| What Prop do you use? |
| MT 3 blade |
0% |
[ 0 ] |
| Hartzell 2 blade |
0% |
[ 0 ] |
| Total Votes : 0 |
Mike Whisky
Posted: Mon Sep 24, 2007 7:40 am Post subject: Prop Governor Question |
I installed the prop governor a couple days ago but I thing that the orientation of the lever is wrong.
Before I cut the hole for the cable in the baffeling assembly I want to be sure that this is right?
If you could attach a picture of your installation that would help most. I used the MT FWF Kit and the governor came as you see in the picture.
Michael
858.52 KB |
529 Time(s) |
_________________ RV-10 builder (flying)
#511 |
Tim Olson
Posted: Mon Sep 24, 2007 8:22 am Post subject: Prop Governor Question |
Michael,
This photo may help:
http://www.myrv10.com/N104CD/maintenance/20061022/RV200610220012.html
You just loosen the screws and rotate it. Don't remove screws.
For the newbies, pay attention to the responses here because
this question comes up often. Yes, you have to rotate the
arm position on the governor, and then it will work. It's kind
of an 8 o'clock to 11 o'clock rotation if I remember correctly
but others may chime in because it's been a long time since
I did this now.
Michael Wellenzohn wrote:
Michael
RV-10 builder (fuselage)
#511
http://forums.matronics.com/viewtopic.php?p=136112#136112
http://forums.matronics.com//files/dsc01635_302.jpg
mritter509(at)msn.com Guest
Posted: Mon Sep 24, 2007 8:27 am Post subject: Prop Governor Question |
Michael,
Loosen the 5 screws on the face plate and clock the lever around to the 10:00 position.
Mark
RV-10/N410MR
<html><div></div></html>
> Subject: Prop Governor Question
Make your little one a shining star! Shine on! [quote][b]
Mike Whisky
Posted: Mon Sep 24, 2007 11:55 am Post subject: Re: Prop Governor Question |
Great,
thanks for your answers.
Michael
www.wellenzohn.net
#511 |
