Posted: Sat Apr 26, 2008 3:56 pm Post subject: 2 Vs 3 blade |
I tried the archives but no joy. Is there any side-by-side in-the-air
data available on the 2 or 3 blade props??? I seem to recall some
comments about efficiency ..... but don't recall the facts (if there are
any) or which way the discussion went.
Any takers???
Linn ...... decision looming
rv10builder(at)verizon.ne Guest
Posted: Sat Apr 26, 2008 6:23 pm Post subject: 2 Vs 3 blade |
Pascal
From: "linn Walters" <pitts_pilot(at)bellsouth.net>
Sent: Saturday, April 26, 2008 4:54 PM
To: "RV-10" <rv10-list(at)matronics.com>
Subject: 2 Vs 3 blade
Any takers???
240.93 KB |
366 Time(s) |
dc71(at)netspace.net.au Guest
Posted: Sat Apr 26, 2008 6:27 pm Post subject: 2 Vs 3 blade |
Comparison published in the RVator - 5th issue 2005. I've attached the
relevant pages.
Indran
On 27/04/2008, at 7:54 AM, linn Walters wrote:
air data available on the 2 or 3 blade props??? I seem to recall
some comments about efficiency ..... but don't recall the facts (if
there are any) or which way the discussion went.
Any takers???
RVator5-05p6-8.pdf |
425.51 KB |
414 Time(s) |
3edcft6(at)cox.net Guest
Posted: Sun Apr 27, 2008 10:45 am Post subject: 2 Vs 3 blade |
linn Walters wrote:
| Quote: | I tried the archives but no joy. Is there any side-by-side in-the-air
I can't site the source but it is from a report done by NASA that
determined that a perfect 3 blade is "slightly" less efficient than a
perfect 2 blade. However in practice, other variables, such as engine,
airframe, altitude, cruise speed, etc, will have more of an effect than
the theoretical difference in efficiency between a 2 and 3 blade prop.
With all the variables beyond our control it is very difficult to
determine what prop would work the best for any given situation by
comparing various reports from various builders. What I would really
like to see is Van's (or anybody else for that matter) build 2 identical
planes. Do side by side flight tests to see how close they are in the
air for a base line. Then start testing various changes in side by side
tests. Seems to me that is the best way to get data that is very useful.
Chris W
KE5GIX
"Protect your digital freedom and privacy, eliminate DRM,
learn more at http://www.defectivebydesign.org/what_is_drm"
Ham Radio Repeater Database.
http://hrrdb.com
lessdragprod(at)aol.com Guest
Posted: Sun Apr 27, 2008 11:23 am Post subject: 2 Vs 3 blade |
Why build two RV-10s? When we could fly two different propellers on the same RV-10.
IMHO, it will take more time to get the flight test data than it will take to change the propellers.
Jim Ayers
