jeffrey-j-paris(at)excite Guest
Posted: Thu Dec 17, 2009 4:30 pm Post subject: Oil Colloer Question? |
Jabiru List Guru"s,
I have attached a picture of a plenum I laid up that will fit my oil cooler. The plenum will be attached to some ducting and then to a NACA vent on my Europa's cowl. With that in mind I was wondering if anyone has scavenged the "hot air" off the oil cooler and used it as a source for cabin heat? Any pictures or input would help?
Jeff Paris
95% done on a Europa Classic Monowheel Jab 3300
Also a builder of a FAA SAIB grounded Zenith Zodiac CH601 XL Jab 3300 287 total hours until the hammer dropped.
Best Weight Loss Program - Click Here! Weight Loss Program Click Here For More Information
| | - The Matronics JabiruEngine-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?JabiruEngine-List |
2.47 MB |
6264 Time(s) |
Gary Weaver
Posted: Thu Jun 03, 2010 1:16 am Post subject: Re: Oil Colloer Question? |
Just a picture of mine on my highlander
189.1 KB |
5957 Time(s) |
wypaul
Posted: Fri Jun 04, 2010 1:20 pm Post subject: Re: Oil Colloer Question? |
Jeff,
When you need the cabin heat, the oil will not be hot enough to do you any good with the OC on line. I cut off the air to my oil cooler in the winter. Stick with the standard heat muff on the exhaust, for my 2 cents worth.
Paul
_________________ Paul Spackman
Q-2 Jabiru 3300 |
