-serif';color:#1F497D;} .ExternalClass .ecxMsoChpDefault {font-size:10.0pt;} (at)page Section1 {size:8.5in 11.0in;} .ExternalClass div.ecxSection1 {page:Section1;}
John Melchert
Gary Specketer
bob
 Filesize:  62.32 KB
 Viewed:  5556 Time(s)
Bob Turner
PostPosted: Tue Jun 08, 2010 12:02 pm    Post subject: Re: Finish Kit Surpise Reply with quote
Robin: Actually my cabin is done; I thought the QC on the cowl was worse. The cabin area issues were cosmetic; the cowl issues structural. The foam/glass reinforcement was placed too far aft. I had to remove some, and then reinforce what was left.
Bob Turner
RV-10 QB
pitts_pilot(at)bellsouth.
PostPosted: Tue Jun 08, 2010 12:41 pm    Post subject: Finish Kit Surpise Reply with quote
And what paint are you using inside the cabin
Robin Marks wrote: [quote] [quote]--> RV10-List message posted by: Robin Marks <robin(at)painttheweb.com> (robin(at)painttheweb.com)
Spoken like a builder that hasn't worked with the canopy yet! Talk about crappy fiberglass. I would definitely pay extra for much more finished glass parts. I decided to paint my interior canopy vs. headliner and it takes a lot of filler and sanding to get the canopy paint ready inside & out. Robin Do Not Archive --
PostPosted: Tue Jun 08, 2010 12:53 pm    Post subject: Finish Kit Surpise Reply with quote
Lynn, it has been almost 2 years now. I am sorry I don’t recall what paint was used but it turned out terrific and I really like the simplicity of the painted cabin after 155 hours. If I didn’t have an OH console with its complex angles, switches, openings & eyeball vents I would have used a headliner.
Good luck,
Robin
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Linn Walters
Sent: Tuesday, June 08, 2010 1:39 PM
Subject: Re: Re: Finish Kit Surpise
Spoken like a builder that hasn't worked with the canopy yet! Talk aboutcrappy fiberglass. I would definitely pay extra for much more finishedglass parts. I decided to paint my interior canopy vs. headliner and ittakes a lot of filler and sanding to get the canopy paint ready inside &out.
3[quote]--
