nuckollsr(at)cox.net Guest
Posted: Sat Mar 17, 2007 2:52 pm Post subject: How reliable is reliable |
At 05:10 PM 3/16/2007 -0700, you wrote:
Out of curiosity Bob, would you then mainly advocate z-14 for new designs
with a 20A alternator. In the past it seems you have suggested z-14 over
z-12 for people in the planning stages (correct me if I'm wrong). Maybe a
z-14 that uses the second bus as a smaller main alt. out e-bus, not used
for starting...smaller battery...
In what instance would you use z-12 over z-14 with a 20A alternator? Save
a little $ and #?
-Ryan (In the pondering stage)
To my way of thinking, perhaps 1-2% of all OBAM aircraft
under construction will be used in ways that justify a
Z-14 installation. Here's a post I made in 2005 to a similar
question:
At 08:46 PM 2/9/2005 +0100, you wrote:
<snip>
| Quote: | Thank you for your thoughtful reply. The 2 batt/2 alt setup (Z11) did get me
excited but the type of flying (very occasional dusk VFR, no IFR, over water
at times) plus a common sensical KISS principle to govern decisions may
dampen my enthusiasm for Z11.
Let's try to put some things into perspective. There are tons
of dark-n-stormy night stories wherein alternators and batteries
are star performers in the role of villain. Given the proven
reliability of modern automotive alternators . . . in particular
the converted Nipon Denso products from B&C . . . probability
of alternator failure is a small fraction of what we've come to
expect from certified iron. Combine this with the very robust,
sealed lead-acid batteries -AND- a truly meaningful preventative
maintenance plan and we've beat the worst worries into submission.
If one simply installs Van's a-la C-172 wiring with a modern
alternator and well maintained RG battery, probability of
having to take a staring role in a dark-n-stormy night play
due to electrical systems issues is very low.
By taking advantage of variations on a theme described in the
z-figures, one can push those probabilities still lower. In
10+ years of suggesting builders consider the e-bus, I've
had only one reader write and tell me the e-bus turned an
alternator failure into a ho-hum event. However, I've had
perhaps a half dozen people write and thank me for the OVM-14
crowbar ov module. Far more folks have experienced an ov
condition that forced alternator shutdown than simple
alternator failure. I don't recall the numbers of ov
experiences that benefited from an e-bus installation after
the alternator was shut off. Even if the builder did not
have an e-bus, keeping a well maintained RG battery on
board goes a long way to saving the day.
| Quote: | In the final analysis, I think it all boils down to whether I want full
electronic ignition, partial, or all mags.
If you go electronic ignition, consider at least one p-mag
which does not depend on electrical system for operation.
| Quote: | I am finishing the wings which means that I have a long way to go - you'll
see my posts as the situation evolves.
I have a client with enough funds to strive for the
"ultimate" system which may include dual efis, dual
electronic ignition, dual autopilots . . . For the
moment, I'm still trying to justify ruling out
a Figure Z-13/8 installation thus saving about a 23
pound penalty for going with Z-14.
Reliability doesn't have to be heavy or expensive . . .
just well considered. Since the e-mag/p-mag guys
came along, reliability is getting easier, lighter
and less expensive all the time.
------------------ end of quotation -------------------------
If I owned a certified machine, I would endeavor to
(1) add ACTIVE NOTIFICATION OF LOW VOLTAGE. (2)
install and MAINTAIN an RG battery. (3) Modify
the architecture to turn the avionics bus into an
E-BUS. (4) When an if the stock alternator craps,
I'd get a modern automotive adaptation in place.
These simple changes alone would elevate the spam
can's SYSTEM reliability by a quantum jump. Implementation
of an e-bus/bat-maintenance protocol makes the vast
majority of demonstrated concerns go away. Virtually
every dark-n-stormy night story I've read that concerned
electrical systems would never had been written had
the owner-operators of the subject airplanes availed
themselves of the knowledge and understanding offered
to you here on this List.
Now, if you don't plan to have a vacuum system then
the vacuum pump pad is open and you'll be many watt-hours
ahead in planning for alternator failure by adding the
SD-8 and perhaps even downsizing the battery for a wash
in weight.
Z-13/8 is an exceedingly robust system that should
handle everything you or I would want to do at
reliability levels that far exceed those of the
certified ships that we're ALREADY using do do the
same kinds of flights.
Now, Z-12 and Z-14 have some appeal but I'd recommend
Z-12 only as an upgrade to an existing Z-11 or spam-can
clone and Z-14 for ships like a Lancair IVP with full-up
dual IFR panels.
Obviously, if you have the $time$ and don't mind the
weight, you can pile on as many backups to backups that
suits your worry levels . . . but I'll suggest that
Z-13/8 is the value leader in return for reliability
with the lowest investment in $time$ and loss of
payload.
It would cost more dollars and talented manpower than
you or I are willing to expend to put numbers on the
relative reliability of Z-13/8 vs Z-14 for the various
operating scenarios. But it's my considered judgement
that Z-14 is overkill for most of the OBAM aircraft
under construction.
ryan42
Posted: Sun Mar 18, 2007 5:20 pm Post subject: Re: How reliable is reliable |
| Quote: | Z-13/8 is an exceedingly robust system that should
dual IFR panels.
payload.
under construction. |
That sounds entirely reasonable. It just seems that by removing the z-13/20 drawing (which I have no problem with), IF the airplane meets the kind of requirements and worry levels to warrent a backup 20 amp alternator, it sounds like you suggest z-14 over z-12 for new ships?
Posted: Sun Mar 18, 2007 7:49 pm Post subject: How reliable is reliable |
At 06:20 PM 3/18/2007 -0700, you wrote:
> dual IFR panels.
> payload.
> under construction.
Depends on the airplane and the missions. If you're
building a long-legged, $200,000 cross country rocket
and you intend to spend hours crossing weather fronts,
then something like Z-14 (along with a second pilot
in the right seat) is the uptown way to go.
If you have an as-purchased airplane wired ah-la C172/
A-36 and you'd like to go all-electric with minimal
changes to the system, then Z-12 is an option to consider.
If you're starting from scratch and intend to use your
airplane like 95% of your brothers use their airplanes,
then I'm betting that Z-13/8 has a high probability of
meeting your mission requirements at a minimum of
cost and weight.
( IF one aspires to be "world class", )
( what ever you do must be exercised )
( EVERY day . . . )
( R. L. Nuckolls III )
