WurlyBird
Joined: 16 May 2008 Posts: 207 Location: North Pole, Alaska
lcfitt(at)sbcglobal.net Guest
Posted: Sat Mar 21, 2009 4:01 pm Post subject: Rudder trim tab |
James,
I did exactly as you suggest and it worked well.
Lowell
WurlyBird
Posted: Sat Mar 21, 2009 5:23 pm Post subject: Re: Rudder trim tab |
Lowell, what size tab did you use and what were it's dimensions? What is it made of? Have any pictures you could send me?
Thanks a lot
James
_________________ James
Kitfox 3 / 582 / 70" IVO 2 blade GA
50 hrs on the 582 swapping for HKS 700E and Avid Cowl. |
Dick Maddux
Posted: Sun Mar 22, 2009 4:39 am Post subject: Rudder trim tab |
James,
This is the way I did it. Just a small aluminum plate I attached with 4 #6 or #4 screws (can't remember which) so that I could remove it or increase the tab size if I needed to. I had to adjust the bend a couple of times but now it is spot on (as the British would say). I have a picture from my files albeit not very good.
Dick Maddux
Fox 4
Pensacola,Fl
Feeling the pinch at the grocery store? Make dinner for $10 or less.
343.39 KB |
8041 Time(s) |
Posted: Sun Mar 22, 2009 6:54 am Post subject: Rudder trim tab |
Mike,
I checked my picture files and found nothing. Dick Maddox's picture is
about like mine and in the same location. It is aluminum and likely .025.
Lowell
pwmac(at)sisna.com Guest
Posted: Sun Mar 22, 2009 7:52 am Post subject: Rudder trim tab |
I saw a simple fix. It was a small triangular piece glued to the
rudder. Easy to change and fine tune. No drilling etc. It appeared to
be white plastic.
I wonder if it lasted?
Paul
Lynn Matteson
Posted: Sun Mar 22, 2009 8:09 am Post subject: Rudder trim tab |
Here's how I did mine, James. Take the aluminum plate and "forge" it
over a scrap piece of tubing or a 3/8" extension, and you'll be able
to get the pop rivets into 2 different rows around the trailing edge
tubing of the rudder. This will allow for a MUCH stronger attachment
than if you just ran a straight row of rivets. If you don't...and you
do much altering of the tab.....you'll run the risk of bending the
rivets and the tab will become loose. I attached mine with aluminum
rivets so I could drill the out if I decided on another method. My
aluminum rivets haven't loosened in the 500 or so hours since I
installed it.
Lynn Matteson
Jabiru 2200, #2062, 618.4 hrs
Sensenich 62x46
Status: flying
On Mar 21, 2009, at 7:24 PM, WurlyBird wrote:
<james.t.trizzino(at)us.army.mil>
I am wondering if anybody has made a rudder trim tab and would like
to share how they did it? I know it will only be really accurate
at one airspeed and I am okay with that since I spend a lot more
time at "cruise" then throttled back for a landing.
I assume it is as simple as riveting a sheet of steel or aluminum
to the rudder and then just experimenting with it's deflection.
Any input?
Did I mention I soloed the Kitfox today? I mean on this thread of
course.
James
Kitfox 3 / 582 / GSC prop
4 hrs of instruction and climbing (I solo tomorrow)
http://forums.matronics.com/viewtopic.php?p 35554#235554
403.12 KB |
8029 Time(s) |
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
rliebmann(at)comcast.net Guest
Posted: Sun Mar 22, 2009 8:19 am Post subject: Rudder trim tab |
I made my rudder trim a cockpit adjustable one and am happy with it. If
anyone wants more info on how it is made, just e-mail me on or off list.
Ron rliebmann(at)comcast.net
Sent: Sunday, March 22, 2009 10:51 AM
Subject: Re: Re: Rudder trim tab
I saw a simple fix. It was a small triangular piece glued to the rudder.
Easy to change and fine tune. No drilling etc. It appeared to be white
plastic.
Paul
302.48 KB |
8029 Time(s) |
309.97 KB |
8029 Time(s) |
Lynn Matteson
Posted: Sun Mar 22, 2009 9:06 am Post subject: Rudder trim tab |
Hi Ron-
The question is, how are you gonna fly your giant RC model now that
you borrowed those control horns from it? : )
Lynn Matteson
Sensenich 62x46
Status: flying
On Mar 22, 2009, at 12:13 PM, Ron Liebmann wrote:
| Quote: | I made my rudder trim a cockpit adjustable one and am happy with
it. If anyone wants more info on how it is made, just e-mail me on
or off list.
N369LM |
patreilly43(at)hotmail.co Guest
Posted: Mon Mar 23, 2009 10:10 am Post subject: Rudder trim tab |
Dick C The light blue lines striping the edge of the dark blue on your plane C is that tape or paint?
Pat Reilly
Mod 3 582 Rebuild
Rockford CIL
Date: Sun C 22 Mar 2009 08:36:41 -0400
Subject: Re: Rudder trim tab
James C
Dick Maddux
Fox 4
Pensacola CFl
