kj7sr(at)earthlink.net Guest
Posted: Fri Jul 06, 2007 8:40 am Post subject: Fuel Transfer |
I am having trouble getting fuel from my wing tanks to transfer to the main tank. I put forward facing tubes from the fuel caps into the airstream but they don't seem to pressurize the tanks enough to permit transfer. I was thinking of putting siphon bulbs such as from boat remote tanks into the fuel lines in the cabin. I would appreciate any other ideas.
Chuck Bloom
Missoula, MT
Kitfox Model 1 #8
Rotax 503
clemwehner(at)sbcglobal.n Guest
Posted: Fri Jul 06, 2007 9:28 am Post subject: Fuel Transfer |
This comes up every few years. About 6-8 years ago we had a discussion about increasing the pressure in the tanks. I did an experiment of taking a fuel cap and putting a little funnel on the end of the tube facing into the wind. I hooked my airspeed indicator to the tube, then used my leaf blower and blew air at it at 80 MPH. Then I took the funnel off and the airspeed went down. Funnel on-more airspeed, funnel off-less airspeed. The funnel seems to catch more wind and increase the pressure in the fuel cap tube. Try it yourself. I used little plastic funnels that my doc gave me. They go on the little scope that he looks into your ears with), but you could make a little funnel out of anything, even cardboard to try the experiment.
Clem Wehner (the other Clem) Hmmmm, what's the chances of 2 Clems on this list?
KFIV,912
Lawton OK
msm_9949(at)yahoo.com Guest
Posted: Fri Jul 06, 2007 11:44 am Post subject: Fuel Transfer |
Hi Charles.
What happens when you try to blow through the fuel cap vents?
Charles Bloom <kj7sr(at)earthlink.net> wrote:
[quote] I am having trouble getting fuel from my wing tanks to transfer to the main tank. I put forward facing tubes from the fuel caps into the airstream but they don't seem to pressurize the tanks enough to permit transfer. I was thinking of putting siphon bulbs such as from boat remote tanks into the fuel lines in the cabin. I would appreciate any other ideas.
Chuck Bloom
Missoula, MT
Kitfox Model 1 #8
Rotax 503
[quote][b] Ready for the edge of your seat? [url=http://us.rd.yahoo.com/evt=48220/*http://tv.yahoo.com/]Check out tonight's top picks[/url] on Yahoo! TV. [quote][b]
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Fri Jul 06, 2007 12:20 pm Post subject: Re: Fuel Transfer |
Chuck,
My fuel transfer is too slow to suit me also, and the wing tank flow stops easily, especially when the fuel is low. The transfer flow varies from about 8 to 13 gallons per hour.
I have a right wing tank that transfers to the panel tank. The fuel line is 1/4 in. ID urathane. The line runs from the wing tank forward above the door and down the diagonal fuselage tube to the panel tank. There is a shut off valve and an in line filter in the line. The panel tank vent line runs to the top of the wing tank.
I think the in line filter is restricting the flow some but believe the biggest cause of the problem is not enough down slope in the line from the tank to where it starts down the diagonal tube.
The kitfox fuel systems that I know of that worked well all ran the fuel line from the wing tank imediately down behind the seat, forward under the seat and door then back up to the panel tank. I have not gone with that route because I don't like the idea of that significant low spot in the line that could collect water and maybe even freeze.
I keep looking for some 5/16 ID urathane fuel line to try but no luck so far. There is plenty of 5/16 rubber fuel line on the market but I am using premix oil in the fuel and have heard that the oil will deterioriate the
rubber fueline.
746.55 KB |
557 Time(s) |
768.77 KB |
546 Time(s) |
_________________ Tom Jones
Classic IV
Ellensburg, WA |
Float Flyr
Posted: Fri Jul 06, 2007 12:40 pm Post subject: Fuel Transfer |
By main tank I assume you mean a panel tank. It may need a vent, possibly rear facing above the level of the wing tank to allow fuel to flow down into it.
Do you have a vent on your main tank?
[img]cid:772442619(at)06072007-1285[/img]
Noel Loveys, RPP, AME intern
Campbellton, Newfoundland,
Canada
Kitfox Mod III-A, 582, B box, Ivo IFA
Aerocet 1100s
noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)
19.77 KB |
507 Time(s) |
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
n981ms(at)yahoo.com Guest
Posted: Fri Jul 06, 2007 12:48 pm Post subject: Fuel Transfer |
I suspect something is wrong with your system. Gravity should feed the main tank and I would hesitate to depend on anything else. I would check every line into and out of every tank for obstruction. I think you will find one some where. Fluid will flow down hill if it has vacuum relief above.
Maxwell
S6 TD IO240
Marco Menezes <msm_9949(at)yahoo.com> wrote:
[quote] Hi Charles.
[quote] I am having trouble getting fuel from my wing tanks to transfer [url=http://us.rd.yahoo.com/evt=48250/*http://searchmarketing.yahoo.com/arp/sponsoredsearch_v9.php?o=US2226&cmp=Yahoo&ctv=AprNI&s=Y&s2=EM&b=50]Pinpoint customers [/url]who are looking for what you sell. [quote][b]
john(at)leptron.com Guest
Posted: Fri Jul 06, 2007 2:59 pm Post subject: Fuel Transfer |
I put a "t" in the line at the low spot and installed a fuel drain at that
point"
John Oakley
"I have not gone with that route because I don't like the idea of that
freeze."
pwmac(at)sisna.com Guest
Posted: Fri Jul 06, 2007 6:42 pm Post subject: Fuel Transfer |
Very true especially if you have a non standard header tank. The M4
header has a low point over an inch below the outlet so a tee in the
outlet line should present no problem.
Paul
At 04:58 PM 7/6/2007, you wrote:
point"
John Oakley
freeze."
You are correct that you have resistance to flow in your gravity
lines. Technically 3/8" would be the proper size. I think the
manufacturer is way marginal with the specified 5/16" lines. Anyway
make sure you have no high points where a a vapor/air bubble can
collect, and that the line gradually goes down hill.
Of course nobody uses rubber for fuel lines. Regular automotive fuel
lines are pretty impervious to any hydrocarbons like 2-stroke oil. Go
to the auto store and get SAE R-7 hose in as big as is practical for
your application. If you have a filter between the tank and the
header, please remove it, and same for the valve. Very bad practice
to have pressure loss devices in a critical place as a gravity feed
system. If you think you must have a valve go to a 3/8" size as it
orifice should be adequate. The hardware store valves work
fine, just find the correct fitting to adapt to the chosen hose.
Last of all make sure your vend is free of any restrictions.
Regards, Paul
At 02:20 PM 7/6/2007, you wrote:
Chuck,
even freeze.
rubber fueline.
Tom Jones
Classic IV, Phase one
Ellensburg, WA
http://forums.matronics.com/viewtopic.php?p=122543#122543
http://forums.matronics.com//files/fuel_line_2_710.jpg
http://forums.matronics.com//files/fuel_line_1_185.jpg
7suds(at)Chartermi.net Guest
Posted: Sat Jul 07, 2007 4:42 am Post subject: Fuel Transfer |
Tom,
On my model 4 I ran 2 wing tanks and a 10 gal panel tank. The wing tanks
were plumbed into the top of the panel tank with 1/4 tygon tubing that ran
down the inside forward door post. Each wing tank had a shutoff and the
panel tank was vented back to the right wing tank. After I filled the wing
tanks I had a piece of tygon tubing I would put on the cap and gently blow
until the line was flowing full and then shut off, then when I was flying
and wanted to transfer I opened the wing valve and would get solid flow, if
I ever lost flow in flight I was normally able to slip and get it folwing
again. I did an experiment once and removed the vent line from the wing tank
and put it up through the top right rear canopy, thus allowing the ram
pressure from the wing tank cap to pressurize the tank and not the return
vent, flow was great but I opted not to leave it that way in case I would
start transfer and forget I could be pushing fuel out of the plane, I also
pre mixed.
(do not archive)
Lloyd
Rebuild
Mod 5 912ul
UP Mi.
Guy Buchanan
Posted: Sat Jul 07, 2007 11:41 am Post subject: Fuel Transfer |
At 09:38 AM 7/6/2007, you wrote:
| Quote: | I am having trouble getting fuel from my wing tanks to transfer to
permit transfer.
Unfortunately, the forward facing vents do not usually promote
transfer as they pressurize the system end to end. They do increase
the pressure at the outlet, which is good, and help if there is some
kind of obstruction that generates a significant internal pressure drop.
| Quote: | I was thinking of putting siphon bulbs such as from boat remote
As offered by others, first go through and check your lines. Pull
both ends and blow. Any significant resistance should be checked out.
There have been fuel lines that swelled shut internally, with no
evidence externally. If everything checks out, check your line sizes.
I use 3/8" from the wing tanks to the header and on to the fuel
valve. From there I go to 1/4" to the pump and on to the carbs. The
exception is that my header vent is 1/4". Check your routing for
losses. These will be in the form of excessive line length, too many
elbows, too many junctions. You already heard about the filters. I
wouldn't take such an extreme position, but I would recommend that
any filter in the gravity side of the system have a negligible
pressure drop. (I.e. use BIG filters. I use a huge race car filter
just after my header tank.) I think the ideal fuel line is bent
aluminum tube. You can use large sizes, the inside is smooth, bends
are smooth, it lasts a long time, (assuming it's mounted correctly,)
and it's light. It's also pretty easy to install.
Guy Buchanan
San Diego, CA
_________________ Guy Buchanan
Deceased K-IV 1200
A glider pilot too. |
