Mark Colbeck
Joined: 04 Nov 2007 Posts: 29 Location: Cochrane, Alberta, Canada
Posted: Sun Mar 23, 2008 8:59 am Post subject: Ray Allen Position Sensor for Flaps |
Does anyone have or have you seen a working set up for using a Ray Allen position sensor for flap position. My issue is 1.2" travel on sensor 2" travel on actuator. This is assuming the sensor is going next to the actuator. I though I could save some time in trial and error an see if anyone has an answer (you guys usually do)
_________________ CH701
70% Complete
www.mykitlog.com/mcolbeck |
Posted: Sun Mar 23, 2008 9:46 am Post subject: Ray Allen Position Sensor for Flaps |
My experience is with the 601XL and I am not sure how things are set up on the 701. On the XL I have seen two styles of solution. In the first an arm is attached to the shaft that rotates to actuate the flaps. One end of the position sensor is tied to the fuselage while the other fastens to some point on the arm. Since the arm moves less than 1.2 inches at the tube (relative to the attachment point on the fuselage) and more than 1.2 inches at a point further out the arm you just find the point on the arm that moves just a bit under 1.2 inches. The pictures below are from Mike Sigman’s 601XL.
Ron Geese has a clever solution that doesn’t involve adding a arm. The flap linear actuator is tied to a fixed pivot at one end and an arm on the rotating flap tube on the other. So, again, somewhere along the actuator is a point where the mechanism rises about 1.2 inches across the whole range of motion. Just connect the sensor at that point. I attached two photos that Ron sent me.
-- Craig
Mike’s solution (three photos):
8.39 KB |
6231 Time(s) |
9.37 KB |
723 Time(s) |
12.79 KB |
723 Time(s) |
35.4 KB |
718 Time(s) |
30.55 KB |
718 Time(s) |
Jaybannist(at)cs.com Guest
Posted: Sun Mar 23, 2008 10:12 am Post subject: Ray Allen Position Sensor for Flaps |
Mark,
I, too, have a 601XL. I didn't use a Ray Allen flap position sensor. I use LOWF (pronounced "lowf"). Look Out Window at Flaps.
Jay in Dallas [quote][b]
Terry Phillips
Joined: 11 Jan 2006 Posts: 346 Location: Corvallis, MT
Posted: Sun Mar 23, 2008 2:39 pm Post subject: Ray Allen Position Sensor for Flaps |
I have considered a flap indicator problem for my 601. The solutions
already mentioned would accommodate the R.A. Allen indicator. I'd like to
suggest a cheaper, simpler indicator.
Yesterday I visited Clayton, my EAA Tech Counselor at his hangar in Helena.
He showed me the homemade flap indicator on his RV-6. The RV-6 flap
appeared to rotate on an axle or hinges located at the center of the flap.
He just painted suitable lines on the skin of his flap around the rotation
axle so that the exposed line indicated the angle. Then glancing over his
left shoulder, he could read the deflection angle directly by seeing which
lines were exposed. 'Sorry, I didn't get any pictures. Obviously, this only
works in daylight.
That concept won't work with the 601 because the flap is hinged at the
bottom, instead of rotating on a central pivot. So, I've been thinking
about suitable visual indicators for the 601.
So far what I've come up with is shown, sort of, in the attached sketch.
The idea is to rivet a short piece of L-angle to the forward skin of the
flange, maybe 3/4" below the top, with the web vertical. Then put a #8
screw through the web of the angle to produce a pivot for a piece of ~10 or
12 AWG aluminum wire that would extend into the wing through an ~1/8" hole
in the rear spar. Paint the wire black and then paint on white rings for
10, 20, and 30° (or whatever) flap positions. A quick glance would confirm
the flap position. I'd place it just outside rear rib #4, so it wouldn't
get stepped on during entry.
Has anyone implemented a similar indicator? If so, how has it worked? Comments?
Terry
At 09:59 AM 3/23/2008 -0700, you wrote:
| Quote: | Does anyone have or have you seen a working set up for using a Ray Allen
Terry Phillips
ttp44~at~rkymtn.net
Corvallis MT
601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail, flaps, & ailerons
are done; working on the wings
http://www.mykitlog.com/N47TP/
53.92 KB |
703 Time(s) |
_________________ Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings. |
ashontz
Posted: Sun Mar 23, 2008 5:12 pm Post subject: Re: Ray Allen Position Sensor for Flaps |
Go down to Boater's World and pickup an trim sender for about $35.
| Mark Colbeck wrote: | Does anyone have or have you seen a working set up for using a Ray Allen position sensor for flap position. My issue is 1.2" travel on sensor 2" travel on actuator. This is assuming the sensor is going next to the actuator. I though I could save some time in trial and error an see if anyone has an answer (you guys usually do)
Thanks |
Mark Colbeck
Posted: Mon Mar 24, 2008 4:25 am Post subject: Re: Ray Allen Position Sensor for Flaps |
Thanks for the input. I think I got it figured now.
70% Complete
