2 Vs 3 blade
pitts_pilot(at)bellsouth.
PostPosted: Sat Apr 26, 2008 3:56 pm    Post subject: 2 Vs 3 blade Reply with quote
I tried the archives but no joy. Is there any side-by-side in-the-air
data available on the 2 or 3 blade props??? I seem to recall some
comments about efficiency ..... but don't recall the facts (if there are
any) or which way the discussion went.
Any takers???
Linn ...... decision looming
rv10builder(at)verizon.ne
PostPosted: Sat Apr 26, 2008 6:23 pm    Post subject: 2 Vs 3 blade Reply with quote
Pascal
From: "linn Walters" <pitts_pilot(at)bellsouth.net>
Sent: Saturday, April 26, 2008 4:54 PM
To: "RV-10" <rv10-list(at)matronics.com>
Subject: 2 Vs 3 blade
Any takers???
 Filesize:  240.93 KB
 Viewed:  289 Time(s)
dc71(at)netspace.net.au
PostPosted: Sat Apr 26, 2008 6:27 pm    Post subject: 2 Vs 3 blade Reply with quote
Comparison published in the RVator - 5th issue 2005. I've attached the
relevant pages.
Indran
air data available on the 2 or 3 blade props??? I seem to recall
some comments about efficiency ..... but don't recall the facts (if
there are any) or which way the discussion went.
Any takers???
RVator5-05p6-8.pdf
 Filename:  RVator5-05p6-8.pdf
 Filesize:  425.51 KB
 Downloaded:  332 Time(s)
3edcft6(at)cox.net
PostPosted: Sun Apr 27, 2008 10:45 am    Post subject: 2 Vs 3 blade Reply with quote
I can't site the source but it is from a report done by NASA that
determined that a perfect 3 blade is "slightly" less efficient than a
perfect 2 blade. However in practice, other variables, such as engine,
airframe, altitude, cruise speed, etc, will have more of an effect than
the theoretical difference in efficiency between a 2 and 3 blade prop.
With all the variables beyond our control it is very difficult to
determine what prop would work the best for any given situation by
comparing various reports from various builders. What I would really
like to see is Van's (or anybody else for that matter) build 2 identical
planes. Do side by side flight tests to see how close they are in the
air for a base line. Then start testing various changes in side by side
tests. Seems to me that is the best way to get data that is very useful.
Chris W
KE5GIX
"Protect your digital freedom and privacy, eliminate DRM,
learn more at http://www.defectivebydesign.org/what_is_drm"
Ham Radio Repeater Database.
http://hrrdb.com
lessdragprod(at)aol.com
PostPosted: Sun Apr 27, 2008 11:23 am    Post subject: 2 Vs 3 blade Reply with quote
Why build two RV-10s? When we could fly two different propellers on the same RV-10.
IMHO, it will take more time to get the flight test data than it will take to change the propellers.
Jim Ayers
