cjpilot710(at)aol.com Guest
Posted: Tue Nov 27, 2007 8:20 pm Post subject: Car Gas/turbins |
It is interesting how changing an aircraft shape, even slightly, can big effects on its handling or even its controllability. Almost 20 years ago, I was playing at being a designer. I was working on an idea for a composite 80% scale Spitfire. When the weight/balance didn't come out (very tail heavy) I thought about extending the nose (along with the engine and anything else I could). When I looked at it, the profile just didn't "right". I asked Bill Welsh (a very respected aero dynamist at the time now passed away) to look at it. He came back with the definitive answer. DON'T DO IT! The extended nose would have turn the "normally docile" Spitfire into a uncontrollable night mare. For much the same reason a lot of float planes have extra fins on the tail, to offset the area added ahead of the center of pressure.
I willing to bet that the lighter weight turbine engine would need to be moved forward to help weight and balance, and a some point you will increase the arm of the area ahead of the center of pressure. Hence the ventral fin on the T-34C as compared to the As&Bs. How this would effect the CJ I don't know. Most CJ are fairly nose heavy with all the radios removed from aft of the rear cockpit and normally ballast is required in the tail. It might be fun to run the numbers, draw up a profile, to see what she might look like. In 2001 when Bushi was asked by one of the AZ guys about that, he told them it would be better to design a whole new airplane. Still - - - - -
Jim "Pappy" Goolsby
In a message dated 11/27/2007 8:56:23 P.M. Eastern Standard Time, N13472(at)aol.com writes:
| Quote: | In a message dated 11/26/2007 9:08:44 P.M. Pacific Standard Time, cjpilot710(at)aol.com writes:
| Quote: | Does the T-34C have the same airfoil and wing?
Jim "Pappy" Goolsby
Speaking of fun turbine air planes I have a neighbor that has a L-17 (Navion) with the Walter 750 Hp on
the nose. Although it looks strange the distances from the spar to the tip of the spinner is the same as
spar to tip of the tail.
Tom Elliott
CJ-6 NX63727
Sandy Valley NV
3L2
702-723-1223
Check out AOL Money & Finance's list of the hottest products and top money wasters of 2007.
://www.matronics.com/contribution">http://www.matronics.com/contribution
="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List
.matronics.com/">http://forums.matronics.com
Posted: Tue Nov 27, 2007 9:33 pm Post subject: Car Gas/turbins |
Jim "Pappy" Goolsby
Hmmm….Design a whole new airplane….novel idea! [img]cid:image001.jpg(at)01C8314D.A9B78A80[/img]
:>0 ;>))
Doc
9.96 KB |
143 Time(s) |
Posted: Wed Nov 28, 2007 6:07 am Post subject: Car Gas/turbins |
Yep,
You see before you a real life Yak 18A.
But its all fabric covered!
And it has a steel tube frame.
Look! all the stabilizers are externally braced and covered with fabric
And that airfoil - - why its the old Clark Y!
And there is that landing gear, stuck out in the breeze. Will keep you from going passed Vne to quickly. That's good. And, Yep its great for the gear up landings these guys are so good at!
Geee the engine is only 260 hp (Must be pretty doggy). How come the CJ-6 was so much faster with the same engine?
That center section? Wonder where they got the from? Maybe the Junkers A50 (1929) or even the Fokker DVIII (It is a monoplane with a center section - just on top is all. And it had a round engine)
Geee it looks like a Yak 52 (with a center section) to me.
Hay! You've pulled my chain! I out of here for a while :>)
Jim "Pappy" Goolsby
"There is nothing NEW under the sun, son" My father a long time ago.
"Form follows function" Some astute engineer a long time ago.
In a message dated 11/28/2007 12:34:27 A.M. Eastern Standard Time, viperdoc(at)mindspring.com writes:
Jim "Pappy" Goolsby
:>0 ;>))
Doc
9.96 KB |
144 Time(s) |
