naumuk(at)alltel.net Guest
Posted: Thu Dec 25, 2008 4:02 pm Post subject: Gettin' close |
All-
Some said yes, some said no. I went with fuse blocks mainly to save a batch of time drilling and soldering.
The question is, where do you put them? What do they look like in a panel mount?
Bill Naumuk
Townville, Pa.
HDS 601MG/Corvair 95%
psm(at)att.net Guest
Posted: Thu Dec 25, 2008 4:17 pm Post subject: Gettin' close |
Hi Bill,
I put my fuse blocks on the horizontal channel that runs from the firewall to the instrument panel. I figured I didn't need or want access to the fuses in flight. Indeed, after a life time of driving cars and flying planes I have never had a fuse failure or circuit breaker trip.
I also built large inspection panels in the forward top skin. This allows easy access to the fuses and also to the back of the instrument panel.
Paul
XL getting close
At 04:01 PM 12/25/2008, you wrote:
[quote]All-
Bill Naumuk
Townville, Pa.
Posted: Thu Dec 25, 2008 4:24 pm Post subject: Gettin' close |
Paul-
That's food for thought.
Bill
Posted: Thu Dec 25, 2008 4:28 pm Post subject: Gettin' close |
On the Van’s RV-12 they just mounted the block behind the panel with a nice trim piece:
http://www.vansaircraft.com/images/RV-12/N412RV/switch_fuse.jpg
Given the lack of visible mounting hardware I’d say they mounted the actual fuse block on a hidden bracket.
I’m not wild about having the fuses exposed where they could get knocked out of the block. My plan is to recess the whole block and cover it with a hinged door. If I use the Waytek LED fuses I’ll make the door transparent.
Others have mounted the fuse block on a hinged panel that folded up under the panel. If you follow the “fuse” philosophy then you don’t plan on messing with fuses in flight – just “fly the plane”
-- Craig
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Bill Naumuk
Sent: Thursday, December 25, 2008 5:01 PM
To: zenith list
Subject: Gettin' close
All-
Bill Naumuk
Townville, Pa.
| Quote: | | http://www.matronics.com/contribution | 01234567890123
steerr(at)bellsouth.net Guest
Posted: Thu Dec 25, 2008 4:35 pm Post subject: Gettin' close |
I also went with fuse blocks. I put them on a horizontal panel that's
hinged to the bottom of the instrument panel, with two pull pins on the
other side so they can easily be dropped down for fuse replacement.
Bill
Bill Naumuk wrote:
| Quote: | All-
a panel mount?
Bill Naumuk
Townville, Pa.
Checked by AVG - http://www.avg.com
leinad
Joined: 19 Sep 2006 Posts: 283 Location: Central Virginia
Posted: Fri Dec 26, 2008 7:31 am Post subject: Re: Gettin' close |
Bill
I put my fuse block by my right knee. Here's a link to a photo.
http://daniel.dempseyfamily.us/zodiac/electronics/fusebus.htm
Dan
601xl/corvair plans build
_________________ Scratch building XL with Corvair Engine |
Posted: Fri Dec 26, 2008 8:25 am Post subject: Gettin' close |
Dan-
This is my plan B. I have to find out how much room I wind up with
around the radio stack.
Bill
Posted: Fri Dec 26, 2008 8:34 am Post subject: Gettin' close |
Dan-
The more I look at your setup, the more I like it. I'll have to see what
kind of room the fuse blocks will take up when they come in.
Bill
jlatimer1(at)cox.net Guest
Posted: Fri Dec 26, 2008 8:49 pm Post subject: Gettin' close |
Bill,
This is what I did. I found a fuse block that had the feed wires in the
back and fuses in the front. It has two buses and is smaller than the
fuse block sold on the B&C Specialty web site.
Just another option.
Jerry
also getting close
On Fri, Dec 26, 2008 at 9:42 PM , Bill Naumuk wrote:
Dan-
Bill
114.79 KB |
500 Time(s) |
99.27 KB |
504 Time(s) |
