KiloPapa
  Joined: 24 May 2006 Posts: 142 Location: Pearblossom, CA
				 Posted: Fri Mar 09, 2007 10:57 am    Post subject: 3MT Scotch-WeldT Epoxy Adhesive DP100 Plus Clear info |
				FYI - Data sheet on the 3MT Scotch-WeldT Epoxy Adhesive DP100 Plus Clear
 mentioned below.
 http://www.bindingsource.com/pdf/DP-100%20plus%20specs.pdf
 Kevin
 40494
 tail/empennage
  Ben, we are using Click Bond fasteners with great results at adhesion.
  A clean and abraded surface is a logical process.  I will get you a
  couple of samples from work and bring them to the NW RV-10 dinner in
  May.
  	  | Quote: | 	 		   I will also bring a demo of 3M DP-100 two part catalytic adhesive which
  is superior to any product yet mentioned. Unfortunately with a quality
  build, it requires a 3M gun, plunger and nozzles.
  _________________ Kevin
40494
do not archive |
