Baffling Question
Mike Whisky
PostPosted: Wed Oct 17, 2007 10:52 am    Post subject: Baffling Question Reply with quote
Hi,
does the baffling need to be on top of the rubber gasket or in front of it?
See attached picture.
Michael
 Filesize:  779.03 KB
 Viewed:  606 Time(s)
RV-10 builder (flying)
#511
Tim Olson
PostPosted: Wed Oct 17, 2007 12:11 pm    Post subject: Baffling Question Reply with quote
Michael, I think that metal baffle should be flat against the cylinder,
so you may want to sand or file slightly to make it go around the
gasket. Not sure if it really matters a huge amount, but you'll
want it to seal well either way. It seems your gaskets may be just
a little larger than some. If it likes sitting there though with
no stress on the metal, you could RTV it too if you wanted. Just
make sure it seals well.
Michael Wellenzohn wrote:
Hi,
Michael
RV-10 builder (fuselage)
#511
http://forums.matronics.com/viewtopic.php?p=140458#140458
http://forums.matronics.com//files/fairings_013_125.jpg
jesse(at)saintaviation.co
PostPosted: Wed Oct 17, 2007 12:48 pm    Post subject: Baffling Question Reply with quote
As Tim said, it mainly needs to seal, but it is best if you have it flat
against the cylinder. I would probably try to trim the gaskets a little
first to get it to pass, then my next move would be to trim the metal a
little, but there is not a lot of extra room around the edges.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
Mike Whisky
PostPosted: Wed Oct 17, 2007 11:10 pm    Post subject: Re: Baffling Question Reply with quote
Thanks Tim & Jesse,
I'll make it fit föat against the gasket.
Michael
BTW: does anyone have a picture of the Vetterman exhaust hanging?
#511
glastar(at)gmx.net
PostPosted: Wed Oct 17, 2007 11:33 pm    Post subject: Baffling Question Reply with quote
Michael,
just make sure you hagd a silencer behind the Vetterman otherwise I'm
afraid you will not pass the ICAO chapter 10 noise test requiered for
Europe.
br Werner
Thanks Tim & Jesse,
Michael
#511
http://forums.matronics.com/viewtopic.php?p=140586#140586
Mike Whisky
PostPosted: Wed Oct 17, 2007 11:42 pm    Post subject: Re: Baffling Question Reply with quote
Werner,
thats one of my big unknowns since there are no noise measurments arount. I talked to Liese and they offer a system. But I don't have any data about noise emission.
Thanks for the advice!
Michael
#511
VHMUM(at)bigpond.com
PostPosted: Wed Oct 17, 2007 11:52 pm    Post subject: Baffling Question Reply with quote
Michael I will take a pic of exhaust and send in the morning if that is not
to late?
My bafling is against the metal not the gasket also.
regards Chris
