Skins
rmacpunk(at)netzero.net
PostPosted: Tue Mar 11, 2008 10:57 am    Post subject: Skins Reply with quote
Do the rear and middle top skins overlap or go inside the side skins?
eddies
PostPosted: Tue Mar 11, 2008 11:28 am    Post subject: Re: Skins Reply with quote
The skins overlap
Eddie
frank_forgues(at)HOTMAIL.
PostPosted: Tue Mar 11, 2008 12:01 pm    Post subject: Skins Reply with quote
I'm at that stage now and I believe that just like the rudder, the skins are positioned inside the panels to mark and drill out matching holes and then pulled out and repositioned on top of the panels. If they were left inside, the top edge of the panel would create a lip and capture rain, dew etc... which could eventually create corrosion. Hope this helps.
Re: rmacpunk(at)netzero.net (rmacpunk(at)netzero.net) wrote... "Do the rear and middle top skins overlap or go inside the side skins?"
Frank Forgues
fuse
601xl/corvair
Toronto Can.
Subject: Zenith-List: Skins
Date: Tue, 11 Mar 2008 14:55:00 -0400
arget=_blank>http://www.matronics.com/Navigator?Zenith-List
p://forums.matronics.com
Snap and Share.  From your phone to your space.  Post your pics here. [quote][b]
leinad
PostPosted: Tue Mar 11, 2008 4:00 pm    Post subject: Re: Skins Reply with quote
The top overlaps the side skins, but tucks under the cabin side skins. Leave a large area of the cabin side skins clecoed until you are ready to tuck the top skin under.
I'm pretty sure I've got this correct according to the plans (at least the version I purchased).
Dan
[quote="rmacpunk(at)netzero.net"]Do the rear and middle top skins overlap or go inside the side skins?
close up of overlap
 Filesize:  57.53 KB
 Viewed:  583 Time(s)
leinad
PostPosted: Tue Mar 11, 2008 4:03 pm    Post subject: Re: Skins Reply with quote
By the way ignore the date on the photo. I took it a week ago. The battery on my camera died and reset the date.
Dan
