av8rps(at)tznet.com Guest
Posted: Wed Dec 20, 2006 6:00 am Post subject: Older Kitfox cruise speeds |
Happy Holidays Everyone!
I was just looking through some old articles and thought I'd share this one
with the group.
On page 2 I've underlined in red ink what Denney Aircraft did to change the
wing incidence of the model 2's (and 3's as I recall). I thought I'd bring
this up because over the years I've noticed owners of older Kitfoxes puzzled
why their cruise is so much slower than the newer Kitfoxes, and in many
cases slower than Avid Flyers. In my opinion this article pretty much
explains it.
Sure, the newer Kitfox (Riblett) airfoil helps to make the newer Kitfoxes
cruise faster, but even if you were to put a new Riblett wing on an older
Kitfox, my guess is you wouldn't see a lot of cruise speed increase, because
there is just too much positive wing incidence causing a lot of drag.
(fwiw - I believe part of the Model IV mods made were to put the wing
incidence back where it belonged. Consequently, all newer Kitfoxes have
reduced wing incidence angles compared to the 2's and 3's). Hopefully this
information might keep a few owners of the older airplanes from going crazy
trying to "clean up" their airplanes in the hope of attaining the higher
cruise speeds.
In defense of the change Denney made back then, newer Kitfoxes will most
likely never be able to take off as short, fly as slow, or land as short as
the older airplanes. So all that positive wing incidence helps in all those
areas. Everything's a trade-off ...
As a side note, does anyone see anything wrong with the airplane on the
cover? Look close, as there is an obvious problem with it (experts usually
laugh when they see this picture).
Paul Seehafer
Model IV-1200 Amphib
Central Wisconsin
92.79 KB |
527 Time(s) |
73.53 KB |
547 Time(s) |
117.6 KB |
541 Time(s) |
rexinator(at)gmail.com Guest
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Wed Dec 20, 2006 8:01 am Post subject: Re: Older Kitfox cruise speeds |
I don't see any aft shock cords on the skis.
Tom Jones, skiplane wannabe
akflyer Guest
Posted: Wed Dec 20, 2006 9:38 am Post subject: Re: Older Kitfox cruise speeds |
looks like a photochop to me...
The photo looks like the plane is in the air, but the skis are not in the correct position for flying... the ski tips are low and the rear limiter cables are sagging suggesting that it is sitting on the ground.
Float Flyr
Posted: Wed Dec 20, 2006 9:39 am Post subject: Older Kitfox cruise speeds |
I have a couple of questions... The answer to one depends on the other.
Where did they ever get a flash strong enough to light the plane from the
bottom .....or was he flying inverted, possibly vertical ???
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Posted: Wed Dec 20, 2006 10:25 am Post subject: Older Kitfox cruise speeds |
BINGO!! Leni wins the prize! (ahem,,, we'll be mailing that out right
away....just send $54.95 to cover the shipping costs Leni) (chuckle)
Ski tips should always be up about 15 degrees in flight. Obviously in this
case they didn't understand how to rig ski cabling, as the front cable needs
to much shorter. In flight the rear cable should be taught, and the spring
bungee on the front taking up the slack in the loose front cables that is
needed to let the ski sit level on the ground when the tail is down. In
other words, the skis as they are could easily catch a tip when landing in
anything less than three point landing. Catching a tip while landing could
be disastrous. Rigging skis is a very important thing to get right as a
ski can also make for a large control surface (besides catching a tip
because it is rigged down too far). Imagine if one ski cable bungee broke,
so one ski was up 15 degrees, and the other was down say 40 degrees. I've
never flown one like that, but you had better hope you have enough control
authority from the rest of the control surfaces to stop the large downward
spiral dive you are otherwise going to enter. Don't let me scare you about
flying with skis now. Just make sure they are rigged right. This factory
demonstrator made a very good example of how to NEVER rig a ski on an
aircraft.
It was the things like this that used to cause so much riff between Avid and
Kitfox. I remember the Avid clan having a good laugh over that one
(remember, Avid was flying skis on their planes before Kitfox was even in
business. So all Kitfox would have had to do back then was to look at
theirs to get it right...) I don't mean to start any hot discussions about
which is airplane is better, because they are both marvelous airplanes, and
the Kitfox in particular has evolved rather nicely (I know I have both).
But the little things like this make it very obvious which company had the
real designer.
Paul
Posted: Wed Dec 20, 2006 10:59 am Post subject: Older Kitfox cruise speeds |
Noel,
I think it was the snow acting as the worlds best flash reflector...
Paul
akflyer Guest
Posted: Wed Dec 20, 2006 11:43 am Post subject: Re: Older Kitfox cruise speeds |
Also, the front should have a limiter cable incase the bungee breaks for the very purpose of keeping the skis from rolling into a excessive nose down attitude. I have had it happen on RC models. Last year I had my 1/6th scale Beaver (22# and an 8' wing span) on Skis and caught the tip on takeoff. I had limiter calbes, but it still alowed the ski to rotate to far. It was a bit of a handful when I tried to slow it down for landing.. as the rudder lost effectiveness at low speeds. I was able to go into the programing in the air and go to 140% throw on the rudder and then made a safe landing. I would not want to do it a real plane..
Michel
Posted: Wed Dec 20, 2006 12:50 pm Post subject: Older Kitfox cruise speeds |
On Dec 20, 2006, at 6:38 PM, akflyer wrote:
| Quote: | the ski tips are low and the rear limiter cables are sagging
Exactly! If my skis were like that in the air, I'd have a serious
problem.
Michel
_________________ Kitfox 3 - Jabiru 2200 |
Float Flyr
Float Flyr
Posted: Wed Dec 20, 2006 1:29 pm Post subject: Older Kitfox cruise speeds |
Disregard my last post.... The picture looked like something manipulated.
The bungees on the tips of the skis seemed stretched which made me think the
picture was actually taken on the ground. Note the alignment of the ski
with the tail wheel.
My best guess now is they rigged the skis with the tail down on the hangar
floor....
BTW I have a set of those composite skis. The previous owner of my plane
even made a set or removable rear tips so the plane can easily be towed
backwards by a ski-doo. I was warned to always remove the rear tips before
flight.
Noel
[quote] --
Kitfox III-A
dave
Posted: Wed Dec 20, 2006 2:40 pm Post subject: Older Kitfox cruise speeds |
Those pics just show that they wer rigged with too long of cable on front
and the airflow is pushing them down.
Not a good thing at all.
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Lynn Matteson
Posted: Wed Dec 20, 2006 2:50 pm Post subject: Older Kitfox cruise speeds |
The shadows look acceptable to me, Noel...it looks like a low winter
sun shot to me. Look at the shadows on the ground...they are all
being caused by the same apparent light source. If not the low sun,
then probably a strobe or single light source of some sort.
Lynn
other.
from the
Noel
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
eskflyer(at)lvcisp.com Guest
Posted: Wed Dec 20, 2006 4:28 pm Post subject: Older Kitfox cruise speeds |
NO they are not to long when you are on the ground they have to be in that
angle . Supposed to have a strong enough bungy on the front to pull them up
when in flight .
John Perry
dave
Posted: Wed Dec 20, 2006 5:08 pm Post subject: Older Kitfox cruise speeds |
John ,
When on the ground , my bungees are stretched.
When in the air the bugee pulls the ski until the safety cable on rear
become tight unless of course the front is too long which makes it loose and
the ariflow pushes the tip down.
You can see mine here in the video from 10 days ago
http://www.cfisher.com/kitfox/
And my rear safety cable could afford to be about 1 inch longer.
If you need some pics, just let me know and I will post them.
Dave
akflyer Guest
Posted: Wed Dec 20, 2006 6:01 pm Post subject: Re: Older Kitfox cruise speeds |
Dave,
John is painfully aware of how skis are rigged... hey John how many them have we done ????? PA-18's, PA-12's, 180's, 185's, 206's... the list is long but distinguished...
The video was nice, but looks like the skis could be a little bigger for playing in deep powder.
The boards I had on my 12 were larger than a set I put on a buddies 180... I kicked his butt in the powder...
Posted: Wed Dec 20, 2006 6:20 pm Post subject: Older Kitfox cruise speeds |
UHHHHH Dave
when sitting flat on ground with taildragger your skis should be straight
out level in front of you on the ground. Look at the pic that is how the ski
is flying . You then install your front safety cables to linit them to this
spot . now you lift the tail and to until the plane is in level flight mode
. and then add 2-3 inches up on tail . now place your rear limit safety
cables . now put your bungees on and make shure they are strong enough to
pull the skis up in the front in flight . I have done MANNNNNNNY instals on
aircraft . If you read my last post slowly you will see this is what is said
in much shorter post .
Fly safe fly low fly slow
OHH yeah MERRY CHRISTMAS almost
John Perry
dave
Posted: Thu Dec 21, 2006 7:45 am Post subject: Older Kitfox cruise speeds |
What are you talking about ?
Mine are rigged properly- are you disputing that they are not ?
I answered a question for Tom Jones that asked why there was no bungee on
the aft end of the ski.
I put up a video and it flys and works fine. If you need pics I can post
them as well.
Perhaps you could post a video and pics if you are disputing this.
Dave
PS Here links to the factual SKi video http://www.cfisher.com/kitfox/
and the factual info on NGK plugs http://www.cfisher.com/ngk/ that
was backed up by Bob Robertson the Rotax guru.
smokey_bear_40220(at)yaho Guest
Posted: Thu Dec 21, 2006 8:48 am Post subject: Older Kitfox cruise speeds |
Shouldn´t the cables have enough slack to allow for
going over slight hills, or will the skis flex enough
for that without over-stressing? After all, these are
often used off airport.
Kurt S.
--- john perry <eskflyer(at)lvcisp.com> wrote:
| Quote: | UHHHHH Dave
cables to linit them to this ............
spot .
Posted: Thu Dec 21, 2006 9:12 am Post subject: Older Kitfox cruise speeds |
Dave did I say yours are rigged wrong if your asking this ? then i guess
the answer must be yes in your mind . As for you plugging in your video clip
all the time its getting tiresome ,yes its great you can do videos and i
enjoy watching them usually once is enough. Now if youll read your own post
you that you sent you wrote my NAME at the top of your post so I really
dont think you know who you were posting to . IF YOU WILL READ MY POST AND
LOOK AT THE PIC you will see what I am talking about .Now enough on the
skis
The SPARK PLUG
I have talked with NGK corporate and the head of the technical department
several times now on this matter .
The NGK plug that rotax buys from them is the B8ES Stock # 3683, BR8ES Stock
#3961 theya re snet to rotax in nice yellow and white boxes with a X thru a
ultralight and a airplane . Rotax takes these out and sned them back out in
nice foam packaging to take the liability off of NGK . IF YOU WILL READ MY
PREVIOUS POSTS you will see I said use the solid cap plugs and gave the
correct stock number from NGK . If you cant read then thats your problem .
Im tired of arguing with someone who has not talked with NGK and found out
the Correct information themselves and are so self- righteous that they are
right because of second hand info from a authorized ROTAX sealer and repair
station . OF course they want you to buy from them thats how they make a
buck geeesh. .
Now Dave I do not have a problem with you its just that in my humble
opinion you do not have all your marbles in one place .
Read and listen to the post and go on to the net and ask questions of the
right people.
Take care fly safe fly low fly snow
MERRY CHRISTMAS
John Perry
