Wheel Fairing Air Access covers
sam(at)fr8dog.net
PostPosted: Thu Nov 15, 2007 2:38 pm    Post subject: Wheel Fairing Air Access covers Reply with quote
I've looked and looked on the web for these things. The little spring assisted access door to put air in your tires, with wheel pants installed. Does anybody remember the part #?
Sam Marlow
#40157 Flying now
bpattonsoa(at)yahoo.com
PostPosted: Thu Nov 15, 2007 3:37 pm    Post subject: Wheel Fairing Air Access covers Reply with quote
I believe that Aircraft Spruce has them. They are fragile and will break. I recommend steel hole plugs, at your hardware store. Paint up a few extra, they can get lost.
Bruce
Sam Marlow
#40157 Flying now
M55p121.pdf
 Filename:  M55p121.pdf
 Filesize:  128.77 KB
 Downloaded:  490 Time(s)
randy(at)romeolima.com
PostPosted: Thu Nov 15, 2007 7:37 pm    Post subject: Wheel Fairing Air Access covers Reply with quote
I suspect you're describing these...
http://www.romeolima.com/RV3works/IdeasProducts/ideasproducts.htm#AccessDoors
Randy Lervold
RV-3B, flying
sam(at)fr8dog.net
PostPosted: Fri Nov 16, 2007 4:59 am    Post subject: Wheel Fairing Air Access covers Reply with quote
Thanks Randy, that's exactly what I was looking for! Nice website.
Randy Lervold wrote: [quote] I suspect you're describing these...
Randy Lervold
RV-3B, flying
----- Original Message -----
Sent: Thursday, November 15, 2007 2:31 PM
Subject: Wheel Fairing Air Access covers
Sam Marlow
#40157 Flying now
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
_popupControl();[b]
sam(at)fr8dog.net
PostPosted: Fri Nov 16, 2007 6:54 am    Post subject: Wheel Fairing Air Access covers Reply with quote
Thanks Bruce, but another member of the list found them. They are #KM713-16-064, from A/C Spruce.
Sam
Do not archive.
Bruce Patton wrote: [quote][b]
PostPosted: Fri Nov 16, 2007 9:27 am    Post subject: Wheel Fairing Air Access covers Reply with quote
Well, it's not an RV-10, in fact it's at the opposite end of the mission profile spectrum, but I sure like it!
[img]cid:005001c8286a$63ddbde0$6401a8c0(at)latittuded810[/img]
Those little doors are installed on the outside of the wheel pants, note how you can't even see them?
Randy
www.rv-3.com
 Filesize:  122.4 KB
 Viewed:  454 Time(s)
jesse(at)saintaviation.co
PostPosted: Fri Nov 16, 2007 10:15 am    Post subject: Wheel Fairing Air Access covers Reply with quote
I looks like Spruce only has as high a 1.5" diameter. Cirrus (yes, I know,
a bad word) sells a 2" plastic plug. You should be able to order it through
any Cirrus repair shop.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
sam(at)fr8dog.net
PostPosted: Fri Nov 16, 2007 11:35 am    Post subject: Wheel Fairing Air Access covers Reply with quote
Do you have a part # Jesse, or has anyone found a Cirrus parts catalog
on line?
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
PostPosted: Fri Nov 16, 2007 3:43 pm    Post subject: Wheel Fairing Air Access covers Reply with quote
"Plug, 2.0" Cirrus"
Item # 50498-200
Price $2.60 ea.
DLK Aviation
2601 Cessna Lane
Kennesaw, GA 30144
770-427-4954
www.dlkaviation.com
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
n212pj(at)gmail.com
PostPosted: Fri Nov 16, 2007 4:11 pm    Post subject: Wheel Fairing Air Access covers Reply with quote
I've seen Randy's plane up close and it's meticulous. A fine, fine example of the craft that we call RV building. Something of which he should rightfully be proud. Randy offered me a ride, but the thought of being strapped to the right wing while Cox got the left, was just too much to bear, so I declined.
Jessen
do not archive !!!
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Randy Lervold
Sent: Friday, November 16, 2007 8:05 AM
Subject: Re: Wheel Fairing Air Access covers
[img]cid:986183918(at)16112007-23B1[/img]
Randy
www.rv-3.com
 Filesize:  122.4 KB
 Viewed:  450 Time(s)
wcurtis(at)nerv10.com
PostPosted: Fri Nov 16, 2007 6:22 pm    Post subject: Wheel Fairing Air Access covers Reply with quote
You mean these?
http://www.aircraftspruce.com/catalog/hapages/accessdoors.php
Spruce has them for ~$21.30 or you can call up B&B Aircraft supply. I got two from them at OSH '07 for $7.50 each.
William
http://wcurtis.nerv10.com/
sam(at)fr8dog.net
PostPosted: Mon Nov 19, 2007 11:24 pm    Post subject: Wheel Fairing Air Access covers Reply with quote
Thanks Jesse!
do not archive.
Jesse Saint wrote:
"Plug, 2.0" Cirrus"
Item # 50498-200
Price $2.60 ea.
DLK Aviation
2601 Cessna Lane
Kennesaw, GA 30144
770-427-4954
www.dlkaviation.com
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
