How does this tank test kit work?
Mike Whisky
PostPosted: Sun Jan 28, 2007 12:01 pm    Post subject: How does this tank test kit work? Reply with quote
Hello I purchased Vans tank test kit but how should this fuel feed cover is supposed to work? Am I missing something here?
Michael
Tankd test kit
 Filesize:  722.31 KB
 Viewed:  631 Time(s)
RV-10 builder (flying)
#511
rvbuilder(at)sausen.net
PostPosted: Sun Jan 28, 2007 3:54 pm    Post subject: How does this tank test kit work? Reply with quote
Unfortunately, almost everything in that kit is useless and doesn't
apply to the -10. You will have to improvise most of it.
Michael Sausen
-10 #352 Limbo
wvu(at)ameritel.net
PostPosted: Sun Jan 28, 2007 7:30 pm    Post subject: How does this tank test kit work? Reply with quote
Michael,
I tested mine using Dan Checkoway's method, described here:
http://www.rvproject.com/20020710.html . It is quite sensitive to
atmospheric changes but should give a good feel.
Anh
Mike Whisky
PostPosted: Mon Jan 29, 2007 12:40 am    Post subject: Re: How does this tank test kit work? Reply with quote
Thank you Michael & Anh, I am just wondering why they sell it this way? Anyway I'll go the alternative route.
Thanks for the fast replys
Michael
http://www.wellenzohn.net
#511
henkjan(at)zme.nl
PostPosted: Mon Jan 29, 2007 12:45 am    Post subject: How does this tank test kit work? Reply with quote
Hi Michael,
I just tested my left tank last night using the test kit, look at:
http://www.mykitlog.com/users/display_log.php?user=phzme&project=1&categ
ory=0&log 7411&row=1
#40355
Henkjan van der Zouw
-----Oorspronkelijk bericht-----
Van: owner-rv10-list-server(at)matronics.com
[mailto:owner-rv10-list-server(at)matronics.com] Namens Michael Wellenzohn
Verzonden: zondag 28 januari 2007 21:02
Aan: rv10-list(at)matronics.com
Onderwerp: How does this tank test kit work?
<michael(at)wellenzohn.net>
Michael
RV-10 builder (wings)
#511
http://forums.matronics.com/viewtopic.php?p=91096#91096
http://forums.matronics.com//files/20070128_wings_01_503.jpg
henkjan(at)zme.nl
PostPosted: Mon Jan 29, 2007 12:58 am    Post subject: How does this tank test kit work? Reply with quote
Why is it useless? I used it on both tanks recently
40355
[mailto:owner-rv10-list-server(at)matronics.com] Namens RV Builder (Michael
Sausen)
Verzonden: maandag 29 januari 2007 0:54
Onderwerp: RE: How does this tank test kit work?
<rvbuilder(at)sausen.net>
Michael Sausen
-10 #352 Limbo
reubanks
PostPosted: Mon Jan 29, 2007 6:16 am    Post subject: Re: How does this tank test kit work? Reply with quote
Couldnt view your URL you posted. Below is the error:
Henkjan's Van's RV10 PH-ZME
RV10
All
Notice: Undefined variable: log_date in /home/content/a/e/r/aeroware2/html/users/display_log.php on line 174
Notice: strtotime(): Called with empty time parameter in /home/content/a/e/r/aeroware2/html/users/templates/library/chart_functions.php on line 28
1-29-2007
Unable to find a work log with the specified id or no id was specified.
LloydDR(at)wernerco.com
PostPosted: Mon Jan 29, 2007 6:49 am    Post subject: How does this tank test kit work? Reply with quote
You need to cut and paste the entire link, as it got truncated.
Dan
N289DT
henkjan(at)zme.nl
I'm no computer wizz, look at www.zme.nl, click at the kitlog logo, it's
the last entry at the log
[mailto:owner-rv10-list-server(at)matronics.com] Namens reubanks
Verzonden: maandag 29 januari 2007 15:16
Onderwerp: Re: How does this tank test kit work?
RV10
All
ns.php on line 28
1-29-2007
http://forums.matronics.com/viewtopic.php?p=91266#91266
Mike Whisky
PostPosted: Mon Jan 29, 2007 8:09 am    Post subject: Re: How does this tank test kit work? Reply with quote
Sorry but I only had one valve, the blue cap and a description in my kit and thats ist. I wonder how you fit this to the standard fuel finger without additional hardware.
Michael
#511
reubanks
PostPosted: Tue Jan 30, 2007 7:10 am    Post subject: Re: How does this tank test kit work? Reply with quote
Hi Dan,
Yes, I used the entire URL before I sent the reply.
jesse(at)saintaviation.co
PostPosted: Tue Jan 30, 2007 8:59 am    Post subject: How does this tank test kit work? Reply with quote
Either I got a different kit, or we are looking at things differently,
because it worked for me. You put a balloon on the vent fitting and seal it
with a rubberband, put the tank fitting in the finger strainer and cap it
with the cap that comes in the kit, then put the little valve stem dealy
(technical term) in the sump hole, cap the tank with the filler cap and fill
with air until the balloon fills up and then check for leaks.
Hope this helps.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
Mike Whisky
PostPosted: Thu Feb 01, 2007 2:18 am    Post subject: Re: How does this tank test kit work? Reply with quote
Hello Jesse,
my issue is actually that the finger strainer has an inside thread as well as the cap. So I guess I am missing the tank fitting? Did it come with the wing kit?
Michael
#511
Tim Olson
PostPosted: Thu Feb 01, 2007 4:37 am    Post subject: How does this tank test kit work? Reply with quote
You use some of the standard AN fittings that probably are in your
kit to attach your fuel lines to. AN fittings is one area where
you may end up spending a bit extra and ordering varieties...if
you do anything non-standard, you'll be swapping one fitting for
another, and you'll have to order them. I think the ones in the
kit are just the plain straight AN6 nipple fittings.
Hello Jesse,
Michael
-------- RV-10 builder (wings) #511
http://forums.matronics.com/viewtopic.php?p=92033#92033
PostPosted: Thu Feb 01, 2007 7:50 am    Post subject: How does this tank test kit work? Reply with quote
It should have come with the kit as I remember. It is the 6D fitting that
has pipe threads on one side and flare fitting on the other side (no angle,
no "T", just the short straight one) and put the cap on that.
Do not archive.
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
