Airfilter problem
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Rocket-List
jrstone(at)insightbb.com
PostPosted: Thu Oct 02, 2008 6:39 am    Post subject: Airfilter problem Reply with quote
HR guys,
As per John Harmon's recommendation, I have been using a UNI filter UP-6300 ast motorcycle filter. Not only do I not like the looks of the thing but it lays on the inside of the cowl and has to deform a bit to do that, it also is wearing where the cuff slides over the Y-valve. I am using John's intake Y valve and the angle of the filter side may not be quite right. Has anyone had this problem and or have a solution? Perhaps going to a K&N filter will do it, any model numbers would help my search for a solution.
Jim Stone
- The Matronics Rocket-List Email Forum -
http://www.matronics.com/Navigator?Rocket-List
fairlea(at)amtelecom.net
PostPosted: Thu Oct 02, 2008 6:53 am    Post subject: Airfilter problem Reply with quote
Jim
I had a similar set up on my second Harmon. I used a conical K&N filter that had a bit of an offset in the attach flange. Part # RB 091. It did touch the starter and I put a big gob of RTV at the point of contact. It also tended to touch the cowling but never seemed to cause and damage. I do not see any reason why you could not squeeze a bit to get more clearance. It is a nice simple system.
Tom Martin
From: owner-rocket-list-server(at)matronics.com [mailto:owner-rocket-list-server(at)matronics.com] On Behalf Of Jim Stone
Sent: October 2, 2008 10:39 AM
To: rocket-list(at)matronics.com
Subject: Airfilter problem
HR guys,
Jim Stone
Checked by AVG.
Checked by AVG.
PostPosted: Thu Oct 02, 2008 7:02 am    Post subject: Airfilter problem Reply with quote
Thanks Tom,
I'm heading to the store now.
Jim Stone
PostPosted: Mon Oct 06, 2008 2:43 pm    Post subject: Airfilter problem Reply with quote
Hey Tom,
Been doing some research on filters. Your part number was close but I came up with RB-0910 which is 5 inches high, and an RB-0900 which is 4 inches in height. Do you think the 4 inch high one would work better, i.e., less contact with cowl and starter?
I also found some cone shapes which are about 5 inches high but have 3 1/2 inch diameter top, perhaps that would work, what do you think?
I wish my cowl was off so I could take some measurements. I just put it back on Sunday after the annual inspection.
Jim Stone
Louisville KY
smokyray(at)rocketmail.co
PostPosted: Mon Oct 06, 2008 3:43 pm    Post subject: Airfilter problem Reply with quote
Jim,
I'm using a K&N cone filter on my Harmon intake w/bypass, 3.5 inch top. Works great with my Skytech starter and clears the cowl with 2" to spare. Suprisingly, K&N had compettive prices...
Smokey
HR2
PostPosted: Mon Oct 06, 2008 5:13 pm    Post subject: Airfilter problem Reply with quote
Smokey,
If you happen to have that K&N model number, you might save me from ordering the wrong one.
Jim
HR2
PostPosted: Tue Oct 07, 2008 9:09 am    Post subject: Airfilter problem Reply with quote
Do my best sir...
Smokey
--- On Tue, 10/7/08, Jim Stone <jrstone(at)insightbb.com> wrote:
[quote]From: Jim Stone <jrstone(at)insightbb.com>
Subject: Re: Airfilter problem
Date: Tuesday, October 7, 2008, 1:12 AM
#yiv1338319602 DIV { MARGIN:0px;} Smokey,
Jim
HR2
PostPosted: Tue Oct 07, 2008 11:25 am    Post subject: Airfilter problem Reply with quote
Jim,
I am 99% sure this is the one. I will pull my cowling and confirm it next week, hope it helps.
Smokey
HR2
http://www.knfilters.com/search/product.aspx?Prod=RF-1039
--- On Tue, 10/7/08, Smoky Ray <smokyray(at)rocketmail.com> wrote:
[quote]From: Smoky Ray <smokyray(at)rocketmail.com>
Date: Tuesday, October 7, 2008, 5:09 PM
Do my best sir...
Smokey
#yiv68663337 #yiv1338319602 DIV { MARGIN:0px;} Smokey,
Jim
HR2
PostPosted: Tue Oct 07, 2008 1:13 pm    Post subject: Airfilter problem Reply with quote
Thanks Smokey,
Please don't pull that cowl for me. I await your confirmation. BTW, send me a pic of yours so I can put a name to a Rocket.
Jim Stone
PS Attached is a pic of my ride
 Filesize:  336.57 KB
 Viewed:  587 Time(s)
Lee Logan
PostPosted: Wed Oct 08, 2008 1:54 pm    Post subject: Airfilter problem Reply with quote
Jim: Your Rocket continues to amaze... It's really beautiful!
Lee...
PostPosted: Wed Oct 08, 2008 2:05 pm    Post subject: Airfilter problem Reply with quote
Thanks Lee!
PostPosted: Tue Oct 14, 2008 6:12 pm    Post subject: Airfilter problem Reply with quote
Hey Smokey,
Did you happen to pull your cowl and check which filter you have?
Jim
PostPosted: Wed Oct 15, 2008 4:44 am    Post subject: Airfilter problem Reply with quote
Hi Jim,
Not yet, but I will next week. Are you using the Harmon air intake system?
Smokey
Date: Tuesday, October 14, 2008, 7:11 PM
Hey Smokey,
Jim
PostPosted: Wed Oct 15, 2008 5:01 am    Post subject: Airfilter problem Reply with quote
Yes,
Jim
russ(at)wernerworld.com
PostPosted: Wed Oct 15, 2008 7:07 am    Post subject: Airfilter problem Reply with quote
If I start my annual this weekend, I'll have mine off also and can give
you a K&N part number.
Russ
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Rocket-List All times are GMT - 8 Hours
