richard.goode(at)russiana Guest
Posted: Thu Feb 23, 2006 7:00 am Post subject: Yak-52 Bad Habits |
The 52 is a delightful aeroplane and a superb aerobatic trainer.
HOWEVER if a spin is allowed to develop and go flat, recovery can be prolonged, which in turn CAN lead to confusion.
Anyone doing aerobatics in a 52 and who has not read our short paper on 52 spinning should do so. Drop us a line off list, and we will send you a copy.
Richard Goode
Richard Goode Aerobatics
Rhodds Farm
Lyonshall
Herefordshire
HR5 3LW
United Kingdom
Tel: +44 (0) 1544 340120
Mob: +44 (0) 7768 610389
Fax: +44 (0) 1544 340129
www.russianaeros.com
Scooter
Posted: Thu Feb 23, 2006 7:44 am Post subject: Re: Yak-52 Bad Habits |
So a developed spin will/can go flat? That could be considered a bad habit i suppose. But not getting out of it (or not having enough altitude to recover) would be a bad piloting habit.
I suggest you guys do the following to finally put this nomex issue to rest. Build a big fire. Half of you dress in nomex and half in corduroy (or whatever you wear when you fly). Then take turns jumping through the fire until somebody bursts into flames. The losers will concede to the winners.
brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Thu Feb 23, 2006 8:05 am Post subject: Yak-52 Bad Habits |
Scooter wrote:
| Quote: | I suggest you guys do the following to finally put this nomex issue to rest. Build a big fire. Half of you dress in nomex and half in corduroy (or whatever you wear when you fly). Then take turns jumping through the fire until somebody bursts into flames. The losers will concede to the winners.
I volunteer to manage the experiment and keep the records!
Brian Lloyd 361 Catterline Way
brian-yak at lloyd dot com Folsom, CA 95630
- Antoine de Saint-Exupery
_________________ Brian Lloyd
- Antoine de Saint-Exupery |
gus.fraser(at)gs.com Guest
Posted: Thu Feb 23, 2006 8:28 am Post subject: Yak-52 Bad Habits |
Scooter,
Even this I would not class as a bad habit. For recovery people often give
up too soon. When the recovery takes time they try something else. Here is
my take on recovery from flat and accelerated spins in a 52.
After the nose has come up the plane is shaking and the ailerons are in, now
comes time for recovery.
***** Close throttle ******
Full forward and in spin aileron at the same time as applying full rudder.
You may think that you have applied full control but keep pushing there is
more. The stick and pedals are real strong you wont break them, and keep
them there. When the rotation stops IMMEDIATELY remove the rudder and center
the aileron otherwise you will cross over to inverted real fast, center
elevator as needed. At about 200 kph start to recover to SAL flight. Best
tip on which rudder pedal to push (inverted or right side up) look at where
the ground is disappearing to that is the pedal to push. Now this is just my
attempt to put into words a method that I was taught, it is a lot more
interesting when doing it for real.
Gennady Elfimov (www.skytrace.co.uk) said that in Russia they experimented
with the standard Muller Beggs recovery and found this method above to be at
least 500 ft more efficient in altitude loss.
Now I really must say here again that email is not the way to learn
technique the only way to do that effectively and safely is to find someone
that knows what they are doing and learn from them. I asked you before which
state are you in there are numerous people out there that would show you
technique.
As for a developed spin going flat I would disagree. Sure a spin can get
very stable and inertia becomes a factor but it will not go flat without the
engine. If you do a flat you will be shocked by just how much the nose comes
up one mans flat is another mans stable.
Gus
Posted: Thu Feb 23, 2006 10:14 am Post subject: Yak-52 Bad Habits |
As a point of reference this link shows the skytrace training program.
http://www.skytrace.co.uk/program.html
This is based on the DOSAF system.
jsfox(at)adelphia.net Guest
Posted: Thu Feb 23, 2006 11:09 am Post subject: Yak-52 Bad Habits |
Richard,
How much do the spin characteristics change, if you don't have the Russian radio in the back?
Steve Fox
Yak 52
N3043R
http://homepage.mac.com/steve.fox/PhotoAlbum5.html
On Feb 23, 2006, at 9:59 AM, Richard Goode wrote:
| Quote: | The 52 is a delightful aeroplane and a superb aerobatic trainer.
Richard Goode
Richard Goode AerobaticsRhodds FarmLyonshallHerefordshireHR5 3LWUnited Kingdom
Tel: +44 (0) 1544 340120Mob: +44 (0) 7768 610389Fax: +44 (0) 1544 340129www.russianaeros.com
dangerous content by http://www.invictawiz.com
and is believed to be clean.
Steve "SOB" Fox
Yak 52
N3043R
BitterlichMG(at)cherrypoi Guest
Posted: Thu Feb 23, 2006 11:51 am Post subject: Yak-52 Bad Habits |
Not much, other than your observer on the ground won't have to speak a foreign language anymore.
Sorry........
mgb
[quote] --
