Pitot test rig (was Pitot cover)
carl.froehlich(at)verizon
PostPosted: Sun Jul 05, 2009 8:53 am    Post subject: Pitot test rig (was Pitot cover) Reply with quote
Before first flight, or anytime you have a doubt about airspeed indication,
you can do a simple but accurate check.
Photo attached on the pitot test rig I made. While the one photo is with
the airspeed indicator out of the plane, normal is to attach the tubing
directly to the pitot tube (electrical tape makes a good seal) and test the
entire system for accuracy and leaks. I used a standard blood pressure bulb
to pump up the water level - it does not take much. Also attached is the
conversion scale to put under the level tube to read out directly into
knots. As airspeed is strictly related to differential pressure, there are
no corrections for temperature, atmospheric pressure or altitude.
Carl Froehlich
RV-8A (500 hrs)
RV-10 (fuselage)
 Filesize:  93.35 KB
 Viewed:  7165 Time(s)
 Filesize:  87.08 KB
Manometer.pdf
 Filename:  Manometer.pdf
 Filesize:  17.53 KB
 Downloaded:  644 Time(s)
KiloPapa
PostPosted: Sun Jul 05, 2009 6:21 pm    Post subject: Pitot test rig (was Pitot cover) Reply with quote
Nice post!
Kevin
40494
tail/empennage
Kevin
40494
orchidman
PostPosted: Mon Jul 06, 2009 3:51 am    Post subject: Re: Pitot test rig (was Pitot cover) Reply with quote
I built and used the one from the EZ people at:
http://www.iflyez.com/manometer.shtml
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
Lenny Iszak
PostPosted: Tue Jul 07, 2009 6:23 pm    Post subject: Re: Pitot test rig (was Pitot cover) Reply with quote
I wonder if I could use different type of tubing for the manometer rig. I'd like to use the tubing supplied for the brakes. Would that change the readings?
Lenny
Bob Turner
PostPosted: Wed Jul 08, 2009 10:03 am    Post subject: Re: Pitot test rig (was Pitot cover) Reply with quote
Only the difference in the heights of the liquid matter, not the diameter of the tubing. And it's vertical height that matters, in case the rig itself is not vertical. The formula is: Pressure equals density (of the liquid) times the acceleration of gravity times the vertical height difference.
Bob Turner
RV-10 QB
Lenny Iszak
PostPosted: Wed Jul 08, 2009 10:08 am    Post subject: Re: Pitot test rig (was Pitot cover) Reply with quote
Thanks Bob. It helps to know how it works.
I tried it last night using the brake tubing and it worked great.
Needed it to calibrate an electronic pressure sensor.
Lenny
