wayne.e(at)grandecom.net Guest
Posted: Fri May 18, 2007 3:53 am Post subject: Start your engine |
There comes a time with every builder when he or she hears someone deep inside the hangar say "Gentlemen start your engine" :>} and today was that day for me. I was able to roll the plane out of the hangar and fired this bird up. There were a few small glitch's, like you've got to remember to turn on the fuel value :>}
I had trouble with my EI engine monitor going off line each time I tried to start the engine. We ended up putting an analog gauge on the engine for oil pressure and forged on. The EI unit has a know problem that when there is a voltage drop, like starting the engine, the unit shuts down. But as soon as the engine starts it comes back on line. I have to send the unit in for an update to it to fix the problem. The RPM was also acting goofy. Hell at one point I got 3800 RPM. This problem was to do with the Lazar system emitting to much interference and they are sending me out a noise filtering unit to fix that problem.
We had to adjust the mixture and idle a couple of times, luckily for me a neighbor on the field and a good friend is great with engines so he saved my bacon.
One other problem I ran into was that my battery wouldn't turn over the engine enough to start it so we had to jump start it with battery cables. I'm overnight charging the battery but I think the battery is either going or already gone to battery heaven. It's a new Odyssey battery !
Anyway I thought I would report my progress. I've attached a couple of pictures for your perusal.
Small RV grin in place right now with a bigger one hopefully to follow shortly :>}
Wayne Edgerton #40336
263.69 KB |
340 Time(s) |
192.28 KB |
351 Time(s) |
247.09 KB |
346 Time(s) |
rvbuilder(at)sausen.net Guest
Posted: Fri May 18, 2007 4:51 am Post subject: Start your engine |
Just a reminder to anyone using Odyssey style batteries, they do not like being run flat. Check them every couple months to make sure they are topped off and if you are using them for testing I would recommend keeping a charger on them to make sure they are full. They keep their charge exceedingly well when in storage but they still need to be checked. If you run them flat they are basically a paperweight.
And congratulations Wayne, that’s another big milestone!
Michael Sausen
-10 #352 Limbo
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Wayne Edgerton
Sent: Friday, May 18, 2007 6:49 AM
Subject: Start your engine
apilot2(at)gmail.com Guest
Congrats. My UBG16 manual specifically requires it to be off during
start. Only takes it about 5 secs to boot up when I switch it on.
On 5/18/07, Wayne Edgerton <wayne.e(at)grandecom.net> wrote:
fix that problem.
bacon.
shortly :>}
Deems Davis
Posted: Fri May 18, 2007 5:01 am Post subject: Start your engine |
Good Work Wayne! Congratulations, keep us all posted, on your progress
as it's inspiring to those of us following behind you.
THANKS
Deems Davis # 406
Finishing - ( A Misnomer ! )
http://deemsrv10.com/
Wayne Edgerton wrote:
| Quote: | There comes a time with every builder when he or she hears someone
shortly :>}
flysrv10(at)gmail.com Guest
Posted: Fri May 18, 2007 5:13 am Post subject: Start your engine |
At the risk of starting a battery brand war, I would like to offer an alternative to Odessey.
I have been using Sears handicap battery for 15 years in my planes. This battery, combined with a L model Skytech starter, will crank your IO540 for ever (especially when you have trouble with Hot Starts). I have actually never seen the end of the life on this battery, I just replace it every three years as a precaution. This battery costs less, lasts longer, It is available to pick up 7 days a week and if you let it go flat, you just recharge it. Another bonus is that it fits the existing battery tray in all RVs without any modifications.
I have seen enough neighbors with Odessey batteries laying on shelf as "Paper Weight".
Do not archive.
Rob
On May 18, 2007, at 8:50 AM, RV Builder (Michael Sausen) wrote:
And congratulations Wayne, thats another big milestone!
Michael Sausen
-10 #352 Limbo
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Wayne EdgertonSent: Friday, May 18, 2007 6:49 AMTo: rv10-list(at)matronics.com (rv10-list(at)matronics.com)Subject: Start your engine
AV8ORJWC
Posted: Fri May 18, 2007 6:39 am Post subject: Start your engine |
Wayne that is most encouraging news and well appreciated here. Is that a custom painted AeroComp propeller and what did the whole thing weigh as installed? It makes me excited to think of your final paint job coming.
John #600
Sent: Friday, May 18, 2007 4:49 AM
Posted: Fri May 18, 2007 6:51 am Post subject: Start your engine |
Weight?
Jesse Saint
Saint Aviation, Inc.
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kermanj
Sent: Friday, May 18, 2007 9:13 AM
Subject: Re: Start your engine
Do not archive.
Rob
-10 #352 Limbo
From:There comes a time with every builder when he or she hears someone deep inside the hangar say "Gentlemen start your engine" :>} and today was that day for me. I was able to roll the plane out of the hangar and fired this bird up. There were a few small glitch's, like you've got to remember to turn on the fuel value :>}
| Quote: | | - NEW MATRONICS WEB FORUMS - class="Apple-converted-space"> --> http://forums.matronics.com[/b] http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.com |
Posted: Fri May 18, 2007 7:07 am Post subject: Start your engine |
Congratulations! Have you already had your inspection? If not, when? I will respond below.
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
Sent: Friday, May 18, 2007 7:49 AM
There comes a time with every builder when he or she hears someone deep inside the hangar say "Gentlemen start your engine" :>} and today was that day for me. I was able to roll the plane out of the hangar and fired this bird up. There were a few small glitch's, like you've got to remember to turn on the fuel value :>}[Jesse Saint] Isn’t that a great feeling? You’re not the first one on the fuel valve issue.
[Jesse Saint] This is a great time to mention the settings on the RPM gauge on anybody’s engine monitor. We have had times that it read way low and we couldn’t figure out why it wasn’t getting full power and then realized that the sensor setting on the EMS was not correct. Before changing anything with the Prop Governor or engine, get a visual tach, point it at the prop and see what you are getting. That can help avoid big problems. Of course, if you are reading higher than you are spinning, then it is not necessarily as dangerous, but you still want to fix the reading before you start adjusting. On the engine monitor, if the option is available to have a backup battery, that is always a good way to go so you can have it on when you start. I run my EFIS/EMS as the only instrument that comes on with the master so it will be on for starting.
Heavier than Odessey but don't know how much. Go to a Sears store and check one out.
Do not archive.
On May 18, 2007, at 10:49 AM, Jesse Saint wrote:
Weight?
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Rob KermanjSent: Friday, May 18, 2007 9:13 AMTo: rv10-list(at)matronics.com (rv10-list(at)matronics.com)Subject: Re: Start your engine
Do not archive.
Rob
-10 #352 Limbo
[b][b][b][b][b]012[b][b][/b][/b][/b][/b][/b][/b][/b][/b]34[b][b][b][b][b][b][b][b][b][b][b][/b][/b][/b][/b][/b][/b][/b][/b][/b][/b][/b]
[b][b][b][b][b][b][b][b][b][b][b]5[/b][/b][/b][/b][/b][/b][/b][/b][/b][/b][/b][/b] |
sam(at)fr8dog.net Guest
Posted: Fri May 18, 2007 8:15 am Post subject: Start your engine |
What's the Sears part #, I wan't one!
Sam Marlow
Rob Kermanj wrote:
| Quote: | At the risk of starting a battery brand war, I would like to offer an
"Paper Weight".
Do not archive.
Rob
> paperweight.
> Michael Sausen
> -10 #352 Limbo
> *From:* owner-rv10-list-server(at)matronics.com
> [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Wayne
> Edgerton
> *Sent:* Friday, May 18, 2007 6:49 AM
> *To:* rv10-list(at)matronics.com <mailto:rv10-list(at)matronics.com>
> *Subject:* Start your engine
> he saved my bacon.
> battery !
> follow shortly :>}
> * - The RV10-List Email Forum - class="Apple-converted-space"> --> http://www.matronics.com/Navigator?RV10-List - NEW MATRONICS WEB FORUMS - class="Apple-converted-space"> --> http://forums.matronics.com*
Posted: Fri May 18, 2007 10:43 am Post subject: Start your engine |
Don't have a part number. Ask for a "Wheelchair" battery at Sears.
It should be about $60 Box.
Do not archive.
On May 18, 2007, at 12:13 PM, Sam Marlow wrote:
Sam Marlow
> Do not archive.
> Rob
>> Michael Sausen
>> -10 #352 Limbo
>> *From:* owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-
>> list-server(at)matronics.com] *On Behalf Of *Wayne Edgerton
>> fuel value :>}
>> follow shortly :>}
KiloPapa
Joined: 24 May 2006 Posts: 142 Location: Pearblossom, CA
Posted: Fri May 18, 2007 8:23 pm Post subject: Start your engine |
Good info.
Kevin
40494
tail/empennage
_________________ Kevin
40494
do not archive |
capsteve
Joined: 09 Jan 2006 Posts: 111 Location: NIAGARA FALLS NY
Posted: Fri May 18, 2007 10:10 pm Post subject: Start your engine |
It’s odd but my experience has been quite different. I’ve killed the pc680 in my 6a at least 5 times since completion in 2001. and I’m talking leaving the master on for days before I notice…when I show up to fly I smack my forehead (doh!) throw the charger on for a while ,then go flying…. Now, ,I noticed it does take a bit longer than a wet cell battery to take an initial charge, similar to a deep cycle, but it will come around.. I don’t normally test my batts to find discharge rates over time, but I do expect them to work well after a week of sitting out in a western ny winter. If they pass that test their still good. (imho). I’ve been using this type of batt almost daily in the auto customs we put together, everything from audio, hydraulics, rv’s and travel trailers, and have been convinced that this is the best technology we have to date. Just a fyi….kenetik battery makes a 26 lb 800 agm batt that fits the rv10 battery tray almost perfectly.
Specifications
Weight: 26 lbs.
Ah: 36
Amps: 950
Dimensions: 7.6" x 5" x 6"
Steven dinieri
Iflyrv10.com
40205
Michael Sausen
-10 #352 Limbo
james.k.hovis(at)gmail.co Guest
Posted: Sat May 19, 2007 3:51 am Post subject: Start your engine |
I've had good luck with sealed lead acid batteries in another
application from these guys:
http://www.batterymart.com/c-sealed-lead-acid-batteries.html
Not sure what AHr rating you'd need for Lyc engine starting.
Kevin H.
On 5/18/07, Rob Kermanj <flysrv10(at)gmail.com> wrote:
Do not archive.
> Sam Marlow
>> Do not archive.
>> Rob
>>> And congratulations Wayne, that's another big milestone!
>>> Michael Sausen
>>> -10 #352 Limbo
>>> fuel value :>}
>>> follow shortly :>}
