LarryRosen
Posted: Tue Oct 24, 2006 5:50 am Post subject: DVD Player Ground |
Should the ground to the DVD player that I am installing in my RV-10 be
grounded pack to the cockpit ground bus?
See aeroelectric Z15-3 here
<http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z15-3.pdf>
Larry Rosen
RV-10 #356
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
nuckollsr(at)cox.net Guest
Posted: Tue Oct 24, 2006 7:51 am Post subject: DVD Player Ground |
At 09:49 AM 10/24/2006 -0400, you wrote:
Larry Rosen
RV-10 #356
Sure (or the avionics ground bus). It's a potential victim
of ground-loop noises. Now, having said that, be aware that
many appliances have case grounds that parallel their
pin-out grounds in connectors. This is one of the reasons
the panel or avionics ground bus was added to the panel at
Rev 11. This drastically shortens any potential ground loops
due to case grounds running in parallel with wired grounds.
< with experiment. >
< --Lawrence M. Krauss >
