georgerace
Posted: Wed Aug 15, 2007 6:01 am Post subject: CH701 Flap Actuator |
I wonder if anyone has successfully installed a electric flap actuator system in the CH701.
If so, what components and from whom did you acquire them.
Any ideas on how many pounds of force it may take, especially when extending them in flight.
George
_________________ Check out my CH-701 project at:
http://www.mykitairplane.com |
dougsnash(at)yahoo.com Guest
Posted: Wed Aug 15, 2007 6:50 am Post subject: CH701 Flap Actuator |
George, I am installing the a SPAL linear actuator
from Surlus Center. I have not completed the
installation yet but am working on some of the
details.
SPAL also makes a controller box that will give you
three preset positions. I am also planning on using
this controller setup.
Unfortunately, that is all of the information I have
at this time.
Doug MacDonald
--- George Race <mykitairplane(at)mrrace.com> wrote:
| Quote: | I wonder if anyone has successfully installed a
them.
them in flight.
George
http://smallbusiness.yahoo.com/webhosting
txpilot
Posted: Wed Aug 15, 2007 5:44 pm Post subject: Re: CH701 Flap Actuator |
George,
I am also using the SPAL linear actuator from Surplus Center. The actuator is rated at 110 pounds with a 550 pound static load. Although I don't have my plane flying yet, I'm confident it's plenty of force for the flaps.
I decided to mount the flap motor on the front of 7F6-1 in line with the bottom of the flaperon control mount. It is bolted to the Flaperon control mount with an AN4-20 in the same place the flaperon control lever would normally go. The position is ideal because it allows easy access and maintenance to the motor through the rear access panel. I ran the idea past ZAC and they suggested adding a doubler to reinforce the channel 7F6-1 and a gusset between 7F6-1 and the z bracket around the access hole. This is to prevent twisting of the channel during flap operation.
I'll try to send pictures and the plans I sent to ZAC, although they're not that great. Good Luck on your project.
Dan Ginty
631.85 KB |
596 Time(s) |
602.37 KB |
654 Time(s) |
619.3 KB |
601 Time(s) |
232.51 KB |
576 Time(s) |
georgerace
Posted: Thu Aug 16, 2007 6:20 am Post subject: CH701 Flap Actuator |
Great information! Will follow up and see if I can find Surplus Center stuff.
Pictures of your install would be greatly appreciated.
Again, thanks for all the great info.
This list is a great resource!
George
