sam(at)fr8dog.net Guest
Posted: Thu Nov 15, 2007 2:38 pm Post subject: Wheel Fairing Air Access covers |
I've looked and looked on the web for these things. The little spring assisted access door to put air in your tires, with wheel pants installed. Does anybody remember the part #?
Sam Marlow
#40157 Flying now
bpattonsoa(at)yahoo.com Guest
Posted: Thu Nov 15, 2007 3:37 pm Post subject: Wheel Fairing Air Access covers |
I believe that Aircraft Spruce has them. They are fragile and will break. I recommend steel hole plugs, at your hardware store. Paint up a few extra, they can get lost.
Bruce
Sam Marlow
#40157 Flying now
 Download |
| Filename: |
M55p121.pdf |
128.77 KB |
| Downloaded: |
484 Time(s) |
randy(at)romeolima.com Guest
Posted: Fri Nov 16, 2007 4:59 am Post subject: Wheel Fairing Air Access covers |
Thanks Randy, that's exactly what I was looking for! Nice website.
Randy Lervold wrote: [quote] I suspect you're describing these...
http://www.romeolima.com/RV3works/IdeasProducts/ideasproducts.htm#AccessDoors
Randy Lervold
RV-3B, flying
| Quote: | ----- Original Message -----
Sent: Thursday, November 15, 2007 2:31 PM
Subject: Wheel Fairing Air Access covers
Sam Marlow
#40157 Flying now
| _popupControl();[b]
Posted: Fri Nov 16, 2007 6:54 am Post subject: Wheel Fairing Air Access covers |
Thanks Bruce, but another member of the list found them. They are #KM713-16-064, from A/C Spruce.
Sam
Do not archive.
Bruce Patton wrote: [quote][b]
Posted: Fri Nov 16, 2007 9:27 am Post subject: Wheel Fairing Air Access covers |
Well, it's not an RV-10, in fact it's at the opposite end of the mission profile spectrum, but I sure like it!
[img]cid:005001c8286a$63ddbde0$6401a8c0(at)latittuded810[/img]
Those little doors are installed on the outside of the wheel pants, note how you can't even see them?
Randy
www.rv-3.com
122.4 KB |
446 Time(s) |
Posted: Fri Nov 16, 2007 10:15 am Post subject: Wheel Fairing Air Access covers |
I looks like Spruce only has as high a 1.5" diameter. Cirrus (yes, I know,
a bad word) sells a 2" plastic plug. You should be able to order it through
any Cirrus repair shop.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
Posted: Fri Nov 16, 2007 11:35 am Post subject: Wheel Fairing Air Access covers |
Do you have a part # Jesse, or has anyone found a Cirrus parts catalog
on line?
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
Posted: Fri Nov 16, 2007 3:43 pm Post subject: Wheel Fairing Air Access covers |
"Plug, 2.0" Cirrus"
Item # 50498-200
Price $2.60 ea.
DLK Aviation
2601 Cessna Lane
Kennesaw, GA 30144
770-427-4954
www.dlkaviation.com
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
n212pj(at)gmail.com Guest
Posted: Fri Nov 16, 2007 4:11 pm Post subject: Wheel Fairing Air Access covers |
I've seen Randy's plane up close and it's meticulous. A fine, fine example of the craft that we call RV building. Something of which he should rightfully be proud. Randy offered me a ride, but the thought of being strapped to the right wing while Cox got the left, was just too much to bear, so I declined.
Jessen
do not archive !!!
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Randy Lervold
Sent: Friday, November 16, 2007 8:05 AM
Subject: Re: Wheel Fairing Air Access covers
[img]cid:986183918(at)16112007-23B1[/img]
Randy
www.rv-3.com
122.4 KB |
443 Time(s) |
wcurtis(at)nerv10.com Guest
Posted: Mon Nov 19, 2007 11:24 pm Post subject: Wheel Fairing Air Access covers |
Thanks Jesse!
do not archive.
Jesse Saint wrote:
"Plug, 2.0" Cirrus"
Item # 50498-200
Price $2.60 ea.
DLK Aviation
2601 Cessna Lane
Kennesaw, GA 30144
770-427-4954
www.dlkaviation.com
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
