Rudder trim tab
WurlyBird
PostPosted: Sat Mar 21, 2009 3:24 pm    Post subject: Rudder trim tab Reply with quote
I am wondering if anybody has made a rudder trim tab and would like to share how they did it? I know it will only be really accurate at one airspeed and I am okay with that since I spend a lot more time at "cruise" then throttled back for a landing.
I assume it is as simple as riveting a sheet of steel or aluminum to the rudder and then just experimenting with it's deflection. Any input?
Did I mention I soloed the Kitfox today? I mean on this thread of course. Very Happy
James
Kitfox 3 / 582 / 70" IVO 2 blade GA
50 hrs on the 582 swapping for HKS 700E and Avid Cowl.
lcfitt(at)sbcglobal.net
PostPosted: Sat Mar 21, 2009 4:01 pm    Post subject: Rudder trim tab Reply with quote
James,
I did exactly as you suggest and it worked well.
Lowell
WurlyBird
PostPosted: Sat Mar 21, 2009 5:23 pm    Post subject: Re: Rudder trim tab Reply with quote
Lowell, what size tab did you use and what were it's dimensions? What is it made of? Have any pictures you could send me?
Thanks a lot
James
James
Dick Maddux
PostPosted: Sun Mar 22, 2009 4:39 am    Post subject: Rudder trim tab Reply with quote
James,
This is the way I did it. Just a small aluminum plate I attached with 4 #6 or #4 screws (can't remember which) so that I could remove it or increase the tab size if I needed to. I had to adjust the bend a couple of times but now it is spot on (as the British would say). I have a picture from my files albeit not very good.
      Dick Maddux
      Fox 4
      Pensacola,Fl
Feeling the pinch at the grocery store? Make dinner for $10 or less.
 Filesize:  343.39 KB
 Viewed:  7954 Time(s)
PostPosted: Sun Mar 22, 2009 6:54 am    Post subject: Rudder trim tab Reply with quote
Mike,
I checked my picture files and found nothing. Dick Maddox's picture is
about like mine and in the same location. It is aluminum and likely .025.
Lowell
pwmac(at)sisna.com
PostPosted: Sun Mar 22, 2009 7:52 am    Post subject: Rudder trim tab Reply with quote
I saw a simple fix. It was a small triangular piece glued to the
rudder. Easy to change and fine tune. No drilling etc. It appeared to
be white plastic.
I wonder if it lasted?
Paul
Lynn Matteson
PostPosted: Sun Mar 22, 2009 8:09 am    Post subject: Rudder trim tab Reply with quote
Here's how I did mine, James. Take the aluminum plate and "forge" it
over a scrap piece of tubing or a 3/8" extension, and you'll be able
to get the pop rivets into 2 different rows around the trailing edge
tubing of the rudder. This will allow for a MUCH stronger attachment
than if you just ran a straight row of rivets. If you don't...and you
do much altering of the tab.....you'll run the risk of bending the
rivets and the tab will become loose. I attached mine with aluminum
rivets so I could drill the out if I decided on another method. My
aluminum rivets haven't loosened in the 500 or so hours since I
installed it.
Lynn Matteson
Jabiru 2200, #2062, 618.4 hrs
Sensenich 62x46
Status: flying
On Mar 21, 2009, at 7:24 PM, WurlyBird wrote:
<james.t.trizzino(at)us.army.mil>
Any input?
course. Very Happy
James
Kitfox 3 / 582 / GSC prop
4 hrs of instruction and climbing (I solo tomorrow)
http://forums.matronics.com/viewtopic.php?p 35554#235554
 Filesize:  403.12 KB
 Viewed:  7942 Time(s)
Lynn
Kitfox IV-Jabiru 2200
N369LM
rliebmann(at)comcast.net
PostPosted: Sun Mar 22, 2009 8:19 am    Post subject: Rudder trim tab Reply with quote
I made my rudder trim a cockpit adjustable one and am happy with it. If
anyone wants more info on how it is made, just e-mail me on or off list.
Ron rliebmann(at)comcast.net
Sent: Sunday, March 22, 2009 10:51 AM
Subject: Re: Re: Rudder trim tab
I saw a simple fix. It was a small triangular piece glued to the rudder.
Easy to change and fine tune. No drilling etc. It appeared to be white
plastic.
Paul
 Filesize:  302.48 KB
 Filesize:  309.97 KB
Lynn Matteson
PostPosted: Sun Mar 22, 2009 9:06 am    Post subject: Rudder trim tab Reply with quote
Hi Ron-
The question is, how are you gonna fly your giant RC model now that
you borrowed those control horns from it? : )
Lynn Matteson
Sensenich 62x46
Status: flying
it. If anyone wants more info on how it is made, just e-mail me on
or off list.
Lynn
N369LM
patreilly43(at)hotmail.co
PostPosted: Mon Mar 23, 2009 10:10 am    Post subject: Rudder trim tab Reply with quote
Dick C The light blue lines striping the edge of the dark blue on your plane C is that tape or paint?
Pat Reilly
Mod 3 582 Rebuild
Rockford CIL
Date: Sun C 22 Mar 2009 08:36:41 -0400
Subject: Re: Rudder trim tab
James C
                                                 Dick Maddux
                                                 Fox 4
                                                 Pensacola CFl
