Deems Davis
Posted: Sun Sep 16, 2007 9:24 am Post subject: Fiberglass and antenna placement |
John W. Cox wrote:
. Fiberglass is not transparent
to RF it creates a false positive and measurable signal loss. It is
only translucent with a clearly diminished performance. It also requires
your output amp to work significantly harder leading to earlier
potential failure and often a loss of valuable communication when you
need it most - rain fade, cloud obscuration and turbulence
John, can you elaborate or point me to a reference source. I have always
heard that fiberglass is transparent wrt antennas. If there is a loss
due to the fiberglass how big of a loss is it? and what is a 'false
positive'? Does the fiberglass affect all spectrums equally? Both of
the antennas in my case are receive only and are satellite based systems.
Deems Davis # 406
'Its all done....Its just not put together'
http://deemsrv10.com/
n8vim(at)arrl.net Guest
Posted: Sun Sep 16, 2007 10:25 am Post subject: Fiberglass and antenna placement |
I am an extra-class ham radio operator, so here's my opinion:
Most fiberglass is relatively transparent to RF. Glass cloth and epoxy
don't attenuate RF much more than dust. If you put in carbon fiber, or
other additives then the situation changes.
The biggest issues typically are actually getting 1) a good ground
plane, and 2) good seperation from nearby antennas and other parallel
pieces of metal which can cause an impedance mismatch.
I have several antennas on top of my tower which are actually *encased*
in fiberglass.
Want a cheap tool for analyzing your antenna installation? Here's what I
use (a bit overkill for the aviation band):
http://www.mfjenterprises.com/products.php?prodid=MFJ-269
-Jim 40384
Deems Davis wrote:
always heard that fiberglass is transparent wrt antennas. If there is
a loss due to the fiberglass how big of a loss is it? and what is a
'false positive'? Does the fiberglass affect all spectrums equally?
Both of the antennas in my case are receive only and are satellite
based systems.
Deems Davis # 406
Deems Davis
Posted: Sun Sep 16, 2007 10:49 am Post subject: Fiberglass and antenna placement |
James, Thanks for the feedback, Here's another naive question: In your
opinion would the heat which exists in the engine compartment adversely
affect the performance of these satellited antennas?
Deems Davis # 406
James Hein wrote:
*encased* in fiberglass.
I use (a bit overkill for the aviation band):
-Jim 40384
> based systems.
> Deems Davis # 406
Tim Olson
Posted: Sun Sep 16, 2007 11:08 am Post subject: Fiberglass and antenna placement |
I've always taken antenna reception quality as THE #1 reason to choose
an antenna or mounting location....especially important if you're
shooting for the same quality as a "certified" installation. I never
understood why as experimental builders, who build planes that we pride
as being built "better than factory", anyone would build absolutely
sub-standard to all of the advice by manufacturers regarding their
installation requirements....on purpose, no less. The fact that someone
would bother to hem and haw about a WAAS GPS antenna no less, really
makes me wonder, as the amount of drag off a small wart of an antenna
is way less than if you were talking about a Nav or Com antenna, and the
signal you're trying to receive is EXTREMELY faint in comparison.
Here's something I dug up recently:
http://www.homelandsecurity.org/bulletin/Dual%20Benefit/warner_gps_spoofing.html
"The GPS signal strength measured at the surface of the Earth is about
–160dBw (1 x 10–16 watts), which is roughly equivalent to viewing a
25-watt light bulb from a distance of 10,000 miles. This weak signal can
easily be blocked by destroying or shielding the GPS receiver’s antenna.
The GPS signal can also be effectively jammed by a signal of a similar
frequency but greater strength. "
So then think about the many electrical noise causing things in an
airplane....probably one of the loudest of which would be the spark
plugs and ignition system. And then to choose to actually mount
the antennas CLOSER to those items? I mean, I've seen TV's get
scrambled signals when a snowmobile drove by the house years
ago....not that the plane is going to be as poor, but we're
*really* talking some tiny electrical signals with GPS...and sorry, but
if someone even thinks they're going to pass by on flying ILS and VOR
approaches and instead favor trusting a WAAS approach, why sacrifice?
If they're going to sacrifice that, then why bother to look at the
actual LPV-spec GPS units in the first place....just fly them with
an autopilot or EFIS driven by a 396. (and no, I'm not REALLY
endorsing that thinking)
http://www.nap.edu/html/embedded_everywhere/ch2_b8.html
"What makes GPS reception difficult is that radio frequency (RF) signals
from the satellites are very weak. Special coding is used to allow
receivers to detect these weak signals, but even with coding, GPS
receivers generally work only if they have a direct line of sight to the
satellites. Performance inside buildings or in an area covered by
foliage is generally quite poor"
http://www.wowinfo.com/gps/gps/chapter2n3.htm
"This is an extremely low-powered system—so low-powered, in fact, that
the signal is really buried in the natural background radio noise. The
receiver recovers this weak signal from the satellites by using
spread-spectrum communication technology, a very tricky concept in
communication theory that works by means of pseudo-random codes."
http://www.dot.nd.gov/manuals/surveymanual/gps-operations.pdf
"You’d think that with all of these radio waves raining down on us from
dozens of satellites in space
we’d all glow in the dark. Actually, the strength of the GPS signal is
very small, equivalent to the tail
light of a car seen from 2,500 kilometers away-halfway across the U.S.!
Weaker, in fact, than the
ordinary background radio noise that’s all around us all of the time."
So then thinking about laying it underneath fiberglass, my thought is:
"Well, if fiberglass is transparent to GPS, then how many layers are
transparent to the GPS. Can you put it under 1/16", 1/8", 1", 5"?
At what point do you decide you've hidden the GPS from it enough?"
And, if it's under a cowl, or at some other point not mounted
horizontally with a full view of the sky in all directions, then
which of the available satellites that are now unavailable are you
happy to just toss aside from shadowing due to poor mounting? So
some of them aren't worth seeing.
I understand the love of building a cosmetically pleasing airplane, but
to sacrifice life-saving avionics signals really makes me wonder. And
nothing against Dan Checkoway, but it's amazing how one person's good
experience with a poor mounting choice can spread to such a universal
acceptance of the idea. It might be better to bounce mounting
and location questions off the antenna makers and companies like Garmin
and see how far they're willing to stick their neck out with an answer.
If it were harmless, they'd have no reason to avoid giving the advice.
I've had many phone calls to Comant and questions to other antenna
makers throughout the build, which in the end mostly just led me to
try to be as "conventional" as possible to attempt the same
reliability as the certified planes could have.
Now, if someone was building a VFR only airplane, I'd say "heck yeah,
may as well give it a try".
Deems Davis wrote:
Deems Davis # 406
Posted: Sun Sep 16, 2007 11:16 am Post subject: Fiberglass and antenna placement |
The heat in the engine compartment would affect the antennas somewhat.
Why?
1. Matching components (if used - capacitors and/or inductors) values
will change with regard to temperature
2. Coax dielectric will soften, allowing the center conductor to migrate
closer to the shield over time, changing the impedance of the coax,
reducing performance.
In reality, #1 probably doesn't amount to much difference at all due to
the small values involved, but #2 needs to be protected against (heat
shield, etc.)
-Jim 40384
Deems Davis wrote:
adversely affect the performance of these satellited antennas?
Deems Davis # 406
> epoxy don't attenuate RF much more than dust. If you put in carbon
> fiber, or other additives then the situation changes.
> what I use (a bit overkill for the aviation band):
> -Jim 40384
>> requires
>> is a loss due to the fiberglass how big of a loss is it? and what is
>> a 'false positive'? Does the fiberglass affect all spectrums
>> equally? Both of the antennas in my case are receive only and are
>> Deems Davis # 406
Deems Davis
Posted: Sun Sep 16, 2007 2:47 pm Post subject: Fiberglass and antenna placement |
OK Tim, I get it, GPS signals are weak. But the question as to how much
attenuation is attributable to the Fiberglass is not addressed anywhere
in your clips, and still remains. The specified/recommended Commant
Antenna for the HeadsUP XM Weather receiver (used in Avidyne
installations in certified Cirrus 's) comes configured with a gain of
30-34 db. The receiver itself is preset to expect a gain of 22db
(+/-2db). The installation manual actually _recommends/requires_ some
additional attenuation and provides a formula for figuring the amount
available through several different types and lengths (feet & yards) of
coax. Turns out that you need quite a bit of coax to get it down to the
22db range (17-58 ' depending on type of coax) Alternatively you may
use a DC bias passing attenuator in line with the cable itself. (my
choice). The only caution from the mfg about placement was to keep it
away from transmitting antennas, (min 36's").
If, as James suggests, the fiberglass (1/16 - 3/32") of the cowl is not
an issue in signal loss, and there are no other blocking restrictions,
then why criticize someone who wants to make the installation
cosmetically attractive as well? the vast majority of the 396/496
Garmins w/ weather are flying with glareshield mounted antennas with the
same issues.
Deems Davis # 406
Tim Olson wrote:
can easily be blocked by destroying or shielding the GPS receiver’s
antenna. The GPS signal can also be effectively jammed by a signal of
a similar frequency but greater strength. "
signals from the satellites are very weak. Special coding is used to
allow receivers to detect these weak signals, but even with coding,
GPS receivers generally work only if they have a direct line of sight
to the satellites. Performance inside buildings or in an area covered
by foliage is generally quite poor"
from dozens of satellites in space
U.S.! Weaker, in fact, than the
> based systems.
> Deems Davis # 406
Tim Olson
Posted: Sun Sep 16, 2007 3:11 pm Post subject: Fiberglass and antenna placement |
Well, I don't know that you're going to find some place to get
a specific factor of attenuation from having a specified layer of
fiberglass. I was just sorting out some antenna boxes in prep
for sending back my piece of crap Comant 401-620 though, and
read through some install docs where they actually specify things
like installation of the antenna near the leading edge of high-wing
wings, so that during climb they aren't shaded by the wing,
and they specify to mount it where things like the propeller
arc aren't in the way of the antenna's forward and upward view
too. It would seem that during climb, a firewall mounted antenna
could be shaded quite a bit by the engine, and your comments
don't address at all the factors of electrical noise of the
ignition system. It's all just food for thought, since a builder
can do whatever they want.
The sad part is, when looks become more important than function,
it can just lead to someone remarking later after they hear the
bad news "Gosh, and that was such a beautiful plane, too."
The 396/496 w/weather and glareshield mounted antenna's don't even
begin to approach the suitability of a WAAS approved GPS antenna
for flying approaches. Consider that the update rate for doing the
calculations is so much higher, that the receiver really needs to
make sure it has a good incoming data stream, whereas a lesser
performing GPS may get by with more sporadic signals.
Regarding the attenuation, keep in mind that the attenuation in
the cable is going to happen AFTER the active antenna has done
it's notch filtering to reduce the external noise and non-on-freq
"stuff" coming down the pipe.
Oh, and, if the GPS signal quality weren't an issue, why would
Xbow make such noise about how they really want to see people use
some specific models of antenna, mounted in some good locations,
using proper techniques. Seems we have actual known experiences
with their AHRS driving EFIS's screwy from lower-quality GPS
signalling.
It really doesn't matter personally to me how someone does it, as long
as they've thought it through and made an informed choice. Just try
to put yourself into the future though, and say 50 hours into it
you start noticing the GPS just isn't what it should be....how much
harder will it be to RE-mount that stuff in a different location?
If it's no fun now, it's really gonna suck later.
Deems Davis wrote:
same issues.
Deems Davis # 406
> Tim Olson - RV-10 N104CD - Flying
>> based systems.
>> Deems Davis # 406
apilot2(at)gmail.com Guest
Posted: Sun Sep 16, 2007 3:46 pm Post subject: Fiberglass and antenna placement |
Well, I don't know about any of this. I use a little bluetooth GPS that I
toss on the passenger seat. Sometimes I forget and lay my aluminum lapboard
on top of it. Oh, and I have an aluminum roof with steel chrome moly tubing
supporting it. But, I consistently see, 8-9 satellites, no problem. Works
the same laying it on the console in my car. The current generation GPS
chips are truly amazing..oh, and it cost me less than $100 and it feeds my
Anywhere Map just fine. No, nothing certified...but it sure makes my
performance using those antique tools like VOR and NDB look good. And
center didn't ask any questions how my /U airplane was going IFR direct
between 2 VORs 200nm apart.
signalling.
> same issues.
> Deems Davis # 406
someone
the
>> can easily be blocked by destroying or shielding the GPS receiver's
>> "You'd think that with all of these radio waves raining down on us
>> we'd all glow in the dark. Actually, the strength of the GPS signal is
>> ordinary background radio noise that's all around us all of the time."
Tim Olson
Posted: Sun Sep 16, 2007 4:36 pm Post subject: Fiberglass and antenna placement |
Yep, I have a bluetooth GPS on the glareshield that I use with the
tablet PC. You're right, the technology has sure gotten good
on the radios. But, my arguments are only for dealing with
the actual approach certified type stuff like a 430W/530W/480/Freeflight
and that sort of GPS antenna. If someone wants to have lesser quality
weather reception, or try something with their secondary GPS,
I think that's just fine. It's when you want to have the utmost
reliability on your primary navigation equipment that I think it's
prudent to not try to cut any corners and just follow the manufacturers
directions. Your primary nav GPS failing is one of those
experiences that when it happens it would forcibly make you work
really hard to get things back together again to continue the
flight.
Kelly McMullen wrote:
| Quote: | Well, I don't know about any of this. I use a little bluetooth GPS that
I toss on the passenger seat. Sometimes I forget and lay my aluminum
lapboard on top of it. Oh, and I have an aluminum roof with steel chrome
moly tubing supporting it. But, I consistently see, 8-9 satellites, no
problem. Works the same laying it on the console in my car. The current
generation GPS chips are truly amazing..oh, and it cost me less than
$100 and it feeds my Anywhere Map just fine. No, nothing certified...but
it sure makes my performance using those antique tools like VOR and NDB
look good. And center didn't ask any questions how my /U airplane
was going IFR direct between 2 VORs 200nm apart.
On 9/16/07, *Tim Olson* <Tim(at)myrv10.com <mailto:Tim(at)myrv10.com>> wrote:
<mailto:Tim(at)MyRV10.com>>
signalling.
Deems Davis wrote:
<mailto:deemsdavis(at)cox.net>>
how much
anywhere
gain of
amount
yards) of
to the
may
is not
restrictions,
with the
> same issues.
> Deems Davis # 406
choose
never
we pride
someone
antenna
and the
about
signal of
sorry, but
and VOR
sacrifice?
used to
sight
covered
fact, that
noise. The
<http://www.dot.nd.gov/manuals/surveymanual/gps-operations.pdf>
signal is
time."
thought is:
airplane, but
wonder. And
good
universal
Garmin
answer.
advice.
yeah,
>> Deems Davis wrote:
<deemsdavis(at)cox.net <mailto:deemsdavis(at)cox.net>>
loss. It is
requires
when you
there is
is a
equally?
>>> based systems.
>>> Deems Davis # 406
>sp; - The RV10-List Email Forum - content now also
available via the Web Forums! =====================
AV8ORJWC
Posted: Sun Sep 16, 2007 4:40 pm Post subject: Fiberglass and antenna placement |
Now you guys are getting with the program. Coax length, inline
connectors, combiners, splitters and fiberglas thickness equate to db
signal losses.
John #600
Deems Davis
Posted: Sun Sep 16, 2007 4:54 pm Post subject: Fiberglass and antenna placement |
OK, I just redesigned my antenna installation : atop a 5 foot tall
pylon, made of spaceage transpardium mounted in the exact center/top
point of the cabin cover, equipped with a gyro stabilized gimble that
ensures stability of the antenna in all unusual attitudes.
I'm out of here
signal losses.
John #600
ricksked(at)embarqmail.co Guest
Posted: Sun Sep 16, 2007 5:37 pm Post subject: Fiberglass and antenna placement |
That was my reason for using the location I picked for my GPS antenna. Although I really like the under the cowl stuff, I also have a 480 and I didn't want any sacrifice in it's GPS capability by degradading the antenna performance even the slightest. I'm not sure if it WOULD under the cowl but I was pretty sure it WOULD NOT mounted on top of the fuselage.
Rick S.
40185
dc71(at)netspace.net.au Guest
Posted: Sun Sep 16, 2007 6:10 pm Post subject: Fiberglass and antenna placement |
After a real world test of holding a handheld GPS under the
On 17/09/2007, at 6:47 AM, Deems Davis wrote:
much attenuation is attributable to the Fiberglass is not addressed
anywhere in your clips, and still remains.
Posted: Sun Sep 16, 2007 6:12 pm Post subject: Fiberglass and antenna placement |
After a real world test of holding a handheld GPS under the cabin top
then the cowl while watching the Satellite signal strength page, I'm
convinced that there is some attenuation from fibreglass - whether
it's significant or not is up to the individual builder. Personally I
have installed my antennae outside the cabin top.
Indran
poneill(at)irealms.com Guest
Posted: Sun Sep 16, 2007 9:02 pm Post subject: Fiberglass and antenna placement |
This comes as a huge relief. I thought I was the only one planning to equip
their RV-10 with AWACS.
Patrick
#40715
rvbuilder(at)sausen.net Guest
Posted: Mon Sep 17, 2007 6:46 am Post subject: Fiberglass and antenna placement |
Deems, make sure you rip all the fiberglass and plastic covering off those certified antennas too. I think the most useful tip I have got out of this string so far is don't by anything from Commant except for maybe VHF and Transponder. Not a surprise as when I have asked them questions in OSH they basically gave me a hand out, promptly ignored me, and walked away when they had no one else at their booth.
Part of the reason that people are seeing better reception from the Bluetooth "bugs" is because they are using much newer technologies than the "certified" antennas. Does that surprise anyone that the certified vendors are probably not really doing anything to improve the antennas because of the hassle to get them recertified. Anyone else remember the horrors stories of the older certified units giving the RAIM messages, usually at the worse possible times?
At this point I will probably have no less than 3-4 satellite antennas performing various functions. Some will be under the canopy and some may not. Depends on how well they function and how important they are. Will I stick an antenna for a Garmin x96 on the outside? Not a chance. But for primary navigation WAAS GPS, potentially. But only after I test it out.
So while everyone is super concerned about if the 1/4" of fiberglass is attenuating the GPS signal in the UHF L Band microwave range (in which most outdoor antennas are protected by fiberglass or ABS plastic), has anyone actually looked at exactly how far they are running those antenna leads? Depending on the cable type you can probably figure a loss of 0.5db for every meter of cable. Or how about if your Bluetooth, cell phone, oscillation of that laptop clock, or RF noise from your various "uncertified" personal electronics are causing any interference in your nav systems that could induce an error? So who wants to volunteer to do a SNR study for GPS locations on the RV-10 along with the factory coverings of said antennas?
Just for the record I have a pair of Commant CI-121 Comm antennas, a pair of archer wingtip antennas for nav, and a Commant CI-105 transponder antenna.
Michael
AV8ORJWC
Posted: Mon Sep 17, 2007 2:17 pm Post subject: Fiberglass and antenna placement |
Don't forget the five degree forward cant to compensate for your
additional forward airspeed with the BPE Cold Air/Davis Induction
System.
Thanks for playing.
John
Posted: Mon Sep 17, 2007 3:15 pm Post subject: Fiberglass and antenna placement |
And the drag coefficent associated with the forward cant must also be considered as well as gyroscopic precession due to the drag in the gimble, unless your going with magnetic suspension of the ring then your precession may not be significant given the fuel onboard and the total time from alignemnt to shut down after stopping to pee. lol....
Rick S.
40185
please do not archive
Posted: Tue Sep 18, 2007 7:01 am Post subject: Fiberglass and antenna placement |
You also need to figure out how to design a mechanism that will keep the lowest drag profile aligned with the relative wind.
I'm still trying to work out how to form a singularity to power an inertial dampener and gravity drive. Then I can bolt a snow plow to the front if I want and pull 50G's. Heh.
Posted: Tue Sep 18, 2007 9:38 am Post subject: Fiberglass and antenna placement |
I think my antennas might cause a bit too much drag:
[img]cid:part1.00020908.02090002(at)arrl.net[/img]
The vertical antenna on the top is a tri-band 2m, 6m, and 70cm and encased in fiberglass (15ft. tall); The main antenna is a log periodic 13-33MHz - As for scale, the boom length is just over 30 feet, longest element is 32 feet.
The plane? Oh yeah.... I should get back to that....
-Jim 40384 do not archive.
RV Builder (Michael Sausen) wrote: [quote] [quote]--> RV10-List message posted by: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net> (rvbuilder(at)sausen.net) You also need to figure out how to design a mechanism that will keep the lowest drag profile aligned with the relative wind. I'm still trying to work out how to form a singularity to power an inertial dampener and gravity drive. Then I can bolt a snow plow to the front if I want and pull 50G's. Heh. Do not archive --
14.65 KB |
372 Time(s) |
