albertakolbmk3
Joined: 13 Jun 2009 Posts: 69 Location: Innisfail, AB
Posted: Sun Jan 17, 2010 3:41 pm Post subject: Rivets used in lexan installation |
I'm replacing the lexan on my mkIII and would like to know what was originally used for rivets? The ones I drilled out have an aluminum body but the mandrel seems to be steel... is this correct? A magnet sticks quite well.
_________________ Tony B.
Kolb MKIII C
Rotax 582
C Gearbox 3.00:1
WD 66" 3 Blade Prop |
Posted: Sun Jan 17, 2010 5:23 pm Post subject: Rivets used in lexan installation |
well.
Tony B/Gang:
Kolb used to send aluminum closed end pop rivets for attaching lexan windows
and windshield. Yes, these rivets did have hardened steel mandrels and were
a bugger to punch out prior to drilling out a rivet.
I use them the first couple times around on windshield installation.
Now I use hardware store aluminum rivets with aluminum mandrels for any
lexan installation. Makes life a lot easier when it comes time to replace
the lexan.
Sorry I could not help you with the PPT, stick grip question. Not familiar
with multi-switch type grips.
mkIII - Looks like I may get to fly tomorrow, unless the weather guesser is
wrong.
_________________ John Hauck
Titus, Alabama |
frank.goodnight(at)att.ne Guest
Posted: Sun Jan 17, 2010 5:42 pm Post subject: Rivets used in lexan installation |
I used hardware store alum rivets for my lexan windshield . no problem
so far and easy to drill out if necessary .
Great weather in south , TX today 72 degrees.--8 mph wind and
bright sunshine. 1st flight in almost a month.
Frank Goodnight
Firestar 2
Brownsville , TX
On Jan 17, 2010, at 7:22 PM, John Hauck wrote:
> Tony B.
Tony B/Gang:
windows and windshield. Yes, these rivets did have hardened steel
mandrels and were a bugger to punch out prior to drilling out a rivet.
any lexan installation. Makes life a lot easier when it comes time
to replace the lexan.
familiar with multi-switch type grips.
guesser is wrong.
Vic Peters
Joined: 30 Oct 2009 Posts: 54 Location: Millinocket, Maine
Posted: Mon Jan 18, 2010 7:16 am Post subject: Rivets used in lexan installation |
Tony,
I used all aluminun fabric rivets. They covered the enlarged holes in the
lexan well.
2 yrs. no problem yet.
Ptt switch. Sounds like just an option.
Vic
Xtra 912
Maine
_________________ Vic
912ul Xtra
Maine
Too old to cut the mustard but not the cheese. |
rayw
Joined: 18 Jul 2009 Posts: 25 Location: Wisconsin, Central
Posted: Mon Jan 18, 2010 6:02 pm Post subject: Re: Rivets used in lexan installation |
Hi all,
While on the topic of rivets. What type of rivet is used to hold fabric on the wing ribs etc? Is there a AN number?
Ray W.
rickofudall
Posted: Mon Jan 18, 2010 6:54 pm Post subject: Rivets used in lexan installation |
Ray, attached is a picture of Poly Fibers fabric rivet. Spruce has them, but you might be able to find the same thing at a better price at McMaster Carr or other industrial supplier.
Rick Girard
On Mon, Jan 18, 2010 at 8:02 PM, rayw <rmwis(at)wi-net.com (rmwis(at)wi-net.com)> wrote:
109.95 KB |
9292 Time(s) |
Posted: Mon Jan 18, 2010 7:29 pm Post subject: Rivets used in lexan installation |
I feel much better using Poly Fiber Fabric Rivets on my airplane.
Rick Girard
Titus, Alabama |
rayw
Posted: Tue Jan 19, 2010 7:46 am Post subject: Re: Rivets used in lexan installation |
Thank you for your helpful replies. I am going to do a re-cover and don't have much to go by. Any suggestions on fabric weight/type etc? It is a Twin star Mark II
Ray W
rickofudall
Posted: Tue Jan 19, 2010 8:35 am Post subject: Rivets used in lexan installation |
Ray, Get a copy of the Poly Fiber manual before you do anything else and read it thorougly. Pay particular attention to appendix A if you are weight conscious about your project.
Rick Girard
On Tue, Jan 19, 2010 at 9:46 AM, rayw <rmwis(at)wi-net.com (rmwis(at)wi-net.com)> wrote:
[quote] --> Kolb-List message posted by: "rayw" <rmwis(at)wi-net.com (rmwis(at)wi-net.com)>
Ray W
http://forums.matronics.com/viewtopic.php?p=282229#282229
le, List Admin.
