KiloPapa
Joined: 24 May 2006 Posts: 142 Location: Pearblossom, CA
Posted: Fri Mar 09, 2007 10:57 am Post subject: 3MT Scotch-WeldT Epoxy Adhesive DP100 Plus Clear info |
FYI - Data sheet on the 3MT Scotch-WeldT Epoxy Adhesive DP100 Plus Clear
mentioned below.
http://www.bindingsource.com/pdf/DP-100%20plus%20specs.pdf
Kevin
40494
tail/empennage
Ben, we are using Click Bond fasteners with great results at adhesion.
A clean and abraded surface is a logical process. I will get you a
couple of samples from work and bring them to the NW RV-10 dinner in
May.
| Quote: | I will also bring a demo of 3M DP-100 two part catalytic adhesive which
is superior to any product yet mentioned. Unfortunately with a quality
build, it requires a 3M gun, plunger and nozzles.
_________________ Kevin
40494
do not archive |
