CJ-6A LED replacement bulbs
k7wx(at)earthlink.net
PostPosted: Sun Jan 10, 2010 8:56 am    Post subject: CJ-6A LED replacement bulbs Reply with quote
Gentlemen,
Larry Pine and I have been outfitting my CJ for night flight with wing strobes and a red strobe for the top of the rudder. We were also planning on replacing that anemic, barely visible flashlight bulb on the tail with a LED position light / strobe from Aveo Engineering.
Last week on the Internet I came across what appeared to be an exact LED drop-in replacement for the Chinese bulb. It's 24 volt, LED cluster that has the same bayonet base, draws very little current, is astonishingly bright and basically lasts forever. This would also be a direct, drop-in replacement for those three lights on the nose gear and mains. This particular LED arrangement has viewing angle of 90 degrees, so it is brightest when viewed mostly from straight ahead. Here is where I found this:
www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=%2Fother_bulbs.htm
The web site navigation is a little confusing and flat-footed, but basically what you would be looking for is the 24 volt, white, dual contact, single intensity, 15 mm 1142 bayonet base. The ordering designation is: 1142-W15-24V White LED bulb - 24V.
A few days ago my order arrived and last night we tested the landing gear and tail lights in place. Wow!
I've attached a picture of what this looks like installed. For about six bucks each they are the cheapest upgrades I've installed to date.
Warren Hill
N867PA Mesa, AZ
 Filesize:  270.78 KB
 Viewed:  4852 Time(s)
alikatz(at)mbay.net
PostPosted: Sun Jan 10, 2010 3:13 pm    Post subject: CJ-6A LED replacement bulbs Reply with quote
Thanks for the Post Warren...
tigeryak18t
PostPosted: Mon Jan 11, 2010 2:08 am    Post subject: CJ-6A LED replacement bulbs Reply with quote
Hi Larry,
thank for the post. Do you know if the lights are the same on the 52 or the 18T.
It looks like!!
regards
Didier
2010/1/10 Warren Hill <k7wx(at)earthlink.net (k7wx(at)earthlink.net)>
Gentlemen,
Warren Hill
N867PA  Mesa, AZ
Didier BLOUZARD
didier.blouzard(at)gmail.com (didier.blouzard(at)gmail.com)
0624243672
[img]data:image/png;base64,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%3D[/img] [quote][b]
Didier Tiger YAK18T
Member of Commemorative Air Force
French Wing
PostPosted: Mon Jan 11, 2010 5:12 am    Post subject: CJ-6A LED replacement bulbs Reply with quote
Dider,
Do not know if they are the same.
Warren Hill
N867PA Mesa, AZ
On Jan 11, 2010, at 3:07 AM, Didier Blouzard wrote:
[quote]Hi Larry,
It looks like!!
regards
Didier
Gentlemen,
Warren Hill
N867PA Mesa, AZ
Didier BLOUZARD
0624243672
href="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List
tigeryak18t
PostPosted: Mon Jan 11, 2010 5:36 am    Post subject: CJ-6A LED replacement bulbs Reply with quote
thanks Larry,
then I will check by myself.
Price is not significant in this case......
thx a lot
regards
Didier
2010/1/11 Warren Hill <k7wx(at)earthlink.net (k7wx(at)earthlink.net)>
Dider,
Warren Hill
N867PA  Mesa, AZ
Hi Larry,
It looks like!!
regards
Didier
Gentlemen,
Warren Hill
N867PA  Mesa, AZ
Didier BLOUZARD
0624243672
[img][/img]
et="_blank">http://www.matronics.com/Navigator?Yak-List
tp://forums.matronics.com
Didier BLOUZARD
0624243672
Didier Tiger YAK18T
French Wing
