rlborger(at)mac.com Guest
Posted: Fri Oct 27, 2006 6:28 pm Post subject: Fuel vent mods |
Fellow Europaphiles,
I have come to the conclusion that I do not like the fuel vent system as per installation instructions. I know there are a number of other venting schemes out there. I'd appreciate it if any of you could point me to any pictures and descriptions of these alternates.
Thanks in advance to all.
Good building and great flying,
Bob Borger
Europa Kit #A221 N914XL, XS Mono, Intercooled 914, Airmaster C/S
http://www.europaowners.org/N914XL
(85%) tail kit done, wings closed, cockpit module installed, pitch system in, landing gear frame in, rudder system in, outrigger mod in, Fuselage Top on, lift/drag/flap pins in, wing incidence set, tie bar in, flap drive in, Mod 70 done. Baggage bay in. Flaps & Main Gear complete. Working in - 24 Instrument Panel, 25 Electrical, 30 Fuel System, 32 Tail, 34 Door Latches & 35 Doors, 37 Finishing. Airmaster arrived 29 Sep 05. Seat arrived from Oregon Aero. E04 interior kit has arrived. Preparing for ROTAX 914 installation.
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
europa(at)pstewart.f2s.co Guest
Posted: Sat Oct 28, 2006 1:14 am Post subject: Fuel vent mods |
The europa owners forum (www.europaowners.org) has some pics of our set up (G-GIDY) - page two of the gallery under fuel mods. Although it has PFA approval here in the UK we are not yet flying or filling the tank so can't vouch for its effectiveness. I know others have vented from the tank upto the filler then back down to area around the flap dive rod. I can't find any such pics but Graham Singleton may be able to oblige??
Paul
G-GIDY
(Surrounded by tangles of wire but more fun than sanding)
On 28 Oct 2006, at 03:26, rlborger wrote:
[quote]Fellow Europaphiles,
Bob Borger
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronics.com/Navigator?Europa-List
ntribution
| [b]
josok-e(at)ukolo.fi Guest
Posted: Sat Oct 28, 2006 2:08 am Post subject: Fuel vent mods |
Just around the corner Bob:
The link to Graham's fuel mod pictures:
http://www.europaowners.org/modules.php?set_albumName=Graham&op=modload&name=gallery&file=index&include=view_album.php
My installation:
http://www.europaowners.org/modules.php?set_albumName=fuel-system&op=modload&name=gallery&file=index&include=view_album.php
Kind Regards,
Jos Okhuijsen
workshopcam http://www.okhuijsen.org/plane
http:www.europaowners.org/kit600
mono xs, top on, gear in, tail wheel in, wings set, flapdrive in, tail
closed, tailwheel in, tail top in, blue stuff filled, sanded and primed,
fuel system in, doors done, windows in, sanding and filling the fuse and
wings.
hagargs(at)earthlink.net Guest
Posted: Sat Oct 28, 2006 3:55 am Post subject: Fuel vent mods |
See attached
Steve Hagar
hagargs(at)earthlink.net (hagargs(at)earthlink.net)
43.35 KB |
343 Time(s) |
82.53 KB |
330 Time(s) |
paul.mcallister
Joined: 09 Jan 2006 Posts: 177 Location: Waukesha, WI USA
Posted: Sun Oct 29, 2006 1:36 pm Post subject: Fuel vent mods |
Hi all,
Some time ago I read on the forum and idea of providing backup fuel tank vent by using a one way value inside the cabin. Does anyone recollect who that was, and even better, what type of valve was used.
Paul N378PJ
530 hours and still grinning
rparigor(at)suffolk.lib.n Guest
Posted: Sun Oct 29, 2006 3:06 pm Post subject: Fuel vent mods |
Hello Paul
"Does anyone recollect who that was, and even better, what type of valve
was used."
Try:
http://www.mcmaster.com/
search 1 way valve
read about check valves
Order a few different types and let us know which one you like.
Take a look below at:
Nylon Body with Viton Diaphragm
PVDF Body with Viton Diaphragm
Crack pressure is under 1 PSI, I don't have a feeling just how low a crack
pressure you want. A 1 liter soda bottle with a hole in it to stick in
place a tygon tube connected to your 1 way, and suck on threaded end
should give you a very good feel for what you want.
Once you select a good crack pressure put it in a bottle for a while with
Mogas, and another with 100LL, then check function again. After fuel test
let bake in sun for a while on the dash of your car for a week and try
again.
We know Viton is probably good. Nylon you see being used in fuel systems,
but you need to be careful as there are different types of nylon. PVDF I
am not familiar with, but think it is well worth a $11.05 test.
Ron Parigoris
This is on page 441 (has picture):
Diaphragm Check Valves
• Maximum Pressure: 15 psi
• Cracking Pressure: Less than 1 psi
These valves have a three-piece design for air applications. They
have a free-floating diaphragm coated with silicone lubricant to assist in
sealing, can be cycled as fast as once per second, and operate in any
position. Use with soft thermoplastic tubing. Note: Cv factor not rated.
Connections: 1/8" sizes have straight ends without barbs; all others have
barbed ends.
Polypropylene Body with Viton or Fluorosilicone Diaphragm— For
corrosive external environments. Temperature range is -40° to +180° F.
Color is translucent white.
Nylon Body with Viton or Fluorosilicone Diaphragm— For higher
external-temperature applications. Temperature range is -70° to +250° F.
Color is translucent white and black, except 47245K17 which is
translucent white and gray.
PVDF Body with Viton Diaphragm— For external applications requiring
superior chemical and abrasion resistance. Temp. range is -70° to +250°
F. Color is translucent white, except 47245K35 which is blue.
Tube ID End-to-End Lg. Each
Polypropylene Body with Viton Diaphragm
1/8" 1 39/64" 47245K11 $6.32
3/16" 1 11/16" 47245K12 6.32
1/4" 1 17/32" 47245K13 6.32
5/16" 1 3/4" 47245K14 8.16
Polypropylene Body with Fluorosilicone Diaphragm
1/8" 1 39/64" 47245K15 5.79
3/16" 1 11/16" 47245K16 4.80
3/16" 1 11/16" 47245K17 5.86
1/4" 1 17/32" 47245K18 5.86
Nylon Body with Fluorosilicone Diaphragm
1/8" 1 39/64" 47245K25 4.80
3/16" 1 11/16" 47245K26 4.80
1/4" 1 17/32" 47245K27 4.80
5/16" 1 3/4" 47245K24 6.45
1/8" 1 39/64" 47245K35 12.63
3/16" 1 11/16" 47245K36 11.05
1/4" 1 35/64" 47245K37 11.05
5/16" 1 3/4" 47245K34 20.79
Double-Union Ball Check Valves
Posted: Sun Oct 29, 2006 3:40 pm Post subject: Fuel vent mods |
Hello Paul
1 more page 439:
Ron P.
Spring-Loaded Ball Check Valves with Barbed Connections
• Maximum Pressure: 125 psi (at) 140° F
• Cracking Pressure: 1 psi
• Temperature Range: 33° to 140° F
These check valves easily fit into tight areas and have good chemical
resistance. For use with soft tubing. Valves have a soft seat. Spring is
Type 302 stainless steel; ball is Type 316 stainless steel. Color is
white. Note: Cv factor not rated. Connections: Barbed.
To Order: Please specify Buna-N or Viton seat.
For End-to- Polypropylene Nylon
Tube ID End Lg. Each Each
1/8" 1 3/8" 7757K11 $3.23
6079T51 $3.56
3/16" 1 11/16" 7757K12 3.23
6079T52 3.56
1/4" 2" 7757K13 3.23
6079T53 3.56
439
jeff(at)rmmm.net Guest
Posted: Mon Oct 30, 2006 3:47 pm Post subject: Fuel vent mods |
Ron,
I must have missed part of this thread so tell me if I'm wrong here.
Are you talking about a valve that will open automatically should the
vent tub become clogged, and if so what catalog/company does your page
numbers refer too? I would like to mount one in the filler tube venting
it into the cabin.
Jeff
N128LJ - Flying
On Oct 29, 2006, at 5:38 PM, <rparigor(at)suffolk.lib.ny.us> wrote:
Hello Paul
1 more page 439:
Ron P.
chemical
is
6079T51 $3.56
6079T52 3.56
6079T53 3.56
439
Posted: Mon Oct 30, 2006 8:47 pm Post subject: Fuel vent mods |
Hello Jeff
"I must have missed part of this thread so tell me if I'm wrong here."
You must have missed my first post.
Go to :
Scroll down to:
Matronics Listserver
For first post.
I saw a few 1 way valves that tweaked my interest and listed them in 2
posts.
Ron P.
