k7wx(at)earthlink.net Guest
Posted: Sun Jan 10, 2010 8:56 am Post subject: CJ-6A LED replacement bulbs |
Gentlemen,
Larry Pine and I have been outfitting my CJ for night flight with wing strobes and a red strobe for the top of the rudder. We were also planning on replacing that anemic, barely visible flashlight bulb on the tail with a LED position light / strobe from Aveo Engineering.
Last week on the Internet I came across what appeared to be an exact LED drop-in replacement for the Chinese bulb. It's 24 volt, LED cluster that has the same bayonet base, draws very little current, is astonishingly bright and basically lasts forever. This would also be a direct, drop-in replacement for those three lights on the nose gear and mains. This particular LED arrangement has viewing angle of 90 degrees, so it is brightest when viewed mostly from straight ahead. Here is where I found this:
www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=%2Fother_bulbs.htm
The web site navigation is a little confusing and flat-footed, but basically what you would be looking for is the 24 volt, white, dual contact, single intensity, 15 mm 1142 bayonet base. The ordering designation is: 1142-W15-24V White LED bulb - 24V.
A few days ago my order arrived and last night we tested the landing gear and tail lights in place. Wow!
I've attached a picture of what this looks like installed. For about six bucks each they are the cheapest upgrades I've installed to date.
Warren Hill
N867PA Mesa, AZ
270.78 KB |
4903 Time(s) |
alikatz(at)mbay.net Guest
Posted: Sun Jan 10, 2010 3:13 pm Post subject: CJ-6A LED replacement bulbs |
Thanks for the Post Warren...
tigeryak18t
Joined: 26 Sep 2009 Posts: 233 Location: PARIS FRANCE
Posted: Mon Jan 11, 2010 2:08 am Post subject: CJ-6A LED replacement bulbs |
Hi Larry,
thank for the post. Do you know if the lights are the same on the 52 or the 18T.
It looks like!!
regards
Didier
2010/1/10 Warren Hill <k7wx(at)earthlink.net (k7wx(at)earthlink.net)>
| Quote: | Gentlemen,
Warren Hill
N867PA Mesa, AZ
Didier BLOUZARD
didier.blouzard(at)gmail.com (didier.blouzard(at)gmail.com)
0624243672
[img]data:image/png;base64,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%3D[/img] [quote][b]
_________________ Didier Tiger YAK18T
Member of Commemorative Air Force
French Wing |
Posted: Mon Jan 11, 2010 5:12 am Post subject: CJ-6A LED replacement bulbs |
Dider,
Do not know if they are the same.
Warren Hill
N867PA Mesa, AZ
On Jan 11, 2010, at 3:07 AM, Didier Blouzard wrote:
[quote]Hi Larry,
It looks like!!
regards
Didier
| Quote: | Gentlemen,
Warren Hill
N867PA Mesa, AZ
Didier BLOUZARD
0624243672
[img]data:image/png;base64,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%3D[/img] | Quote: |
href="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List
| [b]
tigeryak18t
Posted: Mon Jan 11, 2010 5:36 am Post subject: CJ-6A LED replacement bulbs |
thanks Larry,
then I will check by myself.
Price is not significant in this case......
thx a lot
regards
Didier
2010/1/11 Warren Hill <k7wx(at)earthlink.net (k7wx(at)earthlink.net)>
| Quote: | Dider,
Warren Hill
N867PA Mesa, AZ
Hi Larry,
It looks like!!
regards
Didier
| Quote: | Gentlemen,
Warren Hill
N867PA Mesa, AZ
Didier BLOUZARD
0624243672
[img][/img]
et="_blank">http://www.matronics.com/Navigator?Yak-List
tp://forums.matronics.com
Didier BLOUZARD
0624243672
French Wing |
