pbesing(at)yahoo.com Guest
Posted: Tue Feb 23, 2010 9:02 am Post subject: IO-320 Power Chart |
Does anyone have any performance numbers for an IO-320 and a Constant Speed prop? Power settings, fuel burn, etc?
Thanks!
Paul Besing
Doug Gray
Joined: 10 Jan 2006 Posts: 112 Location: Sydney, Australia
Posted: Tue Feb 23, 2010 11:03 am Post subject: IO-320 Power Chart |
Paul,
The attached table was derived using Kevin Horten's python code (thanks
Kevin) but with the parameters taken from the IO320D&E chart in the OM.
The figures marry up to the charts within the accuracy of my eyesight.
Is this what you were after?
Doug Gray
On Tue, 2010-02-23 at 08:53 -0800, Paul Besing wrote:
| Quote: | Does anyone have any performance numbers for an IO-320 and a Constant
Thanks!
Paul Besing
| Description: |
 Download |
| Filename: |
IO320Power.txt |
| Filesize: |
2.5 KB |
| Downloaded: |
450 Time(s) |
Doug Gray
Posted: Tue Feb 23, 2010 11:13 am Post subject: IO-320 Power Chart |
Correction IO-320-B , -D , AIO-320 and LIO-320-B
On Wed, 2010-02-24 at 06:02 +1100, Doug Gray wrote: [quote] | Quote: |
Paul,
Doug Gray
Thanks!
Paul Besing
| [b] |
Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 27801 Location: Toledo Washington (KTDO) USA
Posted: Tue Feb 23, 2010 3:07 pm Post subject: IO-320 Power Chart |
That is a sweet chart. I assume this is the information you can put into EFIS's like the GRT HX to readout real time power? I haven't actually looked at this configuration yet on the HX.
Has anyone run a chart for an IO-390?
RV-8 #82880 N998RV
http://www.mattsrv8.com Matt's Building Blog
Finishing Up...
?At 11:02 AM 2/23/2010 Tuesday, you wrote:
| Quote: | Paul,
Doug Gray
> Thanks!
> Paul Besing
_________________ Matt Dralle
Doug Gray
Posted: Tue Feb 23, 2010 4:31 pm Post subject: IO-320 Power Chart |
I believe the GRT units take the data in a different form - see the GRT_EFIS Yahoo group has a number of such tables. I don't have a GRT EFIS so I cannot give a more detailed response.
Kevin Horton's algorithm computes the power by interpolating the Lycoming plots and doing some pressure altitude corrections arithmetically.
The Lycoming plots are believed to be the product of extensive engine tests and I assume are accurate BUT only for the respective engines. I doubt such plots will ever be available for the 390 or any other modified or experimental engine. BPE is one company that does test engine modifications and may have done some tests. Even if they have I doubt these would be anywhere near the extent necessary to generate the Lycoming style plots. Further ... the chances that your 390 would be the same as any test article is extremely small.
Doug
On Tue, 2010-02-23 at 15:02 -0800, Matt Dralle wrote: [quote] | Quote: |
--> RV-List message posted by: Matt Dralle <dralle(at)matronics.com (dralle(at)matronics.com)>
RV-8 #82880 N998RV
Finishing Up...
| Quote: | Paul,
Doug Gray
> Thanks!
> Paul Besing
| [b]
Posted: Tue Feb 23, 2010 10:15 pm Post subject: IO-320 Power Chart |
Thanks very much, Doug.
Paul Besing
To: rv-list(at)matronics.com
Sent: Tue, February 23, 2010 5:29:20 PM
Subject: Re: IO-320 Power Chart
Doug
On Tue, 2010-02-23 at 15:02 -0800, Matt Dralle wrote: [quote] | Quote: | --> RV-List message posted by: Matt Dralle <dralle(at)matronics.com (dralle(at)matronics.com)>
RV-8 #82880 N998RV
Finishing Up...
| Quote: | Paul,
Doug Gray
> Thanks!
> Paul Besing
Posted: Wed Feb 24, 2010 5:24 am Post subject: IO-320 Power Chart |
I'm missing the email with the power chart attachment .... can someone
resend that???
Linn
Paul Besing wrote:
| Quote: | Thanks very much, Doug.
Paul Besing
*To:* rv-list(at)matronics.com
*Sent:* Tue, February 23, 2010 5:29:20 PM
*Subject:* Re: IO-320 Power Chart
Doug
> Matt Dralle
> RV-8 #82880 N998RV
> Finishing Up...
> >Paul,
> >Doug Gray
> >> Thanks!
> >> Paul Besing
