bwalker11(at)charter.net Guest
george(at)gesoco.com Guest
Posted: Mon Feb 06, 2006 5:54 am Post subject: ELT |
I take it to mean that while exhibiting the aircraft it is not necessary. I would assume that during the "proficiency flight" you do need one. I would hate to argue the point with an FAA official.
George Coy
President
Gesoco Industries Inc.
629 Airport Rd.
Swanton, VT 05488
TEL 802-868-5633
FAX 802-868-4465
Web Site www.gesoco.com
e-mail George(at)gesoco.com
Franklin County Airport (KFSO) [quote] --
dsavarese(at)elmore.rr.co Guest
gus.fraser(at)gs.com Guest
Posted: Mon Feb 06, 2006 6:45 am Post subject: ELT |
But the obvious next question is why would you not have one. Even though the chances of the school kids with revolving antennas finding me is remote it is better than nothing.
Gus
[quote] From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of A. Dennis Savarese
Sent: Monday, February 06, 2006 8:57 AM
To: yak-list(at)matronics.com
Subject: Re: ELT
Bill,
Not required per 91.207 (f) ( . DAR's or FAA Inspectors would not issue Airworthiness Certificates and OL's if they were a required piece of equipment and were not installed.
Dennis
BasiliereR(at)ci.boulder. Guest
Posted: Mon Feb 06, 2006 7:05 am Post subject: ELT |
The added weight...
times 9.5 g's = a bunch :0)
Gus
Subject: Re: ELT
Bill,
Dennis
My thoughts also. Now if you are carrying that new fangled GPS locator beacon. And, you are have the physical capacity to activate it after bouncing off terra firma, the rotor heads will find you alittle faster.
Doc
cjpilot710(at)aol.com Guest
Posted: Mon Feb 06, 2006 7:57 am Post subject: ELT |
Gus and all,
Though it may not have your intentions to down play CAP cadets abilities with directions finders looking for an ELT, I have to step up for them. For 13 years I was the senior cadet commander for the Danbury Squadron. I watched a number of my cadets go off the to different academies and on to productive lives. The proudest moments in my life was watching these school kids after very little training, do some remarkable things. When it came to direction finders, they were tenacious at times. I've seen them track down a discarded ELT in the garbage cans in a very dangerous section of New Heaven. Heard their frustration of trying to find a ELT in a wreck airplane that was on a flat bed truck on it's way to a salvage yard. 99% of the times these ELT's were harping for no reason and the USAF wanted them turned off NOW, often at 2 or 3 am.
The fact of the matter is, IF you go down somewhere remote, the only folks who will come looking for you is the CAP. All volenteers, some good and some not nearly good enough. The only thing paid for by the goverment is the gas and oil during the mission. They don't even pay for the training.
In every real mission I ever participate in the cadets were very much a part of it. If nothing more than checking local airports for the missing plane. But a lot of times the ELT was not and maybe still isn't the best locating machine. They don't work under water (2 missions). They don't work when directly impacted (2 mission) They don't work with dead batteries (1 mission). They are almost impossible to find with the antenna shoved into the ground in the wreckage or under high tension lines (2 mission). And sometimes they are purposely turned off (1 mission that was a murder / suicide).
The ELT? Check and test it often. Keep fresh batteries in it. And pray to God you have some bright, tenacious, pimple face, 14 year old, hot on your trail when things go array. You ain't go'n to find no senator, congressmen, mayor, chief of police, cop, USAF, Navy, or other bureaucracies looking for you.
Jim "Pappy" Goolsby
Gus
Posted: Mon Feb 06, 2006 8:08 am Post subject: ELT |
Jim my comments where more toward the technology and it's limited range rather than the CAP it's self.
Gus
| Quote: | From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of cjpilot710(at)aol.com
Sent: Monday, February 06, 2006 10:55 AM
Subject: Re: ELT
Gus and all,
Jim "Pappy" Goolsby
Gus
Posted: Mon Feb 06, 2006 8:26 am Post subject: ELT |
You can use GPS losat units which have tremendous range. They will give your exact Lat Longs to the SAR team. Problem is that you have to activate it directly. It weighs about as much as your ELT. It is portable, meaning you can throw it in your flight bag. It is registered to you and you have provided all your contact info that stays on file before hand. When it goes off, they will come looking for you good, bad, or indifferent.
Doc
Posted: Mon Feb 06, 2006 8:38 am Post subject: ELT |
Doc,
Do you have any info on suppliers cost etc etc ?
Gus
[quote] From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Roger Kemp
Sent: Monday, February 06, 2006 11:26 AM
Subject: RE: ELT
Doc
jsfox(at)adelphia.net Guest
Posted: Mon Feb 06, 2006 8:50 am Post subject: ELT |
ACR Terrafix available at REI for $699
http://www.rei.com/category/40002202.htm
Steve Fox
On Feb 6, 2006, at 11:37 AM, Fraser, Gus wrote:
[quote] Doc,
Gus
[quote] From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)] On Behalf Of Roger Kemp
Subject: RE: ELT
Doc
fish(at)aviation-tech.com Guest
Posted: Mon Feb 06, 2006 8:54 am Post subject: ELT |
Bill, Dennis and Others,
We have been going around and around about this in the jet world. Yes they are
not required, but lots of times you can not get an airworthiness cert without
one. If it makes the FAA happy, and gets you your cert, then install one. It
is much cheaper then fighting with them.
Fly Safe
John Fischer
Bill,
Not required per 91.207 (f) ( . DAR's or FAA Inspectors would not >issue
Airworthiness Certificates and OL's if they were a required piece >of equipment
[quote]Dennis
Posted: Mon Feb 06, 2006 9:21 am Post subject: ELT |
Gus,
Steve beat me to it. ACR is the unit I have. The price exactly that. The unit is registered with NOAA. It is a SARSAT beacon. It is alittle bulky but at the sametime, it is very portable. If you fly more than one A/C, it will easily go with you.
When going XC over remote territory, I consider it a warm fuzzy. Then you are not worrying about the CAP with a locator DF searching for you. The big boys are coming with a choper for you or a ground SAR team is coming directly to a tree next you in the deep woods if that is where you came to light. The down side is you have to be able to deploy the antenna and push one button.
Doc
Mike Bell
Posted: Mon Feb 06, 2006 9:24 am Post subject: Re: ELT |
Try www.avionicswest.com. Their website has some good info about ELTs and they sell the McMurdo FastFind for about $500. Best bet is a 406Mhz ELT in the plane and a little PLB like the Mc Murdo on your person. Especially if you wear a parachute you want a PLB. The newer 406 ELTs are located hours faster than a 121.5 model, and your position will be resolved down to a few meters rather than a few square miles.
_________________ Mike Bell
Elk Grove, CA
avbell2(at)comcastdotnet |
Posted: Mon Feb 06, 2006 9:53 am Post subject: ELT |
Doc, Steve
Thanks, what exactly is the difference between the two models ? Is it that one has a GPS receiver built in and the other will accept GPS serial data ? There is a $100 difference in cost any ideas ??
Gus
Sent: Monday, February 06, 2006 12:21 PM
Subject: Re: ELT
Gus,
Doc
Posted: Mon Feb 06, 2006 9:56 am Post subject: ELT |
Completely agree.
Dennis
Posted: Mon Feb 06, 2006 10:40 am Post subject: ELT |
Gus,
the website for ACR is info(at)acrelectronics.com (info(at)acrelectronics.com). I am not the expert on these devices. Mine has an external antenna and internal (onboard) gps antenna that you can update the GPS fix with but in an emergency, deploying the beacon antenna will get help.
Doc
BitterlichMG(at)cherrypoi Guest
Posted: Mon Feb 06, 2006 1:54 pm Post subject: ELT |
I have asked the FAA both locally and in 2 others areas, and all three have said that ELT's are not a requirement in Experimental Exhibition Aircraft for any type of flight.
Personally, I think it is entirely reasonable to fly without one, and I take advantage of that rule every time I fly and that's because I have little faith in ELT'S to begin with.
ON THE OTHER HAND, I have a LOT of faith in a 406 Mhz PLB with built in GPS AND a 121.5 transmitter built in (about $660 or so, and you can carry it from plane to plane). If you follow the FAA regs about a ELT install, you have to have things like remote control, automatic G force activation, etc., etc. Many of these things have caused the Civil Air Patrol large amounts of grief.
So ... since I have the option.... and am very glad to have it... I go with the 406 Mhz SARSAT approved, internal GPS carrying Personal Locator Beacon.
Regarding these conversations with the FAA, I was very interested in hearing their viewpoint concerning "carrying passengers in Experimental Exhibition aircraft" was well. For example, a lot of people are getting aerobatic instruction in their YAK52's, or CJ's, etc. etc. Speaking about opening a bag of worms!
My 2 cents only.
Mark Bitterlich
[quote] --
Mike Bell
Posted: Mon Feb 06, 2006 5:42 pm Post subject: Re: ELT |
For some reason my link to Avionics West is no good. Try http://www.avionicswest.com/Emergency/plb.htm#2005.
Elk Grove, CA
Valkyre1(at)comcast.net Guest
Posted: Tue Feb 07, 2006 7:00 am Post subject: ELT |
Just a quick note of agreement. My son was a CAP Cadet rotorhead and so was I. They are generally well trained, dedicated and professional. God bless 'em all. - Val
