GSC Prop blades
Rex Hefferan
PostPosted: Sun Apr 06, 2008 8:51 pm    Post subject: GSC Prop blades Reply with quote
Yes, I read that and have sent an email to GSC asking about the
replacement blades which came with the airplane I bought to repair. I
suspect the TBO is meant to apply to blades installed in a hub. I will
let the list know what they say.
Rex Hefferan
SE Colorado / K-II / 582-C / still waiting repairs
Noel Loveys wrote:
New... Over five years old??? GSC has a TBO on the blades something like
five years or 500 Hr....Whichever first.
Noel
Rex
N740GP - M2/582
Colorado
dave
PostPosted: Mon Apr 07, 2008 12:26 am    Post subject: Re: GSC Prop blades Reply with quote
Rex Hefferan
Rex, When you call GSC , Rick Peters will tell you the same thing -- 5 years !! REplace the blades. Hub will likely be ok but blades ..........hmmmmmmmmmmmmmmmmmm
I just ordered another one from him last week. Nice props and blades are cheap. I would get urethane leading edge on any new blade. TEll him i sent you and it will cost you more ... just joking it will likely cost you less if you order through http://www.rotaxservices.com/
look at my last post ..... here is pic again .
 Filesize:  95.59 KB
 Viewed:  505 Time(s)
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube
Fox5flyer
PostPosted: Mon Apr 07, 2008 3:26 am    Post subject: GSC Prop blades Reply with quote
Rex, another option is to just call GSC for an overhaul estimate and if not
to outrageous, have them make it right.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 355+ TT
- Joseph Joubert
Float Flyr
PostPosted: Mon Apr 07, 2008 6:19 am    Post subject: GSC Prop blades Reply with quote
The 500 hr part would be from installation the 5yr part would be from manufacture.
These blades are wood. They are held to the hub by a smaller, comparatively speaking, root. Older props of this make have been known to break off at the root leaving a good portion of wood inside the hub. If your blades are loose and the hub is torque down so there is no space at all between the front plate and the rear plate then the prop roots have been damaged. The cells in the wood have been damaged , read weakened. The best thing to do with them is to make up a hub and use the blades on a wind charger ... or hang them in your den with a clock in the hub.
I wouldn't even ground run those blades. Blade departures aren’t unknown why take a chance?
I was in exactly the same position you are in and to this day I’m happy I bought a new prop.
Noel Loveys
Campbellton, NL, Canada
CDN AME intern, PP-Rec
C-FINB, Kitfox III-A
582 B box, Ivo IFA, Aerocet 1100 floats
[url=noelloveys(at)yahoo.ca]noelloveys(at)yahoo.ca[/url]
 Filesize:  7.29 KB
 Viewed:  4434 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
dave
PostPosted: Mon Apr 07, 2008 2:04 pm    Post subject: Re: GSC Prop blades Reply with quote
Deke Morisse
Mikado Michigan
Deke, I am not aware of any overhaul on a GSC prop. They are just a throw away unit as are most of the props we play with . You cannot magnaflux a wood prop and the weak link is in the root end.
Just replace after a set time and or hours flown to be safe.
shinco(at)bright.net
PostPosted: Mon Apr 07, 2008 3:34 pm    Post subject: GSC Prop blades Reply with quote
*_manufacture_*.
a clock in the hub.
Sigtaturea
*Noel Loveys*
Float Flyr
PostPosted: Tue Apr 08, 2008 11:20 am    Post subject: GSC Prop blades Reply with quote
Steve:
I replaced it with an Ivo IFA for two reasons.
1 the Ivo is very light. The UL - IFA with the hub and all is much lighter than the GSC
2. I wasn't getting the power out of the GSC I thought I should have been getting... I was right. Not because of a problem with the prop but a problem with the tachometer. My tach was reading 20-% high across the whole envelope. That means at idle I was only turning around 1800 rpm... Read shook like a S.O.B. and at full throttle (6800 rpm on floats) I was actually only getting 5400 rpm. I don't think the prop, fifteen years old could have taken the full 6800 rpm.
With all composite props I still advise getting your torque wrench calibrated. I calibrated mine with twenty pounds of weight slung exactly ten inches horizontally from the centre of the stud (200lb. in.) slinging at 12' gave me the calibration for 240 lb. in.. I then just noted my calibration points. In my case both calibration points were exactly minus 13 lb. in. So to set my wrench for 200 lb. in. Calibrated I set it for 187 lb.in.. If I had to torque to 100 lb. in. I would just do another calibration.
Just a note for Canadian certified aircraft owners the above method of calibration is not a certified method... as practical as it is.
When I got the Ivo first I noticed that there were no holes in the heads of the bolts. I figured this was a mistake on the behalf of Ivo so I called them to check why no lockwire holes. I was told the intentionally don't lock wire their props because they want you to check the torque on a regular basis and some people don't like to cut lock wire. Being a well trained Canadian AME (Aircraft Maintenance Engineer) I do as I'm told and didn't use drilled bolts for the hub.
My experience with the Ivo is it is a very smooth prop and very light too. I never got around to setting the pitch stops and to be honest I think it's better to be able to run a bit further than normally used to keep additional load off the small planetary gears that operate the hub. I also noticed although it was the same length as my GSC it doesn’t pick up spray the same way. With the GSC I was always filling pits in the leading edges of the blades... The Ivo hasn't had that need.
There are some people out there who don’t like the flexibility of the Ivo. I think its flexibility is part of the reason it is so smooth.
Noel Loveys
 Filesize:  7.29 KB
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
PostPosted: Tue Apr 08, 2008 2:50 pm    Post subject: GSC Prop blades Reply with quote
Noel Loveys wrote:
Steve:
Sigtaturea
*Noel Loveys*
