shinden33(at)earthlink.ne Guest
Posted: Thu Mar 15, 2007 9:13 pm Post subject: Yak-52 Rudder Lock |
[quote] | Quote: |
All,
I still live in the desert and occasionally the airplane has to sit out side in the wind. The seat belts work for a stick control lock but I don’t have a rudder lock. Any suggestions?
Scott
N8252 | [b]
Posted: Fri Mar 16, 2007 4:10 am Post subject: Yak-52 Rudder Lock |
I pull a bungee cord from the rudder pedal in the rear cockpit to the frame under the seat. The frame extends outside of the seat and is easy to reach on either side. If the bungee cord is long enough, you can loop it though the hole in the frame back toward the rudder pedal. Works pretty good.
Dennis
cjpilot710(at)aol.com Guest
Posted: Fri Mar 16, 2007 6:32 am Post subject: Yak-52 Rudder Lock |
In a message dated 3/16/2007 7:13:00 A.M. Eastern Standard Time, dsavarese(at)elmore.rr.com writes:
I think bungee cords are a good idea. The damage is done when controls hit their stops hard. Bungee is good while your airplane sit on static display at airshows. One: the protection from wind banging. Two: crowd moving your control as they WILL do when you're not looking.
[quote] I pull a bungee cord from the rudder pedal in the rear cockpit to the frame under the seat. The frame extends outside of the seat and is easy to reach on either side. If the bungee cord is long enough, you can loop it though the hole in the frame back toward the rudder pedal. Works pretty good.
Dennis
Scooter
Posted: Fri Mar 16, 2007 6:58 am Post subject: Re: Yak-52 Rudder Lock |
In the past I have used a rope attached from one rudder pedal to the stick (full forward) and back to the other rudder pedal. Not sure if this is the best way but something to consider.
Also with the stick full back rainwater will accumulate in the elevator (mine anyway) because the drain holes are in the back.
eyeballs(at)cox.net Guest
Posted: Fri Mar 16, 2007 8:14 am Post subject: Yak-52 Rudder Lock |
Take a piece of 1/4 or 3/8 plywood. Cut two circles approx 6 inches in diameter. Drill hole in center for eyebolt that is small enough to fit through slot below rudder. Apply carpet to plywood. Attach rudder lock with eyebolt and wing nut. I attach a remove before flight streamer to eye of the eyebolt. I also put shrink wrap on the part of the eyebolt that will touch the rudder to avoid chafing. Paint the wood red.
This is a home made version of control locks that are available from pilot shops.
Jim Shafer
| Quote: | I still live in the desert and occasionally the airplane has to sit out side
in the wind. The seat belts work for a stick control lock but I don't have
pilko2(at)btinternet.com Guest
Posted: Fri Mar 16, 2007 9:03 am Post subject: Yak-52 Rudder Lock |
This is how they do it in Russia.
Personally I use a 1inch nylon luggage strap with non slip catch from the
left rudder pedal to the frame just aft of the front seat at shoulder
height.
kp
143.89 KB |
663 Time(s) |
173.38 KB |
643 Time(s) |
149.69 KB |
651 Time(s) |
Posted: Fri Mar 16, 2007 9:24 am Post subject: Yak-52 Rudder Lock |
Actually I think the hoop in both pictures is an elevator one whereas the
correct rudder one drops lower over the fin.
Posted: Fri Mar 16, 2007 9:49 pm Post subject: Yak-52 Rudder Lock |
Good suggestions all. Thanks a million.
Scott
lrob4783(at)bigpond.net.a Guest
Posted: Sat Mar 17, 2007 12:02 am Post subject: Yak-52 Rudder Lock |
Hi,
Can anyone tell me what the aircraft in the pictures is. It looks like a Yak
50 but not tail wheel.
Lance Robb
NQ Warbirds
Australia
143.89 KB |
632 Time(s) |
Posted: Sat Mar 17, 2007 1:35 am Post subject: Yak-52 Rudder Lock |
It's a so called "53"................ in reality a 52 with the front cockpit
removed. and panelled over. The picture was taken in Russia
but I believe the aircraft now fly's in the US.
kp
Scooter
jimscjs(at)mbay.net Guest
Posted: Sat Mar 17, 2007 8:54 am Post subject: Yak-52 Rudder Lock |
Yes It's a Yak-53 and I own it, it's for Sale, Very nice Aircraft it only
has 50 Hours total time on it and it fly's great, call if interested.
Jim selby
Posted: Sun Mar 18, 2007 11:51 am Post subject: Yak-52 Rudder Lock |
This is a Yak 53. Yes, 53 and not a typo error.
Dennis
