jonboede(at)hotmail.com Guest
Posted: Fri Jan 13, 2023 10:37 pm Post subject: central tank fuel drain question |
I've looked in the parts catalogs for the CJ and haven't found one that shows the bottom of the central fuel collection tank.
On the bottom of that tank there's a cap with a 36mm nut and through the center of that nut is a 15-20mm drain device, the top of which presses against the hole in the bottom of the central tank.
On my tank that drain device is metal-on-metal with the central tank.
I strongly suspect that there was some kind of gasket or rubber washer between the drain device and the central tank.
Any ideas on what material that gasket/washer should be? Or what I should replace it with? Cork? Rubber? I'm thinking I can go with a 1-2mm Neoprene washer, or some of that blue gasket 1/16". Which would be a better material?
Jon
Mark Pennington
Joined: 18 Jul 2022 Posts: 11 Location: Richmond Virginia
Posted: Sat Jan 14, 2023 1:38 am Post subject: central tank fuel drain question |
Jon
You are correct there is a round gasket in the bottom of the consumption tank. When I went through mine I got a new one from Doug.Â
I would reach out to Carl who has the parts business now. I am sure be has one.  If not you cut one from any suitable material for AV gas. Â
I put a photo of my old one as I removed it from the tank. You can download it and blow it up to see the thickness. It is pretty thick.Â
Mark Pennington
N621CJ
[img]cid:185afa1e290c47b222f1[/img]
On Sat, Jan 14, 2023 at 1:41 AM Jon Boede <jonboede(at)hotmail.com (jonboede(at)hotmail.com)> wrote:
| Quote: | I've looked in the parts catalogs for the CJ and haven't found one that shows the bottom of the central fuel collection tank.
Jon
Replied from my iPhone. Please excuse brevity any typos in the content
635.32 KB |
6614 Time(s) |
_________________ Responding from my iPhone, please disregard any typos. |
Ttail
Posted: Sat Jan 14, 2023 12:49 pm Post subject: Re: central tank fuel drain question |
Another view.
I got one of these gaskets from Doug a while ago. Yet to be installed. Next visit to the hangar I will measure it.
75.67 KB |
6606 Time(s) |
_________________ Sean Trestrail
ttail[at]internode.on.net |
Ttail
Posted: Sun Jan 15, 2023 8:43 pm Post subject: Re: central tank fuel drain question |
Images of a new Fuel tank Drain gasket.
184.6 KB |
6572 Time(s) |
