				|  | Matronics Email Lists Web Forum Interface to the Matronics Email Lists
		| Author | Message |
		| richard.goode(at)russiana Guest
				|  Posted: Thu Feb 23, 2006 7:00 am    Post subject: Yak-52 Bad Habits |   |
				| The 52 is a delightful aeroplane and a  superb aerobatic trainer.
 HOWEVER if a spin is allowed to develop and  go flat, recovery can be prolonged, which in turn CAN lead to  confusion.
 Anyone doing aerobatics in a 52 and who has  not read our short paper on 52 spinning should do so.  Drop us a line off  list, and we will send you a copy.
 Richard Goode
 Richard Goode Aerobatics
 Rhodds  Farm
 Lyonshall
 Herefordshire
 HR5 3LW
 United Kingdom
 Tel:    +44 (0) 1544 340120
 Mob:  +44 (0) 7768  610389
 Fax:   +44 (0) 1544 340129
 www.russianaeros.com
 | |  |  | - The Matronics Yak-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Yak-List
		| Back to top |  |
		| Scooter
				|  Posted: Thu Feb 23, 2006 7:44 am    Post subject: Re: Yak-52 Bad Habits |   |
				| So a developed spin will/can go flat?  That could be considered a bad habit i suppose.  But not getting out of it (or not having enough altitude to recover) would be a bad piloting habit.
 I suggest you guys do the following to finally put this nomex issue to rest.  Build a big fire.  Half of you dress in nomex and half in corduroy (or whatever you wear when you fly).  Then take turns jumping through the fire until somebody bursts into flames.  The losers will concede to the winners.
		| Back to top |  |
		| brian
				|  Posted: Thu Feb 23, 2006 8:05 am    Post subject: Yak-52 Bad Habits |   |
				| Scooter wrote:
  	  | Quote: |  	  | I suggest you guys do the following to finally put this nomex issue to rest.  Build a big fire.  Half of you dress in nomex and half in corduroy (or whatever you wear when you fly).  Then take turns jumping through the fire until somebody bursts into flames.  The losers will concede to the winners.
 I volunteer to manage the experiment and keep the records!
 Brian Lloyd                         361 Catterline Way
 brian-yak at lloyd dot com          Folsom, CA 95630
 +1.916.367.2131 (voice)             +1.270.912.0788 (fax)
 - Antoine de Saint-Exupery
 Brian Lloyd
		| Back to top |  |
		| gus.fraser(at)gs.com Guest
				|  Posted: Thu Feb 23, 2006 8:28 am    Post subject: Yak-52 Bad Habits |   |
				| Scooter,
Even this I would not class as a bad habit. For recovery people often give
 up too soon. When the recovery takes time they try something else. Here is
 my take on recovery from flat and accelerated spins in a 52.
 After the nose has come up the plane is shaking and the ailerons are in, now
 comes time for recovery.
 ***** Close throttle ******
 Full forward and in spin aileron at the same time as applying full rudder.
 You may think that you have applied full control but keep pushing there is
 more. The stick and pedals are real strong you wont break them, and keep
 them there. When the rotation stops IMMEDIATELY remove the rudder and center
 the aileron otherwise you will cross over to inverted real fast, center
 elevator as needed. At about 200 kph start to recover to SAL flight. Best
 tip on which rudder pedal to push (inverted or right side up) look at where
 the ground is disappearing to that is the pedal to push. Now this is just my
 attempt to put into words a method that I was taught, it is a lot more
 interesting when doing it for real.
 Gennady Elfimov (www.skytrace.co.uk) said that in Russia they experimented
 with the standard Muller Beggs recovery and found this method above to be at
 least 500 ft more efficient in altitude loss.
 Now I really must say here again that email is not the way to learn
 technique the only way to do that effectively and safely is to find someone
 that knows what they are doing and learn from them. I asked you before which
 state are you in there are numerous people out there that would show you
 technique.
 As for a developed spin going flat I would disagree. Sure a spin can get
 very stable and inertia becomes a factor but it will not go flat without the
 engine. If you do a flat you will be shocked by just how much the nose comes
 up one mans flat is another mans stable.
 Gus
		| Back to top |  |
				|  Posted: Thu Feb 23, 2006 10:14 am    Post subject: Yak-52 Bad Habits |   |
				| As a point of reference this link shows the skytrace training program.
 http://www.skytrace.co.uk/program.html
 This is based on the DOSAF system.
		| Back to top |  |
		| jsfox(at)adelphia.net Guest
				|  Posted: Thu Feb 23, 2006 11:09 am    Post subject: Yak-52 Bad Habits |   |
				| Richard,
How much do the spin characteristics change, if you don't have the Russian radio in the back?
 Steve Fox
 Yak 52
 N3043R
 http://homepage.mac.com/steve.fox/PhotoAlbum5.html
 On Feb 23, 2006, at 9:59 AM, Richard Goode wrote:
  	  | Quote: |  	  | The 52 is a delightful aeroplane and a superb aerobatic trainer.
 Richard Goode
 Richard Goode AerobaticsRhodds FarmLyonshallHerefordshireHR5 3LWUnited Kingdom
 Tel:    +44 (0) 1544 340120Mob:  +44 (0) 7768 610389Fax:   +44 (0) 1544 340129www.russianaeros.com
 dangerous content by http://www.invictawiz.com
 and is believed to be clean.
 Steve "SOB" Fox
 Yak 52
 N3043R
		| Back to top |  |
		| BitterlichMG(at)cherrypoi Guest
				|  Posted: Thu Feb 23, 2006 11:51 am    Post subject: Yak-52 Bad Habits |   |
				| Not  much, other than your observer on the ground won't have to speak a foreign  language anymore.
 Sorry........
 mgb
 [quote]   --
		| Back to top |  |
 | You cannot post new topics in this forum You cannot reply to topics in this forum
