GRT AHRS and Magnetometer mounting
toaster73(at)earthlink.ne
PostPosted: Sun Jun 03, 2007 6:23 pm    Post subject: GRT AHRS and Magnetometer mounting Reply with quote
I saw in the archives Bob Condrey mounted the magnetometer in the tailcone and the AHRS on a shelf behind the instrument panel. I like this arrangement but have a question...Bob how did you comply with the +/- 1/2 degree pitch alignment between the two boxes? What is the 10's level line? Any other pictures or comments appreciated.
Also wondered if anybody thinks it possible to mount a bent whip in the tunnel between the rear seats without bothering flight controls. Perhaps off to one side? I like having access to things down the road, I really dislike these closed off for good areas.
THanks
Chris Lucas
#40072... skipping all around the fuselage
ScooterF15
PostPosted: Mon Jun 04, 2007 2:36 am    Post subject: GRT AHRS and Magnetometer mounting Reply with quote
I mounted my marker beacon antenna between the rear seats. No problem with pushrod or rudder cable interference. I mounted the bent whip antenna under the passenger seat. You don't want the bent whip antenna too far aft as it will get closer to the ground during takeoff rotation and landing flare / aerobraking the further back you mount it. Pictures attached.
-Jim
Jim "Scooter" McGrew
http://www.mit.edu/~jsmcgrew
In a message dated 6/3/2007 10:25:53 P.M. Eastern Daylight Time, toaster73(at)earthlink.net writes:
THanks
Chris Lucas
See what's free at AOL.com.
 Filesize:  78.99 KB
 Viewed:  561 Time(s)
 Filesize:  56.97 KB
 Viewed:  540 Time(s)
 Filesize:  77.06 KB
 Viewed:  561 Time(s)
jesse(at)saintaviation.co
PostPosted: Mon Jun 04, 2007 4:46 am    Post subject: GRT AHRS and Magnetometer mounting Reply with quote
I don’t think between the rear seats is a good place for an antenna. The control rod is so low there that I think it would be too risky to have anything sticking up from the belly skin there. One possibility for a bent whip is to put it under the baggage floor (with nutplates in the skin), just off center, and then you can either get at it through the lightening holes or you can put in an access panel. I wouldn’t put an access panel under the rear seat floor because there has to be some structural reason that there are no lightening holes in that area. Has anybody had any problems putting them under the front seats, one on either side? I seem to remember someone mentioning that the gear legs can get in the way. We haven’t tested them, but have very good reception with that arrangement.
Jesse Saint
Saint Aviation, Inc.
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of toaster73(at)earthlink.net
Sent: Sunday, June 03, 2007 10:24 PM
Subject: GRT AHRS and Magnetometer mounting
THanks
Chris Lucas
[quote] [b]
LloydDR(at)wernerco.com
PostPosted: Mon Jun 04, 2007 6:15 am    Post subject: GRT AHRS and Magnetometer mounting Reply with quote
It does not matter where the level line is, that will be taken care of during alignment procedures, what does matter is that both are with in the tolerance difference. The easy way to make sure they are the same is to take the smart level device and match the degrees it is saying for both locations. I ordered the smart level from Amazon and got the one with the 4 foot and 2 foot level bars, then you can swap the tool between them and use it stand alone. It made setting travel of elevators/rudders/ ailerons very easy to determine and makes alignment of both the Dynon and Chelton remote magnetometers a non-issue.
just my .02
Dan
N289DT RV10E
THanks
Chris Lucas
PostPosted: Mon Jun 04, 2007 7:32 am    Post subject: GRT AHRS and Magnetometer mounting Reply with quote
On this note, it may be good for all Dynon customers to know that the Dynon magnetometer needs to be very close to the same orientation as the unit. Dynon says that it needs to be within a degree in all directions. Dan, can you post a picture of your installation on this?
Thanks.
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Lloyd, Daniel R.
Sent: Monday, June 04, 2007 10:15 AM
Subject: RE: GRT AHRS and Magnetometer mounting
just my .02
Dan
N289DT RV10E
THanks
Chris Lucas
[quote] href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-Listhref="http://forums.matronics.com">http://forums.matronics.com [b]
bcondrey
PostPosted: Mon Jun 04, 2007 7:50 am    Post subject: Re: GRT AHRS and Magnetometer mounting Reply with quote
I can't take pictures right now because I'm out of town on a biz trip but can take some next weekend if you don't get your questions answered by then.
The magnetometer is aligned to the center J channel in the tailcone and is mounted to the adjacent J channels. I made "hangers" out of .032 and made an alum angle tray that the magnetometer is mount to. The tray was mounted and then I used plum bobs to align the mount holes for the yaw axis. I went as close to the top as possible to maximize distance from the AP roll servo and battery contactors (I have 2). Pitch iand roll axis was rerenced to the longerons and using a digital level.
The AHRS is mounted on a tray that is attached to the right panel rib between the subpanel and firewall. It uses the panel rib for yaw axis and and the upper aluminum firewall structure for roll axis. Pitch axis was set and other axis confirmed with a digital level.
Bob
PostPosted: Mon Jun 04, 2007 9:24 am    Post subject: GRT AHRS and Magnetometer mounting Reply with quote
Will do, as soon as I mount the wing next week for the final time, right now they are still in the cradle waiting for the fuse to come back from paint. What I did was to measure the Dynon as it sits in the panel and replicated the angel offset with the smart tool and used the remote mount unit from Safeair to put it out on the last rib of the wing. I will post the pics next week when I get to the airport.
Dan
N289DT RV10E
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint
Sent: Monday, June 04, 2007 11:32 AM
Thanks.
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
just my .02
Dan
N289DT RV10E
THanks
Chris Lucas
0 [quote][b]
PostPosted: Mon Jun 04, 2007 1:42 pm    Post subject: GRT AHRS and Magnetometer mounting Reply with quote
Thanks for the replies. I get the idea now. Pictures are not necessary,
Bob, unless you feel compelled to share.
Jesse, are you saying you have been mounting the bent whip under the front
seats in your planes, with no com problems in flight, at least none detected
thus far via normal operation etc .etc.?
Chris
#40072
PostPosted: Mon Jun 04, 2007 2:24 pm    Post subject: GRT AHRS and Magnetometer mounting Reply with quote
Yes, that is what I am saying. Again, we haven't done the technical testing
that others have mentioned, but we are quite happy with the placement,
reception on the ground and in the air, and the aesthetics.
Jesse Saint
jesse(at)saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
PostPosted: Tue Jun 05, 2007 5:13 pm    Post subject: GRT AHRS and Magnetometer mounting Reply with quote
Great, Thanks
-Chris
