Oil Colloer Question?
jeffrey-j-paris(at)excite
PostPosted: Thu Dec 17, 2009 4:30 pm    Post subject: Oil Colloer Question? Reply with quote
Jabiru List Guru"s,
I have attached a picture of a plenum I laid up that will fit my oil cooler. The plenum will be attached to some ducting and then to a NACA vent on my Europa's cowl. With that in mind I was wondering if anyone has scavenged the "hot air" off the oil cooler and used it as a source for cabin heat? Any pictures or input would help?
Jeff Paris
95% done on a Europa Classic Monowheel Jab 3300
Also a builder of a FAA SAIB grounded Zenith Zodiac CH601 XL Jab 3300 287 total hours until the hammer dropped.
Best Weight Loss Program - Click Here! Weight Loss Program Click Here For More Information
 Filesize:  2.47 MB
 Viewed:  6267 Time(s)
Gary Weaver
PostPosted: Thu Jun 03, 2010 1:16 am    Post subject: Re: Oil Colloer Question? Reply with quote
Just a picture of mine on my highlander
 Filesize:  189.1 KB
 Viewed:  5960 Time(s)
wypaul
PostPosted: Fri Jun 04, 2010 1:20 pm    Post subject: Re: Oil Colloer Question? Reply with quote
Jeff,
When you need the cabin heat, the oil will not be hot enough to do you any good with the OC on line. I cut off the air to my oil cooler in the winter. Stick with the standard heat muff on the exhaust, for my 2 cents worth.
Paul
Paul Spackman
Q-2 Jabiru 3300
