Mike Whisky
Posted: Sun Jan 28, 2007 12:01 pm Post subject: How does this tank test kit work? |
Hello I purchased Vans tank test kit but how should this fuel feed cover is supposed to work? Am I missing something here?
Michael
722.31 KB |
710 Time(s) |
_________________ RV-10 builder (flying)
#511 |
rvbuilder(at)sausen.net Guest
Posted: Sun Jan 28, 2007 3:54 pm Post subject: How does this tank test kit work? |
Unfortunately, almost everything in that kit is useless and doesn't
apply to the -10. You will have to improvise most of it.
Michael Sausen
-10 #352 Limbo
wvu(at)ameritel.net Guest
Posted: Sun Jan 28, 2007 7:30 pm Post subject: How does this tank test kit work? |
Michael,
I tested mine using Dan Checkoway's method, described here:
http://www.rvproject.com/20020710.html . It is quite sensitive to
atmospheric changes but should give a good feel.
Anh
Mike Whisky
Posted: Mon Jan 29, 2007 12:40 am Post subject: Re: How does this tank test kit work? |
Thank you Michael & Anh, I am just wondering why they sell it this way? Anyway I'll go the alternative route.
Thanks for the fast replys
Michael
http://www.wellenzohn.net
#511 |
henkjan(at)zme.nl Guest
Posted: Mon Jan 29, 2007 12:58 am Post subject: How does this tank test kit work? |
Why is it useless? I used it on both tanks recently
Henkjan van der Zouw
40355
-----Oorspronkelijk bericht-----
Van: owner-rv10-list-server(at)matronics.com
[mailto:owner-rv10-list-server(at)matronics.com] Namens RV Builder (Michael
Sausen)
Verzonden: maandag 29 januari 2007 0:54
Aan: rv10-list(at)matronics.com
Onderwerp: RE: How does this tank test kit work?
<rvbuilder(at)sausen.net>
Michael Sausen
-10 #352 Limbo
reubanks
Posted: Mon Jan 29, 2007 6:16 am Post subject: Re: How does this tank test kit work? |
Couldnt view your URL you posted. Below is the error:
Henkjan's Van's RV10 PH-ZME
RV10
All
Notice: Undefined variable: log_date in /home/content/a/e/r/aeroware2/html/users/display_log.php on line 174
Notice: strtotime(): Called with empty time parameter in /home/content/a/e/r/aeroware2/html/users/templates/library/chart_functions.php on line 28
1-29-2007
Unable to find a work log with the specified id or no id was specified.
LloydDR(at)wernerco.com Guest
Posted: Mon Jan 29, 2007 6:49 am Post subject: How does this tank test kit work? |
You need to cut and paste the entire link, as it got truncated.
Dan
N289DT
http://www.mykitlog.com/users/display_log.php?user=phzme&project=1&categ
ory=0&log 7411&row=1
I'm no computer wizz, look at www.zme.nl, click at the kitlog logo, it's
the last entry at the log
[mailto:owner-rv10-list-server(at)matronics.com] Namens reubanks
Verzonden: maandag 29 januari 2007 15:16
Onderwerp: Re: How does this tank test kit work?
RV10
All
ns.php on line 28
1-29-2007
http://forums.matronics.com/viewtopic.php?p=91266#91266
Mike Whisky
Posted: Mon Jan 29, 2007 8:09 am Post subject: Re: How does this tank test kit work? |
Sorry but I only had one valve, the blue cap and a description in my kit and thats ist. I wonder how you fit this to the standard fuel finger without additional hardware.
Michael
#511 |
reubanks
Posted: Tue Jan 30, 2007 7:10 am Post subject: Re: How does this tank test kit work? |
Hi Dan,
Yes, I used the entire URL before I sent the reply.
Posted: Tue Jan 30, 2007 8:59 am Post subject: How does this tank test kit work? |
Either I got a different kit, or we are looking at things differently,
because it worked for me. You put a balloon on the vent fitting and seal it
with a rubberband, put the tank fitting in the finger strainer and cap it
with the cap that comes in the kit, then put the little valve stem dealy
(technical term) in the sump hole, cap the tank with the filler cap and fill
with air until the balloon fills up and then check for leaks.
Hope this helps.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
Mike Whisky
Posted: Thu Feb 01, 2007 2:18 am Post subject: Re: How does this tank test kit work? |
Hello Jesse,
my issue is actually that the finger strainer has an inside thread as well as the cap. So I guess I am missing the tank fitting? Did it come with the wing kit?
Michael
#511 |
Tim Olson
Posted: Thu Feb 01, 2007 4:37 am Post subject: How does this tank test kit work? |
You use some of the standard AN fittings that probably are in your
kit to attach your fuel lines to. AN fittings is one area where
you may end up spending a bit extra and ordering varieties...if
you do anything non-standard, you'll be swapping one fitting for
another, and you'll have to order them. I think the ones in the
kit are just the plain straight AN6 nipple fittings.
Tim
Michael Wellenzohn wrote:
<michael(at)wellenzohn.net>
Hello Jesse,
Michael
-------- RV-10 builder (wings) #511
http://forums.matronics.com/viewtopic.php?p=92033#92033
Posted: Thu Feb 01, 2007 7:50 am Post subject: How does this tank test kit work? |
It should have come with the kit as I remember. It is the 6D fitting that
has pipe threads on one side and flare fitting on the other side (no angle,
no "T", just the short straight one) and put the cap on that.
Do not archive.
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
