		nuckollsr(at)cox.net Guest
				 Posted: Sat Mar 17, 2007 2:52 pm    Post subject: How reliable is reliable |
				At 05:10 PM 3/16/2007 -0700, you wrote:
 Out of curiosity Bob, would you then mainly advocate z-14 for new designs
 with a 20A alternator.  In the past it seems you have suggested z-14 over
 z-12 for people in the planning stages (correct me if I'm wrong).  Maybe a
 z-14 that uses the second bus as a smaller main alt. out e-bus, not used
 for starting...smaller battery...
 In what instance would you use z-12 over z-14 with a 20A alternator? Save
 a little $ and #?
 -Ryan (In the pondering stage)
 To my way of thinking, perhaps 1-2% of all OBAM aircraft
 under construction will be used in ways that justify a
 Z-14 installation. Here's a post I made in 2005 to a similar
 question:
 At 08:46 PM 2/9/2005 +0100, you wrote:
 <snip>
  	  | Quote: | 	 		  Thank you for your thoughtful reply. The 2 batt/2 alt setup (Z11) did get me
 excited but the type of flying (very occasional dusk VFR, no IFR, over water
 at times) plus a common sensical KISS principle to govern decisions may
 dampen my enthusiasm for Z11.
    Let's try to put some things into perspective. There are tons
    of dark-n-stormy night stories wherein alternators and batteries
    are star performers in the role of villain. Given the proven
    reliability of modern automotive alternators . . . in particular
    the converted Nipon Denso products from B&C . . . probability
    of alternator failure is a small fraction of what we've come to
    expect from certified iron. Combine this with the very robust,
    sealed lead-acid batteries -AND- a truly meaningful preventative
    maintenance plan and we've beat the worst worries into submission.
    If one simply installs Van's a-la C-172 wiring with a modern
    alternator and well maintained RG battery, probability of
    having to take a staring role in a dark-n-stormy night play
    due to electrical systems issues is very low.
    By taking advantage of variations on a theme described in the
    z-figures, one can push those probabilities still lower. In
    10+  years of suggesting builders consider the e-bus, I've
    had only one reader write and tell me the e-bus turned an
    alternator failure into a ho-hum event. However, I've had
    perhaps a half dozen people write and thank me for the OVM-14
    crowbar ov module. Far more folks have experienced an ov
    condition that forced alternator shutdown than simple
    alternator failure. I don't recall the numbers of ov
    experiences that benefited from an e-bus installation after
    the alternator was shut off. Even if the builder did not
    have an e-bus, keeping a well maintained RG battery on
    board goes a long way to saving the day.
  	  | Quote: | 	 		  In the final analysis, I think it all boils down to whether I want full
 electronic ignition, partial, or all mags.
   If you go electronic ignition, consider at least one p-mag
   which does not depend on electrical system for operation.
  	  | Quote: | 	 		  I am finishing the wings which means that I have a long way to go - you'll
 see my posts as the situation evolves.
    I have a client with enough funds to strive for the
    "ultimate" system which may include dual efis, dual
    electronic ignition, dual autopilots . . . For the
    moment, I'm still trying to justify ruling out
    a Figure Z-13/8 installation thus saving about a 23
    pound penalty for going with Z-14.
    Reliability doesn't have to be heavy or expensive . . .
    just well considered. Since the e-mag/p-mag guys
    came along, reliability is getting easier, lighter
    and less expensive all the time.
 ------------------ end of quotation -------------------------
    If I owned a certified machine, I would endeavor to
    (1) add ACTIVE NOTIFICATION OF LOW VOLTAGE. (2)
    install and MAINTAIN an RG battery. (3) Modify
    the architecture to turn the avionics bus into an
    E-BUS. (4) When an if the stock alternator craps,
    I'd get a modern automotive adaptation in place.
    These simple changes alone would elevate the spam
    can's SYSTEM reliability by a quantum jump. Implementation
    of an e-bus/bat-maintenance protocol makes the vast
    majority of demonstrated concerns go away. Virtually
    every dark-n-stormy night story I've read that concerned
    electrical systems would never had been written had
    the owner-operators of the subject airplanes availed
    themselves of the knowledge and understanding offered
    to you here on this List.
    Now, if you don't plan to have a vacuum system then
    the vacuum pump pad is open and you'll be many watt-hours
    ahead in planning for alternator failure by adding the
    SD-8 and perhaps even downsizing the battery for a wash
    in weight.
    Z-13/8 is an exceedingly robust system that should
    handle everything you or I would want to do at
    reliability levels that far exceed those of the
    certified ships that we're ALREADY using do do the
    same kinds of flights.
    Now, Z-12 and Z-14 have some appeal but I'd recommend
    Z-12 only as an upgrade to an existing Z-11 or spam-can
    clone and Z-14 for ships like a Lancair IVP with full-up
    dual IFR panels.
    Obviously, if you have the $time$ and don't mind the
    weight, you can pile on as many backups to backups that
    suits your worry levels . . . but I'll suggest that
    Z-13/8 is the value leader in return for reliability
    with the lowest investment in $time$ and loss of
    payload.
    It would cost more dollars and talented manpower than
    you or I are willing to expend to put numbers on the
    relative reliability of Z-13/8 vs Z-14 for the various
    operating scenarios. But it's my considered judgement
    that Z-14 is overkill for most of the OBAM aircraft
    under construction.
		ryan42
				 Posted: Sun Mar 18, 2007 5:20 pm    Post subject: Re: How reliable is reliable |
				 	  | Quote: | 	 		  Z-13/8 is an exceedingly robust system that should
 dual IFR panels.
 payload.
 under construction. |
 That sounds entirely reasonable.  It just seems that by removing the z-13/20 drawing (which I have no problem with), IF the airplane meets the kind of requirements and worry levels to warrent a backup 20 amp alternator, it sounds like you suggest z-14 over z-12 for new ships?
				 Posted: Sun Mar 18, 2007 7:49 pm    Post subject: How reliable is reliable |
				At 06:20 PM 3/18/2007 -0700, you wrote:
  > dual IFR panels.
  > payload.
  > under construction.
     Depends on the airplane and the missions. If you're
     building a long-legged, $200,000 cross country rocket
     and you intend to spend hours crossing weather fronts,
     then something like Z-14 (along with a second pilot
     in the right seat) is the uptown way to go.
     If you have an as-purchased airplane wired ah-la C172/
     A-36 and you'd like to go all-electric with minimal
     changes to the system, then Z-12 is an option to consider.
     If you're starting from scratch and intend to use your
     airplane like 95% of your brothers use their airplanes,
     then I'm betting that Z-13/8 has a high probability of
     meeting your mission requirements at a minimum of
     cost and weight.
         ( IF one aspires to be "world class",  )
         ( what ever you do must be exercised   )
         ( EVERY day . . .                      )
         (                  R. L. Nuckolls III  )
