Posted: Sun Jul 05, 2009 8:53 am Post subject: Pitot test rig (was Pitot cover) |
Before first flight, or anytime you have a doubt about airspeed indication,
you can do a simple but accurate check.
Photo attached on the pitot test rig I made. While the one photo is with
the airspeed indicator out of the plane, normal is to attach the tubing
directly to the pitot tube (electrical tape makes a good seal) and test the
entire system for accuracy and leaks. I used a standard blood pressure bulb
to pump up the water level - it does not take much. Also attached is the
conversion scale to put under the level tube to read out directly into
knots. As airspeed is strictly related to differential pressure, there are
no corrections for temperature, atmospheric pressure or altitude.
Carl Froehlich
RV-8A (500 hrs)
RV-10 (fuselage)
93.35 KB |
7163 Time(s) |
87.08 KB |
7163 Time(s) |
 Download |
| Filename: |
Manometer.pdf |
17.53 KB |
| Downloaded: |
644 Time(s) |
KiloPapa
Joined: 24 May 2006 Posts: 142 Location: Pearblossom, CA
Posted: Sun Jul 05, 2009 6:21 pm Post subject: Pitot test rig (was Pitot cover) |
Nice post!
Kevin
40494
tail/empennage
_________________ Kevin
40494
do not archive |
orchidman
Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
Posted: Mon Jul 06, 2009 3:51 am Post subject: Re: Pitot test rig (was Pitot cover) |
I built and used the one from the EZ people at:
http://www.iflyez.com/manometer.shtml
_________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
Lenny Iszak
Posted: Tue Jul 07, 2009 6:23 pm Post subject: Re: Pitot test rig (was Pitot cover) |
I wonder if I could use different type of tubing for the manometer rig. I'd like to use the tubing supplied for the brakes. Would that change the readings?
Lenny
Bob Turner
Posted: Wed Jul 08, 2009 10:03 am Post subject: Re: Pitot test rig (was Pitot cover) |
Only the difference in the heights of the liquid matter, not the diameter of the tubing. And it's vertical height that matters, in case the rig itself is not vertical. The formula is: Pressure equals density (of the liquid) times the acceleration of gravity times the vertical height difference.
_________________ Bob Turner
RV-10 QB |
Lenny Iszak
Posted: Wed Jul 08, 2009 10:08 am Post subject: Re: Pitot test rig (was Pitot cover) |
Thanks Bob. It helps to know how it works.
I tried it last night using the brake tubing and it worked great.
Needed it to calibrate an electronic pressure sensor.
Lenny
