topglock(at)cox.net Guest
Posted: Wed Jul 02, 2008 4:41 pm Post subject: A question on composits |
Fellow Europaphiles,
As some of you know, after seeing a modified Europa cowl at Sun'n'fun, I
decided to take on the job of redesigning my cowl, to see what I could
gain. I've successfully made a mold from my current cowl, and want to
make a new cowl. One that I can cut up and modify. My question is,
what is the best cloth and resin to use to build the cowl? Any ideas on
what is used in the stock Europa cowl and how many layers of cloth are
used? I considering having a new exhaust system designed and built to
save space and weight. I will probably be moving the coolers to
accommodate the new exhaust. I've just got this nagging idea, in my
head that a well designed cowl will improve cooling, air speed, weight
and appearance. Am I wrong?:
Jeff - Baby Blue - Looking at getting a nose job...
paul.the.aviator(at)gmail Guest
Posted: Wed Jul 02, 2008 5:26 pm Post subject: A question on composits |
Hi Jeff,
Would you happen to have any photographs of the cowl design that your
trying to build ?
Thanks, Paul
Posted: Thu Jul 03, 2008 6:40 am Post subject: A question on composits |
Paul,
Nothing, yet, but I'm leaning toward something along the lines of the
Lanceair 235. There's a cover shot of one in the July '08 Kitplanes.
The new cowl would, of course, be minus the carb intake underneath.
This is probably going to be a lengthy project, as I want to fly several
variations to compare the results. When it's finished, the design will
certainly be offered to the list.
Jeff - Baby Blue
Paul McAllister wrote:
Hi Jeff,
trying to build ?
Thanks, Paul
Checked by AVG.
karelvranken(at)hotmail.c Guest
Posted: Thu Jul 03, 2008 1:37 pm Post subject: A question on composits |
Jeff,
In attachment my concept of cowling and inner radiator duct.
Best regards,
Karel Vranken
179.01 KB |
442 Time(s) |
170.01 KB |
454 Time(s) |
172.01 KB |
470 Time(s) |
Posted: Thu Jul 03, 2008 2:47 pm Post subject: A question on composits |
Hi Karel,
Nice looking modification. Do you have the radiators directly behind
each other or to you have the rear one dropped down by 40 mm ?
Paul
On Thu, Jul 3, 2008 at 4:28 PM, karelvranken <karelvranken(at)hotmail.com> wrote:
[quote] Jeff,
Best regards,
Karel Vranken
Posted: Thu Jul 03, 2008 3:13 pm Post subject: A question on composits |
Karel,
Great stuff! Thanks...
Jeff - Baby Blue
karelvranken wrote:
[quote] Jeff,
Best regards,
Karel Vranken
Posted: Thu Jul 03, 2008 3:36 pm Post subject: A question on composits |
Paul,
I didn't use the original cubic radiator for the coolant. The surface is
greater and only 1,5" thick with the same contents. I didn't need to lower
the oil radiator. Using the Evans coolant I notice normally in cruise 100°C
for oil and 110°C for coolant. In hot summer like last year in Italy by 41°C
on the tarmac the temperatures rose with 10°C. Oil is changed every 50 hours
and I use actually Shell Advance 4. Next I will change to the Aeroshell
Sport plus. I always use Mogas 98 without alcohol.
Best regards,
Karel Vranken, F-PKRL 912 ULS Airmaster CSU.
fklein(at)orcasonline.com Guest
Posted: Thu Jul 03, 2008 9:16 pm Post subject: A question on composits |
On Wednesday, Jul 2, 2008, at 17:38 US/Pacific, Rman wrote:
| Quote: | I've successfully made a mold from my current cowl, and want to make
a new cowl. One that I can cut up and modify. My question is, what
used?
Jeff...great idea...
If memory serves, I seem to recall reading that the stock cowl is made
of FG and vinyl-ester resin; heat resistance and cure time may be the
reasons, but by all means get more info from an authoritative source. I
do know that Alex Bowman used vinyl-ester resin on his custom cowl, but
I'm not sure of the reasoning behind the decision to use it.
If you do make up a production mold, my local composite guru recommends
"molding cloth" which is a fairly heavy tight weave; for my special
wingroot fairing/fillet molds, I've used four layers of Acft Spruce P/N
7781-50...it's a bitch to wet out w/ Aeropoxy and I've had to really
work at getting out the air bubbles, but the surface is pretty smooth
when cured. Since the mold is long and has no tight radii, I've had to
add an armature of triangulated tongue depressor sticks to maintain the
exact desired shape, but hey, with no real experience behind me, I'm
learning as I go.
| Quote: | I've just got this nagging idea, in my head that a well designed cowl
will improve cooling, air speed, weight and appearance. Am I wrong?:
Though I'm not sure it's fair to say that Baby Blue needs a nose job, I
also seem to recall comments on this forum to the effect that the stock
XS cowl was designed under some time/deadline pressure and that the
results were less than optimum. IMHO...and it's just opinion...cooling
drag may be higher than need be...and the aesthetics of the radiator
inlet can be much improved. I've always admired the Suncoast/Jab
cowling on John Lawton's ship with its Mooney/Lancair-style inlets, and
I like Karel's modifications as well.
Go for it Jeff,
Fred
believed to be clean.
