IO-320 Power Chart
pbesing(at)yahoo.com
PostPosted: Tue Feb 23, 2010 9:02 am    Post subject: IO-320 Power Chart Reply with quote
Does anyone have any performance numbers for an IO-320 and a Constant Speed prop? Power settings, fuel burn, etc?
Thanks!
Paul Besing
Doug Gray
PostPosted: Tue Feb 23, 2010 11:03 am    Post subject: IO-320 Power Chart Reply with quote
Paul,
The attached table was derived using Kevin Horten's python code (thanks
Kevin) but with the parameters taken from the IO320D&E chart in the OM.
The figures marry up to the charts within the accuracy of my eyesight.
Is this what you were after?
Doug Gray
Thanks!
Paul Besing
IO320Power.txt
 Filename:  IO320Power.txt
 Filesize:  2.5 KB
 Downloaded:  381 Time(s)
Doug Gray
PostPosted: Tue Feb 23, 2010 11:13 am    Post subject: IO-320 Power Chart Reply with quote
Correction IO-320-B , -D , AIO-320 and LIO-320-B
On Wed, 2010-02-24 at 06:02 +1100, Doug Gray wrote: [quote]
Paul,
Doug Gray
Thanks!
Paul Besing
Site Admin
PostPosted: Tue Feb 23, 2010 3:07 pm    Post subject: IO-320 Power Chart Reply with quote
That is a sweet chart. I assume this is the information you can put into EFIS's like the GRT HX to readout real time power? I haven't actually looked at this configuration yet on the HX.
Has anyone run a chart for an IO-390?
RV-8 #82880 N998RV
http://www.mattsrv8.com Matt's Building Blog
Finishing Up...
?At 11:02 AM 2/23/2010 Tuesday, you wrote:
Paul,
Doug Gray
> Thanks!
> Paul Besing
Doug Gray
PostPosted: Tue Feb 23, 2010 4:31 pm    Post subject: IO-320 Power Chart Reply with quote
I believe the GRT units take the data in a different form - see the GRT_EFIS Yahoo group has a number of such tables. I don't have a GRT EFIS so I cannot give a more detailed response.
Kevin Horton's algorithm computes the power by interpolating the Lycoming plots and doing some pressure altitude corrections arithmetically.
The Lycoming plots are believed to be the product of extensive engine tests and I assume are accurate BUT only for the respective engines. I doubt such plots will ever be available for the 390 or any other modified or experimental engine. BPE is one company that does test engine modifications and may have done some tests. Even if they have I doubt these would be anywhere near the extent necessary to generate the Lycoming style plots. Further ... the chances that your 390 would be the same as any test article is extremely small.
Doug
On Tue, 2010-02-23 at 15:02 -0800, Matt Dralle wrote: [quote]
--> RV-List message posted by: Matt Dralle <dralle(at)matronics.com (dralle(at)matronics.com)>
RV-8 #82880 N998RV
Finishing Up...
Paul,
Doug Gray
> Thanks!
> Paul Besing
PostPosted: Tue Feb 23, 2010 10:15 pm    Post subject: IO-320 Power Chart Reply with quote
Thanks very much, Doug.
Paul Besing
To: rv-list(at)matronics.com
Sent: Tue, February 23, 2010 5:29:20 PM
Subject: Re: IO-320 Power Chart
Doug
RV-8 #82880 N998RV
Finishing Up...
Paul,
Doug Gray
> Thanks!
> Paul Besing
pitts_pilot(at)bellsouth.
PostPosted: Wed Feb 24, 2010 5:24 am    Post subject: IO-320 Power Chart Reply with quote
I'm missing the email with the power chart attachment .... can someone
resend that???
Linn
Paul Besing
*To:* rv-list(at)matronics.com
*Sent:* Tue, February 23, 2010 5:29:20 PM
*Subject:* Re: IO-320 Power Chart
Doug
> Matt Dralle
> RV-8 #82880 N998RV
> Finishing Up...
> >Paul,
> >Doug Gray
> >> Thanks!
> >> Paul Besing
